I’m going nuts over this…
I have a read-only usb that I attach to a qube and I want to set it’s permissions to writable, but I can’t. I can’t even format it. The usual thing to unmount and mount with permissions don’t work, as when I unmount I don’t see the usb(the path e.g. /dev/sda) in the terminal of that qube.
So how do I format it?
and how do I grant write permissions if I need to, for the entire usb? -
I also want to make a bootable some windows usb that etcher won’t make it bootable. so I tried like billion ways and I can’t make this little shit bootable including running rufus with wine(because rufus with wine works only with version 3.2 or whatever and it doesn’t even see the usb) and nothing helps. like seriously… what the…
Isn’t there like a some tiny program to handle this in a sane way without want me to end my life?
