When I installed Qubes, I wanted Qubes to only take up a certain percentage of the drive. I did that, with luks encryption, which took a while to figure out.
Unfortunately varlib-qubes is very large and vm-pool is very small. Somehow these got messed up. I also now have data in this other partition.
There is not that much important to me within the current Qubes install and I could reinstall if needed, but I don’t even understand why that’s necessary and why I can’t change partition names or do things within what I currently have.
I also tried to reload backed up Qubes and that’s when this problem started
and when I learned I installed it wrong, apparently.
I forget what I did during the install, but I wanted Luks2 and I also wanted a fourth partition that was not part of the Qubes operating system. To do this, I had to do things manually and apparently did not do this correctly.
Is there any solution other than a reinstall and if I do reinstall, is there any way to do this without over-writing the 4th partition that already has data?
