I opted-in for updating Dom0 using Whonix when installing Qubes OS. I used to update Dom0, but for a while now, I haven’t been receiving updates. I had some issues which is fixed now I suppose. Nonetheless, when I update via Terminal, neither does it give an error message, nor an update. What I need to know is whether not receiving an update for a few months is usual.
I believe Dom0 does not need that much of an update as stated in the website, but I am skeptical about my system’s issue being solved.
TL;DR was there any updates for Dom0 (onion repo, stable) in the last few months?
These are the outputs; it rarely gives the former one, usually the latter. Native Qubes updater gives a green tick, but it does not update anything as far as I can see.
[user@dom0 ~]$ sudo qubes-dom0-update
Using sys-whonix as UpdateVM to download updates for Dom0; this may take some time…
Error: Cannot retrieve repository metadata (repomd.xml) for repository: fedora. Please verify its path and try again
fedora/metalink | 5.8 kB 00:00
fedora | 4.3 kB 00:00
fedora/primary_db | 26 MB 01:30
qubes-dom0-current | 3.8 kB 00:00
qubes-dom0-current/primary_db | 728 kB 00:01
qubes-templates-itl/metalink | 2.6 kB 00:00
qubes-templates-itl | 3.0 kB 00:00
qubes-templates-itl/primary_db | 7.2 kB 00:00
updates/metalink | 5.4 kB 00:00
updates | 4.7 kB 00:00
updates/primary_db | 12 MB 00:27
No Match for argument
Nothing to download
No new updates available
No updates available
