Usually my work spaces show on the panel and I can click through them on the panel. They always showed as squares. Suddenly this is gone and the only way I can scroll through the different work spaces is my the scroll button on my mouse.
First: Change your title, “Please help” is probably the least helpful title you could use.
Second: Have you tried the ol’ turn it off and on trick?
Yeah and still no fix
I can’t even click and drag windows to different work spaces on panel like I did before
Could you attach an image?
