Honestly, I don’t remember how it was before I restored my Whonix VMs (due to a crash I had to restore my old VMs). Now I have four templates:
Template: whonix-gw
Template: whonix-gw-15
Template: whonix-ws
Template: whonix-ws-15
Is this normal if yes why four instead of two (one workstation, one gateway)? Or can I just delete the VMs without numbers (like normal obsolete Template VMs)?
Hi @whoami,
there is the old-one and the new-one (restored) VM for each workstation and gateway, see the @Surf question and the @adw answer here.
I think the -15 is the new-one, but not sure, check before deleting!
But know I cannot launch the tor browser in the disposable whonix VM. It is simple not available the Qubes VM launcher menu but selected in the VM settings, Applications.
Hi @whoami,
did you try to launch the tor browser from a terminal (the command is torbrowser)? Just to check if it is present and works well… Then check the below documentations and report here which eventually failed:
As you can see in my last screenshot this is not my issue. It is listed in my Applications list - so it is Available and it is Selected. But when I want to launch it over the “Q” it is not displayed.
Yes, this works. I can start a disposable VM - terminal and launch torbrowser.
I just updated the torbrowser (via the whonix template VM) and this pops up:
Yes it’s same, except the Selected Applications which contains the default entries (chat Support, Thunar File Manager, Tor Browser (AnonDist), Tor Browser Downloader (AnonDist), WhonixCheck and Xfce Terminal).
Inside a dispvm instance, do you get the /usr/share/applications/janondisttorbrowser.desktop file?
user@host:~$ cat /usr/share/applications/janondisttorbrowser.desktop
## Copyright (C) 2012 - 2020 ENCRYPTED SUPPORT LP <adrelanos@riseup.net>
## See the file COPYING for copying conditions.
[Desktop Entry]
Exec=torbrowser %u
Type=Application
Name=Tor Browser (AnonDist)
GenericName=Privacy Browser
Comment=Start Tor Browser (AnonDist)
Categories=Network;
Icon=/usr/share/icons/anon-icon-pack/torbrowser.png
X-KDE-StartupNotify=false
Keywords=browser;privacy;Tor;
MimeType=text/html;text/xml;application/xhtml+xml;application/xml;application/vnd.mozilla.xul+xml;application/rss+xml;application/rdf+xml;image/gif;image/jpeg;image/png;x-scheme-handler/http;x-scheme-handler/https;
user@host:~$ dpkg -S /usr/share/applications/janondisttorbrowser.desktop
tb-starter: /usr/share/applications/janondisttorbrowser.desktop
If you don’t get the file, search in this direction.
Else, search how is build the menu entries in dom0, my menu entries:
If absent, you can add these files manually, but I think a Qubes command should be launch to rebuild your menu entries… Search in the documentation the required command, and if it works, give the solution here.
