Hi, I’m new to Qubes, I am wondering if Zoom works in Qubes? And if it’s possible to show two different presentations at the same time in Zoom?
I will be grateful for your help!
I could install Zoom in Fedora, Windows-7 and Unbuntu templates and start Zoom sessions in parallel in both of them. See this screenshot:
When using the camera of my laptop, performance was not the best, however.
Yes, you can use Zoom. And you can also show multiple images at the same time, you just need to: click on the green Share Screen button in the meeting controls;
then select the screen you want to share;
hold Shift to select multiple windows.
There are other ways to do this, read more here:
