Wyng for Noobs
@Mirai Thanks for following-up. I re-opened the issue and posted a workaround in fix08.
I’m unsure how introducing a tty/login shell will impact remote access, so I went with a simpler solution which is to prefix the command with sh -c.
@tasket thanks for the quick response.
Unfortunately it still fails
Wyng-util-qubes v0.9 beta rel 20251105
Wyng 0.8.1 (fix08) release 20260427
XXXXXXXXX)'.
mkdir -p -m 777 /tmp/wyngrpc/  && tdir=$(mktemp -d /tmp/wyngrpc/tmpXXXXXXXXXXXX)  && echo && echo $tdir && cat >$tdir/dest_helper.py
[0, 127]
StorageError: (5, 'Destination not ready to receive commands.')
@Mirai Seems to be an odd artifact of ssh and its shell invocation. But this new workaround I just posted works on my Ubuntu server when its set to use fish. Hopefully it works for you, too.
@tasket :frowning: fish is version 4.2 on fedora 33 in both the sending and receiving qube.
Wyng 0.8.1 (fishpass) release 20260430
warning: An error occurred while redirecting file '/tmp/wyngrpc/tmpnojr7lxm'
warning: Path '/tmp/wyngrpc' does not exist
/bin/sh: /tmp/wyngrpc/tmpnojr7lxm: No such file or directory
[0, 127]
@Mirai OK, I left out a necessary mkdir before creating the script at that path. Error doesn’t occur if the /tmp/wyngrpc dir already exists.
The fishpass branch has been updated with the necessary changes.
@tasket thank you no problems now <3
Wyng is fantastic
Please check out the Wyng v0.8.1 and v0.9alpha2 releases being readied…
v0.8.1 in the fix08 branch has some bug fixes and enhanced data recovery in arch-check.
v0.9alpha has arch-copy, which efficiently copies/updates duplicate archives. It also allows passphrase changes, cc @solene. These are some of the most-requested new features, though there are more to come.
can wyng backup running qubes?
what happens if backup destination does not exist and it auto runs the backup (like missing external hdd)?
can i choose not to encrypt the backup (my disk already encrypted)?
@ssh1 By itself Wyng will backup a running VM in the state it had when it was started, not the current state. Similar to the built-in qubes-backup tool, to backup the most recent information with Wyng VMs should be shutdown or restarted prior to running the backup.
Its also possible to run a script to create snapshots of the live VM volumes, possibly by running fsfreeze beforehand to help ensure the VM filesystem is taken in a consistent state. This would allow backing up new information in running VMs without a shutdown or restart. An issue exists for making this an automatic Wyng feature in the future.
Encryption is optional, just use --encrypt=off when creating the archive with wyng arch-init.
