any ideas how to fix this?
Dec 23 18:59:22 dom0 kernel: tpm tpm0: Operation Timed out
Dec 23 18:59:23 dom0 systemd-vconsole-setup[445]: /usr/bin/setfont failed with exit status 71.
Dec 23 18:59:23 dom0 systemd-vconsole-setup[450]: /usr/bin/setfont failed with exit status 71.
Dec 23 18:59:24 dom0 kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 022554 [ PRIVRING ]
Dec 23 18:59:37 dom0 systemd-tty-ask-password-agent[456]: Invalid password file /run/systemd/ask-password/ask.wpgn1k
Dec 23 18:59:37 dom0 systemd-tty-ask-password-agent[456]: Failed to process password: Bad message
Dec 23 18:59:42 dom0 systemd-udevd[950]: event4: Failed to open device '/dev/input/event4': No such file or directory
Dec 23 18:59:44 dom0 kernel: Bluetooth: hci0: Reading supported features failed (-16)
Dec 23 18:59:45 dom0 alsactl[1744]: /usr/sbin/alsactl: load_state:1683Cannot open /var/lib/alsa/asound.state for reading: No such file or directory
Dec 23 18:59:45 dom0 alsactl[1744]: alsa-lib main.c:983:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -2
Dec 23 18:59:46 dom0 alsactl[1744]: alsa-lib main.c:983:(snd_use_case_mgr_open) error: failed to import hw:1 use case configuration -2
Dec 23 18:59:46 dom0 xenstored[1762]: Checking store ...
Dec 23 18:59:46 dom0 xenstored[1762]: Checking store complete.
Dec 23 18:59:52 dom0 anaconda[2319]: anaconda: ui.gui.hubs: Initialization controller for hub InitialSetupMainHub expected but missing.
Dec 23 19:13:15 dom0 libvirtd[1779]: internal error: Unable to reset PCI device 0000:00:14.0: no FLR, PM reset or bus reset available
Dec 23 19:15:12 dom0 pulseaudio[14117]: ALSA woke us up to read new data from the device, but there was actually nothing to read.
Dec 23 19:15:12 dom0 pulseaudio[14117]: Most likely this is a bug in the ALSA driver 'snd_hda_intel'. Please report this issue to the ALSA developers.
Dec 23 19:15:12 dom0 pulseaudio[14117]: We were woken up with POLLIN set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
Dec 23 19:15:15 dom0 pulseaudio[14117]: ALSA woke us up to write new data to the device, but there was actually nothing to write.
Dec 23 19:15:15 dom0 pulseaudio[14117]: Most likely this is a bug in the ALSA driver 'snd_hda_intel'. Please report this issue to the ALSA developers.
Dec 23 19:15:15 dom0 pulseaudio[14117]: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
Dec 23 19:42:22 dom0 systemd-coredump[39760]: Process 14158 (xss-lock) of user 1000 dumped core.
Stack trace of thread 14158:
#0 0x00007475baa8efc2 g_logv (libglib-2.0.so.0 + 0x59fc2)
#1 0x00007475baa8f233 g_log (libglib-2.0.so.0 + 0x5a233)
#2 0x000058fb8dce4be5 screensaver_event_cb (xss-lock + 0x4be5)
#3 0x000058fb8dce4cdf xcb_event_dispatch (xss-lock + 0x4cdf)
#4 0x00007475baa8778f g_main_context_dispatch (libglib-2.0.so.0 + 0x5278f)
#5 0x00007475baa87b18 g_main_context_iterate.constprop.0 (libglib-2.0.so.0 + 0x52b18)
#6 0x00007475baa87e33 g_main_loop_run (libglib-2.0.so.0 + 0x52e33)
#7 0x000058fb8dce3ecd main (xss-lock + 0x3ecd)
#8 0x00007475ba855082 __libc_start_main (libc.so.6 + 0x27082)
#9 0x000058fb8dce402e _start (xss-lock + 0x402e)
Stack trace of thread 14166:
#0 0x00007475ba92486f __poll (libc.so.6 + 0xf686f)
#1 0x00007475baa87aae g_main_context_iterate.constprop.0 (libglib-2.0.so.0 + 0x52aae)
#2 0x00007475baa87be3 g_main_context_iteration (libglib-2.0.so.0 + 0x52be3)
#3 0x00007475baa87c31 glib_worker_main (libglib-2.0.so.0 + 0x52c31)
#4 0x00007475baab17f2 g_thread_proxy (libglib-2.0.so.0 + 0x7c7f2)
#5 0x00007475ba74c432 start_thread (libpthread.so.0 + 0x9432)
#6 0x00007475ba92f6d3 __clone (libc.so.6 + 0x1016d3)
Stack trace of thread 14171:
#2 0x00007475baa87e33 g_main_loop_run (libglib-2.0.so.0 + 0x52e33)
#3 0x00007475bacdb6aa gdbus_shared_thread_func (libgio-2.0.so.0 + 0x1226aa)
Dec 23 19:42:26 dom0 qrexec-policy-e[13844]: error calling qrexec-policy-agent in dom0
File "/usr/lib/python3.8/site-packages/qrexec/tools/qrexec_policy_exec.py", line 133, in execute
await super().execute(caller_ident)
File "/usr/lib/python3.8/site-packages/qrexec/policy/parser.py", line 552, in execute
raise ExecutionFailed('qrexec-client failed: {}'.format(command))
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-usb,8',>
During handling of the above exception, another exception occurred:
File "/usr/lib/python3.8/site-packages/qrexec/tools/qrexec_policy_exec.py", line 151, in notify
await call_socket_service(guivm, service, source_domain, params)
File "/usr/lib/python3.8/site-packages/qrexec/server.py", line 105, in call_socket_service_local
reader, writer = await asyncio.open_unix_connection(path)
File "/usr/lib64/python3.8/asyncio/streams.py", line 111, in open_unix_connection
transport, _ = await loop.create_unix_connection(
File "/usr/lib64/python3.8/asyncio/unix_events.py", line 244, in create_unix_connection
await self.sock_connect(sock, path)
File "/usr/lib64/python3.8/asyncio/selector_events.py", line 496, in sock_connect
return await fut
File "/usr/lib64/python3.8/asyncio/selector_events.py", line 501, in _sock_connect
sock.connect(address)
ConnectionRefusedError: [Errno 111] Connection refused
Dec 23 19:42:26 dom0 qrexec[13844]: qubes.InputMouse: sys-usb -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', >
Dec 23 19:42:26 dom0 qrexec-policy-e[39742]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-firewal>
return await fut
Dec 23 19:42:26 dom0 qrexec[39742]: qubes.WindowIconUpdater: sys-firewall -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'd>
Dec 23 19:42:26 dom0 qrexec-policy-e[39812]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-net,5',>
return await fut
Dec 23 19:42:26 dom0 qrexec[39812]: qubes.WindowIconUpdater: sys-net -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0',>
Dec 23 19:42:26 dom0 qrexec-policy-e[39743]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-whonix,>
return await fut
Dec 23 19:42:26 dom0 qrexec[39743]: qubes.WindowIconUpdater: sys-whonix -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom>
Dec 23 19:42:26 dom0 qrexec-policy-e[39768]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET13,sys-usb,8',>
return await fut
Dec 23 19:42:26 dom0 qrexec[39768]: qubes.WindowIconUpdater: sys-usb -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0',>
Dec 23 19:44:02 dom0 libvirtd[1779]: internal error: Unable to reset PCI device 0000:00:14.0: no FLR, PM reset or bus reset available
Dec 23 19:44:06 dom0 systemd-cryptsetup[43125]: Device luks-4603badf-a995-430b-acb6-b08d9bb443a9 is still in use.
Dec 23 19:44:06 dom0 systemd-cryptsetup[43125]: Failed to deactivate: Device or resource busy
-- Reboot --
Dec 23 19:48:43 dom0 kernel: tpm tpm0: Operation Timed out
Dec 23 19:48:44 dom0 systemd-vconsole-setup[456]: /usr/bin/setfont failed with exit status 71.
Dec 23 19:48:44 dom0 kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 001228 [ PRIVRING ]
Dec 23 19:49:06 dom0 xenstored[1462]: Checking store ...
Dec 23 19:49:06 dom0 xenstored[1462]: Checking store complete.
Dec 23 19:49:07 dom0 libvirtd[1487]: internal error: Unable to reset PCI device 0000:00:14.0: no FLR, PM reset or bus reset available
Dec 23 19:49:39 dom0 pulseaudio[19503]: ALSA woke us up to write new data to the device, but there was actually nothing to write.
Dec 23 19:49:39 dom0 pulseaudio[19503]: Most likely this is a bug in the ALSA driver 'snd_hda_intel'. Please report this issue to the ALSA developers.
Dec 23 19:49:39 dom0 pulseaudio[19503]: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
