I’ve already posted this in the Whonix forum, but since I’m not sure that it’s a Whonix problem, I’ll post it here again - I hope you’ll forgive me.
I’m also quite new to Qubes and Whonix, so please forgive my cluelessness.
I’ve recently (yesterday) updated the whonix-ws-16 (I think - it might’ve been the whonix-gw-16 too).
I’m not sure to which version, as I don’t know how to determine the currently installed versions.
Now everytime I start any Qube based on the Whonix-ws, I get legal information regarding Whonix, finishing with the info that a check will be run, which fails:
ERROR: check network interfaces Result: network interface eth0 not up!
Recommendation:
Try to manually start Whonix networking.
sudo systemctl restart networking
Or reboot.
Debugging information:
Command sudo --non-interactive cat /sys/class/net/eth0/carrier failed.
If this error happens only during upgrading or is transient this error can be safely ignored.
If you know what you are doing, feel free to disable this check. Create a file /etc/systemcheck.d/50_user.conf and add:
systemcheck_skip_functions+=" check_network_interfaces "
Also, when I try to start a Whonix template (either gw or ws), I get the following error:
ERROR: whonix_firewall failed to load!
The whonix_firewall failed to load for some reason. This could be due to the firewall being mis-configured or race-condition. Try restarting the VM to see if this error persists.
Failure file /run/anon-firewall/failed.status does not exist, ok.
output of sudo systemctl status whonix-firewall:
● whonix-firewall.service
Loaded: masked (Reason: Unit whonix-firewall.service is masked.)
Active: inactive (dead)
output of sudo journalctl --boot -u whonix-firewall:
-- Journal begins at Tue 2022-01-25 17:30:51 UTC, ends at Thu 2022-01-27 16:12:13 UTC. --
-- No entries --
To see this for yourself...
1. Open a terminal. (dom0 -> Start Menu -> Template: whonix-ws-16 -> Terminal)
2. Run.
2. Also see.
sudo journalctl --boot -u whonix-firewall | cat
3. Try to manually start Whonix firewall.
sudo whonix_firewall
systemcheck_skip_functions+=" check_whonix_firewall_systemd_status "
The following happens when trying to apply the suggestions:
- Manually start Whonix networking in WS-based Qube:
user@host:~$ sudo systemctl restart networking
Failed to restart networking.service: Unit networking.service is masked.
- Restarting / rebooting (anything): No difference
- Try to manually start Whonix firewall in template:
user@host:~$ sudo whonix_firewall
sudo: whonix_firewall: command not found
In case it’s helpful (it at least seems to contain some version numbers): Here’s the output of a verbose systemcheck on the qube based on whonix-ws-16:
user@host:~$ sudo systemcheck --verbose
[INFO] [systemcheck] EG | Whonix-Workstation | whonix-ws-16 TemplateBased AppVM | Thu 27 Jan 2022 08:26:46 PM UTCuser@host:~$ sudo systemcheck --verbose
[INFO] [systemcheck] Check sudo Result: OK
[INFO] [systemcheck] Whonix build version: 3:8.1-1
[INFO] [systemcheck] whonix-workstation-packages-dependencies-cli: 22.1-1
[INFO] [systemcheck] derivative_major_release_version /etc/whonix_version: 16
[INFO] [systemcheck] Whonix Support Status of this Major Version: Ok.
[WARNING] [systemcheck] Hardened Malloc: Disabled.
[INFO] [systemcheck] Spectre Meltdown Test: skipping since spectre_meltdown_check=false, ok.
[INFO] [systemcheck] Package Manager Consistency Check Result: Output of command dpkg --audit was empty, ok.
[INFO] [systemcheck] systemd journal check Result:
warnings:
failed:
Jan 27 20:11:00 host systemd[1]: apparmor.service: Failed with result 'exit-code'.
Jan 27 20:11:00 host systemd[1]: Failed to start Load AppArmor profiles.
Jan 27 20:11:00 host systemd-udevd[310]: eth0: Process '/usr/lib/qubes/setup-ip' failed with exit code 1.
Jan 27 20:13:28 host systemd[1]: qubes-sync-time.service: Failed with result 'exit-code'.
errors:
Jan 27 20:10:59 host kernel: ACPI Error: No handler or method for GPE 00, disabling event (20190816/evgpe-841)
Jan 27 20:10:59 host kernel: ACPI Error: No handler or method for GPE 01, disabling event (20190816/evgpe-841)
Jan 27 20:10:59 host kernel: ACPI Error: No handler or method for GPE 03, disabling event (20190816/evgpe-841)
Jan 27 20:10:59 host kernel: ACPI Error: No handler or method for GPE 04, disabling event (20190816/evgpe-841)
Jan 27 20:10:59 host kernel: ACPI Error: No handler or method for GPE 05, disabling event (20190816/evgpe-841)
Jan 27 20:10:59 host kernel: ACPI Error: No handler or method for GPE 06, disabling event (20190816/evgpe-841)
Jan 27 20:10:59 host kernel: ACPI Error: No handler or method for GPE 07, disabling event (20190816/evgpe-841)
Jan 27 20:11:00 host kernel: Error: Driver 'pcspkr' is already registered, aborting...
Jan 27 20:13:21 host systemd-xdg-autostart-generator[633]: Not generating service for XDG autostart app-qubes\x2dwhonixsetup-autostart.service, error parsing Exec= line: No such file or directory
denied:
ordering cycle:
1. Open a terminal. (dom0 -> Start Menu -> ServiceVM: EG -> Terminal)
2. Run. sudo journalctl --boot | grep -i warn
3. Run. sudo journalctl --boot | grep -i fail
4. Run. sudo journalctl --boot | grep -i error
5. Run. sudo journalctl --boot | grep -i denied
6. Run. sudo journalctl --boot | grep -i "ordering cycle"
systemcheck_skip_functions+=" check_journal "
[ERROR] [systemcheck] check network interfaces Result: network interface eth0 not up!
Recommendation:
Or reboot.
warnings:
failed:
errors:
denied:
ordering cycle:
Recommendation:
Or reboot.
Some more notes:
- I’ve done all the steps from the Whonix “Essential Connectivity Troubleshooting”, none helped.
- The network in another qube, which uses a whonix-gw-16 qube (e.g. sys-whonix) as network does work - so it’s clearly the workstation that has problems, isn’t it?
anon-infogives the following:
user@host:~$ anon-info
INFO: /etc/apt/sources.list.d/torproject.list does not exist.
INFO: version of the ‘tor’ package: 0.4.6.9-1~d11.bullseye+1
How can I resolve this issue? Or where can I find more information?
