I am writing to ask for your help for my wifi connection issue.
It shows error when I installed and configured Qubes, saying;
"[’/user/bin/qvm-start’,‘sys-firewall’] failed:
stdout: “”
stderror: “Started failed: internal error: Unable to reset PCI device 0000:00:1f.6: no FLR, PM reset or bus reset available, see /var/log/libvirt/libxl-driver.log for details”
and it shows PCI problem and no wifi connection that:
1.All VMs, including NetVM cannot start because of PCI related to Ethernet
and
2.No wifi connection and Networkmanger is not shown in my NetVM settings and Applications.
I would greatly appreciate it if I could hear your advice to resolve this issue and configure my wifi connection.
Thank you fsch
I managed to resolve PCI pass through by configuring strict reset and now my NetVM works, but my wifi network connection is still disabled.
Could you advise me how I can go step further ?
Thank you deeplow, I managed to install Networkmanager.
But apparently Instill need to install NetworkManager-wifi.
When I tired it by “dnf install NetworkManager-wifi”, it returns me the error saying “This command has to be run with super user privileges (under the root user on most system)”
Could you advise me how I can install NetworkManager-wifi ?
Yes, you’ll have to connect to the internet via a cable (ethernet). Otherwise the only solution is to copy the file manually from another computer, which I don’t recommend (for security reasons).
It seems like there is a packaged missing in your installation (for some reason) and since that prevents you from using wifi, you’ll have to get it some other way first. After that, you may be able to get wifi working again.
