VirtualGL to sys-gpu over qrexec?
I was thinking about a better alternative to sr-iov (and I also hear that VirtualGL is baaaad for security) but.. I think this architecture can make tradeoffs known and controllable. First, gpu is no longer dom0, and it is better than raw sr-iov or gpu passthrough already. Second, everything bad that happens has a blast radius limited to VirtualGL clients, you may opt out your maximum security qubes from this. Third, it is entirely application layer, you may “firewall” bad requests if the attack pattern is known.
Actually that was the idea behind my old project. But I’d watch VirtIO-GPU is coming to Qubes OS :: Qubes OS Summit 2026 :: pretalx before thinking about reviving it :wink:
I did! But it is not going to land earlier than Wayland does.. So yes, it is definitely worth reviving. Dependency on hw rendering only got worse in desktop software, especially browser/electron.
Is qrexec as a comms channel fast enough for such latency and throughput-sensitive tasks as are common with GPUs?
