What's the easiest way to enable and benefit from zram with debian templates?
On fedora templates I can get zram easily enabled using:
dnf install zram zram-generator zram-generator-defaults
And after restarting the VMs zram is enabled.
But there doesn’t seem to be a similar equivalent for debian templates. So what’s the easiest way to enable and benefit from zram with debian templates?
sudo apt install systemd-zram-generator?
The easiest seems to be zram-tools:
sudo apt install zram-tools
Then you just edit /etc/default/zram-swap (if you want to change anything from the default values) and it’s on.
