I’ve just noticed that the fedora-37 template has apache Apache/2.4.55 installed by default.
Is there a reason this is needed?
It is not needed and it is not installed by default.
It sure seems like it is. Am I doing something wrong then?
Dom0 terminal
$ sudo qubes-dom0-update qubes-template-fedora-37
Redirecting to 'qvm-template install fedora-37'
Downloading 'qubes-template-fedora-37-0:4.0.6-202302271646'...
qubes-template-fedora-37-0:4.0.6-202302271646: 100%|▉| 1.78G/1.78G [02:40<00:00,
Installing template 'fedora-37'...
fedora-37: Importing data
Opening terminal in fedora-37 template right after the above completes
$ httpd -v
Server version: Apache/2.4.55 (Fedora Linux)
Server built: Jan 25 2023 00:00:00
I’m curious. What does a search for the package show?
rpm -qa | grep httpd
[user@fedora-37 ~]$ rpm -qa | grep httpd
httpd-tools-2.4.55-1.fc37.x86_64
fedora-logos-httpd-36.0.0-3.fc37.noarch
httpd-filesystem-2.4.55-1.fc37.noarch
httpd-core-2.4.55-1.fc37.x86_64
httpd-2.4.55-1.fc37.x86_64
You are quite right, and I am a complete ass.
This only confirms that I am definitely not a Fedora, or Gnome, person.
dnf history httpd-core suggests that it may be pulled in as part of
some group - @networkmanager-submodules @gnome @printing?- is there some
gnomish way of configuring network or printing using a browser? I suspect
so, but I havent had enough sleep to do anything but weep.
Found the culprit: gnome-user-share
$ dnf repoquery --requires gnome-user-share
<SNIP>
Last metadata expiration check: 0:00:01 ago on Sun Mar 12 22:22:43 2023.
/bin/sh
httpd
libc.so.6(GLIBC_2.34)(64bit)
libgio-2.0.so.0()(64bit)
libglib-2.0.so.0()(64bit)
libgobject-2.0.so.0()(64bit)
libselinux.so.1()(64bit)
libselinux.so.1(LIBSELINUX_1.0)(64bit)
mod_dnssd
rtld(GNU_HASH)
Possibly something worth removing in future releases? I cant see it being beneficial to most people day to day
removing gnome-user-share also would remove,
apr x86_64 1.7.2-2.fc37 @updates 297 k
apr-util x86_64 1.6.3-2.fc37 @updates 217 k
apr-util-bdb x86_64 1.6.3-2.fc37 @updates 15 k
apr-util-openssl x86_64 1.6.3-2.fc37 @updates 24 k
fedora-logos-httpd noarch 36.0.0-3.fc37 @fedora 12 k
httpd x86_64 2.4.55-1.fc37 @updates 60 k
httpd-core x86_64 2.4.55-1.fc37 @updates 4.7 M
httpd-filesystem noarch 2.4.55-1.fc37 @updates 464
httpd-tools x86_64 2.4.55-1.fc37 @updates 202 k
julietaula-montserrat-fonts noarch 1:7.222-3.fc37 @fedora 4.2 M
mailcap noarch 2.1.53-4.fc37 @fedora 81 k
mod_dnssd x86_64 0.6-27.fc37 @fedora 62 k
mod_http2 x86_64 2.0.9-1.fc37 @updates 394 k
mod_lua x86_64 2.4.55-1.fc37 @updates 143 k
