Yeah but if you cloned the same qube, they might have the same session, which can make troubles. Try to logout and login in each to “separate them”.
You’re welcome. It’s actually an issue I had when I worked for a VPN company and I discovered this kind of issue, which makes sense when you figure how the app is working.
I’ve also cloned my proton vpn vm (didn’t used guide tho) but each one required to login to proton account separately. But my vpn vm is done on template not on standalone.
