The downloaded iso could be verified. Is there any way to verify the USB stick that I restored that iso file to?
Recently added this section:
Thank you
If you use their website without a proxy “YOU are Suicidal”
https://cryptcheck.fr/https/www.qubes-os.org
The grade is F and not from FABULOUS!
The keyserver is crap… and so on. I can fill this forum with problems but it is not constructive. Use chips.de that sinks your time with java script or some dudes that know what they are doing. These guys just talk crap… Your ONLY defense is to customize with your own templates!
If you download torrent not to using Tribler or Sparky (torlock) you need a shrink for sure!
I paste the latest test:
[HTTPS] www.qubes-os.org (07/08/2022 14:36:06 +00:00)
F 2606:50c0:8002::153 : 443 (www.qubes-os.org)
Name Key exchange Authentication Encryption MAC PFS
Type Key size Block size Mode Type Size
TLSv1_2
ECDHE-RSA-AES128-GCM-SHA256 ECDH RSA AES 128 128 GCM SHA256 256 PFS
ECDHE-RSA-AES256-GCM-SHA384 ECDH RSA AES 256 128 GCM SHA384 384 PFS
ECDHE-RSA-CHACHA20-POLY1305 ECDH RSA CHACHA20 256 stream AEAD POLY1305 128 PFS
ECDHE-RSA-AES128-SHA256 ECDH RSA AES 128 128 CBC SHA256 256 PFS
ECDHE-RSA-AES256-SHA384 ECDH RSA AES 256 128 CBC SHA384 384 PFS
ECDHE-RSA-AES128-SHA ECDH RSA AES 128 128 CBC SHA1 160 PFS
ECDHE-RSA-AES256-SHA ECDH RSA AES 256 128 CBC SHA1 160 PFS
AES128-GCM-SHA256 RSA RSA AES 128 128 GCM SHA256 256 No PFS
AES128-SHA RSA RSA AES 128 128 CBC SHA1 160 No PFS
AES256-SHA RSA RSA AES 256 128 CBC SHA1 160 No PFS
F 2606:50c0:8000::153 : 443 (www.qubes-os.org)
TLSv1_2
F 2606:50c0:8003::153 : 443 (www.qubes-os.org)
TLSv1_2
F 2606:50c0:8001::153 : 443 (www.qubes-os.org)
TLSv1_2
F 185.199.108.153 : 443 (www.qubes-os.org)
TLSv1_2
F 185.199.110.153 : 443 (www.qubes-os.org)
TLSv1_2
F 185.199.111.153 : 443 (www.qubes-os.org)
TLSv1_2
F 185.199.109.153 : 443 (www.qubes-os.org)
TLSv1_2
https://www.qubes-os.org/faq/#should-i-trust-this-website
https://www.qubes-os.org/faq/#why-doesnt-this-website-have-security-feature-x
Also, the source code of the entire website is available here:
You can simply download the repo and read the website locally on your private, offline machine, if you wish.
