Does this default Qube have a special function? Can I delete it?
Thank you.
Thank you.
Where are you seeing this?
under the Q on the top left of the screen. Start menu? When I drop it down there are a bunch of preisntalled Qubes, templates.
There is no preinstalled qube called “Proxy” on my machine.
I may be mistaken. Its possible I created it when experimenting with proxys and I dont remember. Thanks for your reply.
