I am on R4.3 with an fully up-to-date system.
I remember that once while doing an backup with wyng i had to stop the backup while running, which lead to some errors when I tried to do an backup again. Fortunately I was able to fix this, unfortunately this happened already some time ago and i didnt save any error messages.
However, creating backups with sudo wyng-util-qubes backup -includes and sudo wyng arch-check --session=newest works fine.
The only command that fails is
sudo wyng monitor --all
Output is:
Local storage is offline: None
Wyng 0.8 beta release 20250824
Enter passphrase:
Encrypted archive 'qubes://<REDACTED>'
Last updated 2025-09-28 12:01:39.249748 (+20:00)
Error, Local path not found: (None) None
Error on volumes: <REDACTED, but all my volumes are just listed>
the “Local storage is offline: None” error also occurs on sudo wyng monitor --all, but the backup still finishes without any other errors.
