i was using qubes for a while until my system “went bad” so i did a reinstall. In the reinstall i noticed, that my circuits only use one guard and there is no “show vanguard logs” entry in the start menu as it used to be. After a short inspection i figured, that vanguards isn’t installed in the whonix-gw-15.
So this raises a question for me:
Was vanguards even installed in my first installation?
If so: Why isn’t it in the new installation?
I kinda like the vanguards concept and would love to have it installed. If someone has a quick instruction on how to set it up, that would be great. Otherwise i think i will figure it out and write one myself.
Tahnks for You help!
