Hello! I am having troubles connecting to my home wifi.
After installing qubes I had to remove the “force reset pci” setting from my internet controllers to be able to start my qubes. But now I can’t connect to my home wifi, although my phones hotspot works fine
Jun 08 00:53:31 sys-net NetworkManager[472]: <info> [1654642411.9874] device (wls6f0): supplicant interface state: disconnected -> interface_disabled
Jun 08 00:53:31 sys-net NetworkManager[472]: <info> [1654642411.9935] device (wls6f0): supplicant interface state: interface_disabled -> inactive
Jun 08 00:53:31 sys-net NetworkManager[472]: <info> [1654642411.9938] device (wls6f0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.0949] policy: auto-activating connection 'Hotspotb' (993524db-5eda-4c42-9466-acde5501dc28)
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.0953] device (wls6f0): Activation: starting connection 'Hotspotb' (993524db-5eda-4c42-9466-acde5501dc28)
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.0967] device (wls6f0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.0989] manager: NetworkManager state is now CONNECTING
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.1142] device (wls6f0): set-hw-addr: set-cloned MAC address to FF:FF:FF:FF:FF:FF (stable)
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.3152] device (wls6f0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.3157] device (wls6f0): Activation: (wifi) access point 'Hotspotb' has security, but secrets are required.
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.3157] device (wls6f0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.3235] device (wls6f0): supplicant interface state: inactive -> interface_disabled
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.3275] device (wls6f0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.3291] device (wls6f0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.3298] device (wls6f0): Activation: (wifi) connection 'Hotspotb' has security, and secrets exist. No new secrets needed.
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.3298] Config: added 'ssid' value 'Hotspotb'
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.3298] Config: added 'scan_ssid' value '1'
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.3298] Config: added 'bgscan' value 'simple:30:-70:86400'
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.3298] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256'
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.3298] Config: added 'psk' value '<hidden>'
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.3302] device (wls6f0): supplicant interface state: interface_disabled -> inactive
Jun 08 00:53:35 sys-net NetworkManager[472]: <info> [1654642415.3443] device (wls6f0): supplicant interface state: inactive -> scanning
Jun 08 00:53:38 sys-net NetworkManager[472]: <info> [1654642418.2441] device (wls6f0): supplicant interface state: scanning -> associating
Jun 08 00:53:38 sys-net NetworkManager[472]: <info> [1654642418.4272] device (wls6f0): supplicant interface state: associating -> associated
Jun 08 00:53:38 sys-net NetworkManager[472]: <info> [1654642418.4394] device (wls6f0): supplicant interface state: associated -> 4way_handshake
Jun 08 00:53:38 sys-net NetworkManager[472]: <info> [1654642418.4521] device (wls6f0): supplicant interface state: 4way_handshake -> completed
Jun 08 00:53:38 sys-net NetworkManager[472]: <info> [1654642418.4522] device (wls6f0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Hotspotb"
Jun 08 00:53:38 sys-net NetworkManager[472]: <info> [1654642418.4523] device (wls6f0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Jun 08 00:53:38 sys-net NetworkManager[472]: <info> [1654642418.4526] dhcp4 (wls6f0): activation: beginning transaction (timeout in 45 seconds)
Jun 08 00:53:38 sys-net NetworkManager[472]: <info> [1654642418.5246] dhcp4 (wls6f0): state changed unknown -> bound, address=192.168.43.19
Jun 08 00:53:38 sys-net NetworkManager[472]: <info> [1654642418.5262] device (wls6f0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Jun 08 00:53:38 sys-net NetworkManager[472]: <info> [1654642418.5428] device (wls6f0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Jun 08 00:53:38 sys-net NetworkManager[472]: <info> [1654642418.5430] device (wls6f0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Jun 08 00:53:38 sys-net NetworkManager[472]: <info> [1654642418.5434] manager: NetworkManager state is now CONNECTED_LOCAL
Jun 08 00:53:38 sys-net NetworkManager[472]: <info> [1654642418.5479] manager: NetworkManager state is now CONNECTED_SITE
Jun 08 00:53:38 sys-net NetworkManager[472]: <info> [1654642418.5482] policy: set 'Hotspotb' (wls6f0) as default for IPv4 routing and DNS
Jun 08 00:53:38 sys-net NetworkManager[472]: <info> [1654642418.5671] device (wls6f0): Activation: successful, device activated.
Jun 08 00:53:38 sys-net NetworkManager[472]: <info> [1654642418.5680] manager: NetworkManager state is now CONNECTED_GLOBAL
Jun 08 00:59:35 sys-net NetworkManager[472]: <info> [1654642775.7858] device (wls6f0): disconnecting for new activation request.
Jun 08 00:59:35 sys-net NetworkManager[472]: <info> [1654642775.7858] device (wls6f0): state change: activated -> deactivating (reason 'new-activation', sys-iface-state: 'managed')
Jun 08 00:59:35 sys-net NetworkManager[472]: <info> [1654642775.7860] manager: NetworkManager state is now DISCONNECTING
Jun 08 00:59:35 sys-net NetworkManager[472]: <info> [1654642775.7879] audit: op="connection-activate" uuid="1830d81c-c2fa-4dea-8c3a-98334276dc39" name="Area 51" pid=828 uid=1000 result="succ>
Jun 08 00:59:35 sys-net NetworkManager[472]: <info> [1654642775.8422] device (wls6f0): supplicant interface state: completed -> disconnected
Jun 08 00:59:35 sys-net NetworkManager[472]: <info> [1654642775.8426] device (wls6f0): state change: deactivating -> disconnected (reason 'new-activation', sys-iface-state: 'managed')
Jun 08 00:59:35 sys-net NetworkManager[472]: <info> [1654642775.8465] dhcp4 (wls6f0): canceled DHCP transaction
Jun 08 00:59:35 sys-net NetworkManager[472]: <info> [1654642775.8465] dhcp4 (wls6f0): state changed bound -> terminated
Jun 08 00:59:35 sys-net NetworkManager[472]: <info> [1654642775.8654] device (wls6f0): set-hw-addr: set MAC address to FF:FF:FF:FF:FF (scanning)
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.0965] manager: NetworkManager state is now DISCONNECTED
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.0992] device (wls6f0): Activation: starting connection 'Area 51' (1830d81c-c2fa-4dea-8c3a-98334276dc39)
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.1109] device (wls6f0): supplicant interface state: disconnected -> interface_disabled
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.1114] device (wls6f0): supplicant interface state: interface_disabled -> disconnected
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.1141] device (wls6f0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.1166] manager: NetworkManager state is now CONNECTING
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.1328] device (wls6f0): set-hw-addr: set-cloned MAC address to FF:FF:FF:FF:FF:FF(stable)
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.3350] device (wls6f0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.3362] device (wls6f0): Activation: (wifi) access point 'Area 51' has security, but secrets are required.
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.3366] device (wls6f0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.3394] device (wls6f0): supplicant interface state: disconnected -> interface_disabled
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.3422] device (wls6f0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.3441] device (wls6f0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.3452] device (wls6f0): Activation: (wifi) connection 'Area 51' has security, and secrets exist. No new secrets needed.
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.3454] Config: added 'ssid' value 'Area 51'
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.3455] Config: added 'scan_ssid' value '1'
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.3456] Config: added 'bgscan' value 'simple:30:-70:86400'
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.3457] Config: added 'key_mgmt' value 'SAE'
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.3458] Config: added 'auth_alg' value 'OPEN'
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.3459] Config: added 'psk' value '<hidden>'
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.3466] device (wls6f0): supplicant interface state: interface_disabled -> disconnected
Jun 08 00:59:36 sys-net NetworkManager[472]: <info> [1654642776.3564] device (wls6f0): supplicant interface state: disconnected -> scanning
Jun 08 00:59:39 sys-net NetworkManager[472]: <info> [1654642779.4226] device (wls6f0): supplicant interface state: scanning -> disconnected
Jun 08 01:00:01 sys-net NetworkManager[472]: <warn> [1654642801.2730] device (wls6f0): Activation: (wifi) association took too long, failing activation
Jun 08 01:00:01 sys-net NetworkManager[472]: <info> [1654642801.2731] device (wls6f0): state change: config -> failed (reason 'ssid-not-found', sys-iface-state: 'managed')
Jun 08 01:00:01 sys-net NetworkManager[472]: <info> [1654642801.2739] manager: NetworkManager state is now DISCONNECTED
Jun 08 01:00:01 sys-net NetworkManager[472]: <info> [1654642801.2915] device (wls6f0): set-hw-addr: set MAC address to FF:FF:FF:FF:FF:FF (scanning)
Jun 08 01:00:01 sys-net NetworkManager[472]: <warn> [1654642801.4946] device (wls6f0): Activation: failed for connection 'Area 51'
that should be a whole connection sequence. I have censored my mac address for general opsec.
I have tried to connect through the command nmcli and I get either “No network with SSID found” or “connection activision failed: (53) The WiFi network couldn’t be found”.
Of course the network is working as I have other clients connected and my network card is working as I have connected to my phones hotspot.
Any help is much appreciated!
