/usr/sbin/meminfo-writer missing (fedora41)
after boot this morning (i power down each evening) I got the usual notification that fedora41 template had updates, and started the update.
fedora41 result:
dom0 check:
the nature of the missing file has me concerned.
i’m very much a vanilla qubes user. i don’t mess around with the environments. i avoid installing anything outside the delivered repos.
any thoughts?
A quick search on the forum for meminfo-writer, landed me on:
– it’s mentioned for r4.3 and Fedora 42, but maybe it somehow was also moved on r4.2?
:slight_smile:
thanks for the reply.
i searched on the full path name, so didn’t see that one.
those changes related to meminfo-writer date back to march. why a problem today? i do my updates as soon as i see them come in.
just for the f of it i tried launching the fedora41 update a second time this morning:
Updating fedora-41
ls: cannot access ‘/usr/sbin/meminfo-writer’: No such file or directory
Refreshing package info
Fetching packages:
alsa-sof-firmware-2025.05-1.fc41.noarch.rpm: Fetched
Updating packages.
alsa-sof-firmware-2025.05-1.fc41.noarch: Upgrade
alsa-sof-firmware-2025.01.1-1.fc41.noarch: Upgraded
Updated
Installed packages:
None
Updated packages:
alsa-sof-firmware 2025.01.1-1.fc41 → 2025.05-1.fc41
Removed packages:
None
Hi t0t0
I’m only guessing – a proper answer is beyond my knowledge of the system … maybe someone else will see the topic and can share the “why”.
:slight_smile:
This is why:
It is used to check the meminfo-writer SELinux label, but as you noticed, it’s not there anymore since it was moved.
The new /usr/bin path was added in version 4.3, but it was not backported to version 4.2, which is causing the error:
One of the Fedora 42 changes was unifying /usr/sbin and /usr/bin directories (more information here). Some of the Qubes OS utilities had to be relocated from the former directory to the latter.
Look into /usr/bin directory. The meminfo-writer should have been relocated there.
The patches goes through thorough testing. It might take weeks or even months until they are delivered to stable branch.
Times flies. It was like yesterday.
so, the update process is looking in the wrong place. i don’t have control over that. or do I?
Unless you’re having issues with SELinux labels, consider this line a harmless warning.
You can still fix this manually by editing /usr/lib/python3.11/site-packages/vmupdate/agent/source/plugins/fix_meminfo_writer_label.py in dom0 and by replacing /usr/sbin to /usr/bin in the meminfo_path variable.
thanks for the info.
