sporadically my sys-whonix (whonix-gw-16) CPU utilization goes to 90+% (as reported in the list of running qubes from the task bar) and becomes completely unresponsive.
Top in dom0 reports that IRQ/114-ACPI:Ev uses around 50% CPU.
The reported overall CPU utilization from the task manager is around 35-45% while normally idling around 1%.
When emergency pausing sys-whonix, it goes back to normal idling utilization. (The dip in the graph)
Is this a problem with qubes or whonix? How would i trouble shoot this best?
What kernel version do you have in sys-whonix?
It is on: Linux 5.10.71-1.fc32.qubes.x86_64 x86_64
Hmm, then I’m not sure. There was similar issue in 5.10.70, but should be fixed in 5.10.71. You can try updating to 5.10.76 (just update dom0 from current-testing repo), but I doubt it will help much.
When this happens, can you run top in sys-whonix to see what is it doing?
I will let a terminal with top running an wait for the next freeze. Good idea!
It is kswapd0 that uses much cpu.
Memory is full, nyx seems to have a memory leak and consumed over a GB RAM…
