Whonix Template Installation
Whenever I try to install the whonix templates via qvm-install, it shows them as 100% completed, however each template is 1 MB short?
If there was no error during the template installation, then it should be a visual bug. Maybe the progress bar is not updated after the last data chunk is downloaded or something like this.
