I should provide an update to this.
I contacted GPD. They said their manufacturing partners did the manufacturing runs with the 7265 by mistake (apparently the modules were mistakenly soldered because they look very similar). They have already sent out an AX201 module for me to solder myself (I don’t mind doing a bit of soldering). The other option was to ship my laptop back to Shenzhen, and they do it, But that would mean I didn’t have a laptop for a few weeks… They did this for free, too.
So it’s definitely not a scam, and they were pretty good about fixing it.
Well, then you should use what you’re comfortable using…
It future-proofs the hardware to a certain extent. The difference between Wifi 5 (3.5gbps) and Wifi 6 (9.6bps) is MASSIVE. The max bandwidth is usually greater than most residential internet connections, so you generally won’t notice any benefit if you’re accessing something outside your LAN (your internet connection is your bottleneck).
But when your Wifi is faster than your Ethernet (that should be a meme), you really notice the difference when doing network backups, streaming 4k/8k media from within your LAN, using sshfs
, etc.
