what does the --gui and --nogui option do in qvm-run? i can’t find an explanation to what “gui forwarding” means in qubes os.
qvm-run with --gui (the default) waits for the VM to become ready to launch graphical programs. With --nogui that’s not guaranteed to work if qvm-run has just started the VM: It might run the program too early in this case.
qubes-gui and qubes-guid processes All AppVM X applications connect to local (running in AppVM) Xorg servers that use the following “hardware” drivers: dummyqsb_drv - video driver, that paints onto a framebuffer located in RAM, not connected to real...
Also, if the VM has no guivm (headless, like stripped of its installation of X, terminal access only through “Open console in qube” / qvm-console-dispvm) then --no-gui is mandatory, every qvm-run call will stall and time out otherwise.
Atrate
September 7, 2025, 7:16pm
5
Exactly. This has been reported in this Github issue:
opened 03:51PM - 20 Feb 25 UTC
C: core
P: default
needs diagnosis
affects-4.2
### Qubes OS release
Qubes OS 4.2
### Brief summary
I have qubes with the `gu… i` feature disabled, but `qvm-run --gui` (default is to use GUI), waits indefinitely when I try to open a GUI application. It does not print stdout or stderr, but waits for the session first, therefore not even returning if the command failed.
### Steps to reproduce
1. `qvm-features disp-sys-usb gui ''`
2. `qvm-start disp-sys-usb`
3. Try to run commands that require a GUI
$ qvm-run -p -- disp-sys-usb xterm
^C%
$ qvm-run -p --no-gui -- disp-sys-usb xterm
xterm: Xt error: Can't open display: :0
### Expected behavior
1. Don't wait for GUI when `gui` feature is disabled.
2. Exit when subprocess terminates
### Actual behavior
Waits for GUI even though it doesn't have one.
### Additional information
I don't how it should consider also `gui-emulated` or emulated VGA.
It also completely breaks the r4.3 upgrade tool if the UpdateVM has no GUI:
opened 06:08PM - 11 Aug 25 UTC
P: default
needs diagnosis
C: dist upgrade
affects-4.2
Qubes OS 4.2
### Brief summary
Line 72 in `qubes-dist-up… grade-r4.3.sh`:
update_prechecks() {
echo "INFO: Please wait while running pre-checks..."
if qvm-check -q "$updatevm" 2>/dev/null; then
if ! qvm-run -q "$updatevm" "command -v dnf"; then
echo "ERROR: UpdateVM ($updatevm) should on a template that have 'dnf' installed - at least Fedora 37, Debian 11, or Whonix 16."
exit 1
fi
fi
The `qvm-run` call has an implied `--gui` flag, which causes it to hang indefinitely when the UpdateVM has the GUI feature disabled. Caused by: #9789
1. Try to upgrade to `r4.3-rc1` with the UpdateVM set to a Qube that has the `gui` feature set to `''` (e.g. `sys-firewall`, which many people disable the GUI for)
Works.
### Actual behavior
Hangs indefinitely on `INFO: Please wait while running pre-checks...`
_No response_
