Good morning, I hope you are doing well perhaps you might know more about me Hardware compatibility list (HCL) | Qubes OS I came across a machine called thinkpad x1 carbon gen 8
Looking to see if the function’s work I saw that it says TPM is unknown but all other features are YES
does this mean the TPM with proper BIOS support (required for [Anti Evil Maid] actually is not working meaning if lets say I got the machine that would mean only 6/7 features would work only? Is this laptop one that can disable the ME for no backdoor? maybe you know about this more then I do. or should I just get the laptop that we talked about previously t430with the upgrade CPU would it work smoothly if I want to do work a lot. Would this mean the machine ThinkPad X1 Carbon Gen 8 Is not Neutralized/Disabled Intel ME. This laptop actually the gen 5 was recommended by the qubes team from [Joanna Rutkowska
