I haven’t been able to get Whonix Gateway to update for a few days now.
In the Updater gui Details, it tells me to run sudo dpkg --configure -a. I’ve done this twice now with restarts inbetween, and its not fixing it.
Details from Updater
Updating whonix-gateway-17
Refreshing package info
Refreshing available packages.
Refreshed.
E:dpkg was interrupted, you must manually run ‘dpkg --configure -a’ to correct the problem.
Installed packages:
None
Updated packages:
None
Removed packages:
None
Hit:1 tor+https://deb.debian.org/debian bookworm InRelease
Hit:2 tor+https://deb.kicksecure.com bookworm InRelease
Hit:3 tor+https://fasttrack.debian.net/debian-fasttrack bookworm-fasttrack InRelease
Hit:4 Index of /r4.2/vm/ bookworm InRelease
Hit:5 tor+https://deb.whonix.org bookworm InRelease
Hit:6 tor+https://deb.debian.org/debian bookworm-updates InRelease
Hit:7 tor+https://fasttrack.debian.net/debian-fasttrack bookworm-backports-staging InRelease
Hit:8 tor+https://deb.debian.org/debian-security bookworm-security InRelease
Hit:9 tor+https://deb.debian.org/debian bookworm-backports InRelease
Reading package lists…
Building dependency tree…
Reading state information…
Calculating upgrade…
The following packages were automatically installed and are no longer required:
auditd deborphan hardened-malloc iptables libauparse0 libip6tc2 libopenjp2-7
libwpe-1.0-1 libwpebackend-fdo-1.0-1 python3-daemon python3-lockfile
Use ‘apt autoremove’ to remove them.
The following packages will be upgraded:
libjxl0.7 libqubesdb python3-qubesdb qubesdb qubesdb-vm sudo
6 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
30 not fully installed or removed.
Inst python3-qubesdb [4.2.8-1+deb12u1] (4.2.9-1+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Inst libqubesdb [4.2.8-1+deb12u1] (4.2.9-1+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Inst qubesdb [4.2.8-1+deb12u1] (4.2.9-1+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Inst qubesdb-vm [4.2.8-1+deb12u1] (4.2.9-1+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Inst sudo [1.9.13p3-1+deb12u1] (1.9.13p3-1+deb12u2 Debian-Security:12/stable-security [amd64])
Inst libjxl0.7 [0.7.0-10] (0.7.0-10+deb12u1 Debian-Security:12/stable-security [amd64])
Conf python3-qubesdb (4.2.9-1+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Conf libqubesdb (4.2.9-1+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Conf qubesdb (4.2.9-1+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Conf qubesdb-vm (4.2.9-1+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Conf sudo (1.9.13p3-1+deb12u2 Debian-Security:12/stable-security [amd64])
Conf libjxl0.7 (0.7.0-10+deb12u1 Debian-Security:12/stable-security [amd64])
Conf qubes-core-qrexec (4.2.24-1+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Conf libqrexec-utils2 (4.2.24-1+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Conf xserver-xorg-video-dummyqbs (4.2.21-1+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Conf libblockdev-part2 (2.28-2+deb12u1 Debian-Security:12/stable-security [amd64])
Conf libblockdev-swap2 (2.28-2+deb12u1 Debian-Security:12/stable-security [amd64])
Conf xserver-xorg-core (2:21.1.7-3+deb12u10 Debian-Security:12/stable-security [amd64])
Conf xserver-xorg-input-qubes (4.2.21-1+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Conf gir1.2-gdkpixbuf-2.0 (2.42.10+dfsg-1+deb12u2 Debian-Security:12/stable-security [amd64])
Conf libblockdev-fs2 (2.28-2+deb12u1 Debian-Security:12/stable-security [amd64])
Conf udisks2 (2.9.4-4+deb12u1 Debian-Security:12/stable-security [amd64])
Conf libgdk-pixbuf-2.0-0 (2.42.10+dfsg-1+deb12u2 Debian-Security:12/stable-security [amd64])
Conf libxml2 (2.9.14+dfsg-1.3~deb12u2 Debian-Security:12/stable-security [amd64])
Conf libqubes-pure0 (4.2.20+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Conf libudisks2-0 (2.9.4-4+deb12u1 Debian-Security:12/stable-security [amd64])
Conf libblockdev-loop2 (2.28-2+deb12u1 Debian-Security:12/stable-security [amd64])
Conf libqubes-rpc-filecopy2 (4.2.20+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Conf libgstreamer-plugins-bad1.0-0 (1.22.0-4+deb12u6 Debian-Security:12/stable-security [amd64])
Conf xserver-common (2:21.1.7-3+deb12u10 Debian-Security:12/stable-security [all])
Conf libblockdev2 (2.28-2+deb12u1 Debian-Security:12/stable-security [amd64])
Conf libblockdev-part-err2 (2.28-2+deb12u1 Debian-Security:12/stable-security [amd64])
Conf libblockdev-utils2 (2.28-2+deb12u1 Debian-Security:12/stable-security [amd64])
Conf python3-qrexec (4.2.24-1+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Conf ca-certificates (20230311+deb12u1 Debian:12-updates/stable-updates [all])
Conf qubes-gui-agent (4.2.21-1+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Conf qubes-utils (4.2.20+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Conf libblockdev-crypto2 (2.28-2+deb12u1 Debian-Security:12/stable-security [amd64])
Conf libicu72 (72.1-3+deb12u1 Debian-Security:12/stable-security [amd64])
Conf xserver-xorg-qubes-common (4.2.21-1+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Conf qubes-kernel-vm-support (4.2.20+deb12u1 Qubes Debian:deb.qubes-os.org [amd64])
Conf libgdk-pixbuf2.0-common (2.42.10+dfsg-1+deb12u2 Debian-Security:12/stable-security [all])
