I installed Qubes on a partition.
I did this because Qubes has had so many problems with this machine that I wanted to use it for a while prior to just making it a daily driver.
I ran into this problem before and last time was told the install must just be corrupt, so I waited and finally just installed again. I created the system directories and then there were two partitions I could make larger. One was the swap, I didn’t make that larger. One was just the regular partition for Qubes and I made that larger. I’m having the same problem with vm-pool full again and this took so long to set up everything with the flatpak stuff and trying to get different drivers working.
It’s going to take another 10 hours to reinstall everything. Why is this happening in the custom manual install?
The solution last time was just reinstall everything. I don’t see why I can’t make vm-pool larger and varlibqubes smaller, and I was never given options for sizes during the install. I also redownloaded the iso and checked the hash, nothing was corrupt.
I’m on the verge of just not running Qubes anymore. Things like this happen so much.
