Whonix standalone VM is getting the green tick on update but the monero app does not update to latest version?
Hi @que. Welcome to the Qubes Community forum!
I’m no too familiar with monero, but perhaps also try this question at the whonix forum
It’s the Monero App version that doesn’t update.
If I make a new standalone VM based off whonix then the latest version is installed?
This is a Qubes update issue.
If you create a standalone machine from a template, then it is as up-to-date as the template was. You should try updating the standalone manually and see what it says (sudo apt update && sudo apt upgrade)
I see. I though the green tick was something on the monero interface.
Does the Qubes updater not update standalone vms properly?
If it shows the green
on the qubes-update, but it you then manually update the machine and there were also packages to update, then it may well be a bug.
Must be a bug.
Manual update also showing as nothing to do and Monero version is still outdated but up to date on fresh standalone template install?
