Vmware workstation on Qubes ? VT-x error
Hello,
I have build a StandaloneVM and I have installed on it my VMWare workstation.
All are working.
After this, I have installed Kali as VM in my VMware workstation … When trying to run it, I have : this host doesn’t support VT-x
I think the host cannot share the VT-x or something similar … If this is the case, what is the best way, in my Qubes laptop, to make working this type of config ??
Thx
You can’t run it. Xen doesn’t support nested virtualization, so you can’t run any VM inside your VM.
Yep thx, I am installing it through his ISO
