Hallo community,
How can I set up my template VMs with UTF-8 encoding? Or am I wrong and this is not an encoding problem?
Here are two examples.
First examle: If I send a text file named “µ-size” via qvm-open-in-dvm then firefox opens it and shows as result in the URL bar this:
file:///tmp/disp9777-aKJjL2/�-size
If I jump to the path “file:///tmp/disp9777-aKJjL2/” and open the file, then this is the result: “lenght: 10 痠” instead of “lenght: 10 µm”
Second example: If I execute ls -la to see the file in the directory then this is the result:
-rw-r--r-- 1 user user 15 May 24 14:08 ''$'\265''-size'
What should I configure in my VMs to avoid this situation?
Thanks in advance for your help.
