The easy way was to use Qubes menu->Settings->System Settings->keyboard and add a shortcut to xfce4-screenshooter -r.
As a new user, I am not yet in a position to update what I donât know how to do. I certainly can point out the areas that are no longer accurate. From my experience as a professional developer, the documentation needs the skills of a technical writer.
FWIW, if there was a QA person, they would have already have submitted tickets about all the issues in the documentation. Most like one that reads - âupdate documentation in all areas affected by changes to 4.2, but especially screen capturesâ.
@SteveC Usability encompasses the entire user experience of a product. Its about being able to use a product to get a task done. Weâve all bought products that have poorly written or incorrect instructions, and found the experience frustrating. In some cases, so frustrating we gave up and returned it to the store. I know that is what I did with Qubes 3.2.
In my case, being able to use an external mouse as opposed to the track pad of my laptop makes the laptop much more usable. For some users with mobility issues, carpal tunnel, etc. external mouse and or keyboard are not just nice to have but essential.
Sadly, when I initially installed Qubes, I chose poorly. (Raiders of the Lost Ark reference) I am very glad that Qubes allows me to change my mind (+ for usability). It was hard to discover where to make that change, either in the documentation or in this forum due to conflicting answers (- for usability).
I am doggedly working my way through issues. Iâll (re)read the docs, ask questions, try things. And hopefully I can give back to the community, either by documenting what I find, pointing out errors or omissions in the document, or maybe point out options that would make the use of Qubes easier for ALL levels of technical expertise. Iâm sure there are plenty of folk that need better security but donât have technical expertise.
This whole thing with mice and keyboards often makes an enormous difference. Most desktop machines these days require a USB keyboard and mouse; installing sys-usb the wrong way will basically lock you out of your machine. I am one of those who wants a mouse even on a laptop (itâs not a need in my case, but a strong desirement). Fortunately if sys-usb crashes or doesnât work for whatever reason on the laptop I can run in degraded mode (keyboard + touchpad), long enough to make sure sys-usb doesnât start up the next time I reboot. (Itâs easy enough to do that, if you are in Qubes OS rather than stuck with a password prompt that doesnât see your keystrokes!)
Iâm very glad this is now controllable via a GUI (as are the update proxy settings). Doing things the old way is still supported but it will âbreakâ the GUI. (And thatâs great for right after an upgrade to 4.2âif you upgraded in place, the files that controlled it before are controlling it now and your settings donât get lost. But that doesnât mean itâs meant to be a permanent solution!) But I donât think anyone wants to break the GUI long term.
I do a LOT of things on the command line, but when I canât remember a command [and youâll have noticed many command lines are arcane, and if you havenât yet noticed you eventually will notice that a lot of things on a Linux system (not just on QubesOS) are configured in a file with God-and-Google knows what name, sitting in God-and-Google knows what directory], I like to fall back on a GUI. And I like to launch applications via a GUI, too, even if itâs just double clicking on a file or a shortcut. (Iâve set up a zillion desktop shortcuts to start qubes, run an app on a qube, and so forth.) But thatâs me. I know of people here who will use a keyboard shortcut for absolutely everything; and others who are utterly dependent on a GUI.
I totally agree. I have used Emacs for decades, and I have muscle memory for lots of common operations. The rest I use the mouse and menu for, or lookup the Emacs command to run. I worked with another developer who swore by the keyboard shortcuts, and knew way more of them than I do.
Iâm trying to be pragmatic with Qubes. If it is easy to customize it to make it fit my style of work, I will do it. If it is very hard, and I can work around the lack, I will. Worst case, I can switch over to my Windows 11 or Linux Mint laptops.
BTW, after enabling the mouse, I dug up a wireless mouse and dongle. The wire on the wired mouse was annoying to me. The wireless mouse works well, though I do get some âkeyboard deniedâ warnings - I assume the dongle also supports a wireless keyboard as well.
The most customizable configuration of QubesOS is to enable KDE instead of the xfce desktop.
I came to QubesOS from xubuntu which uses xfce, so the default setup fit me like an old shoe, but the 4.1 menu was really unsuitable and that motivated me to look into KDE (which, I believe used to be the default, a few versions ago).
Hereâs info to get you started should you decide to pursue this (and it can be undone):
The update to the XFCE menu in 4.2 made it a lot easier to work with. There are separate sub-menus for accessing specific qubes vs system-wide (dom0) actions, and the qube submenus are divided into 3 tabs for AppVMs, Templates, and Services (sys-*).
Not trying to dissuade you from KDE, I just think this is worth mentioning as it improves âusability for the non-technical userâ on a default installation. ![]()
@SteveC I am not ready to change window managers. Iâd rather stick with the stock one since:
a) it is stock
b) it is what is shown in the documentation (more or less)
c) an easy solution to my issue was available that didnât require the larger change
In addition to my personal interest in Qubes, I am also writing for a class I am taking (for fun) where I plan on evaluating the Qubes experience out of the box. I.e. how easy is it to work with, configure, customize, etc. I think a window manager change would be a higher bar for many users, esp. ones coming from Windows.
@skyvine - definitely agree. The less changes a new user has to make to become productive, the higher the usability in my opinion.
Thatâs entirely true, and I am glad you brought it up.
When I upgraded my laptop to 4.2, switching to KDE was the very last thing I did after a few iterations before I felt like I had automated all my customizations, As such I got re-acquainted with xfce and got to use the new menu. It was a vast improvement over 4.1!
It didnât do enough for me, because it didnât make some distinctions (like between templates and disposable templates) that I want made. Also, Iâm one of those oddball types with dozens of VMs and I need more granularity.
But it was a HUGE step forward even so.
Trying to get everyone onto KDE whether or not its best for them certainly isnât my goal, but I certainly do think that some users may find it more usable. So I mentioned it.
Agreed for your purposes KDE wouldnât be a good thing. In fact, I hesitate to demo Qubes to people, because my system wouldnât look recognizable as compared to the default installationâIâd be showing them something they wonât get. (Maybe I should install, bone stock, to a thumbdrive/memory stick for âlive bootâ purposes. In fact, thatâs how I demoed it to myselfâŚthe first machine I tried to install 4.1 to, the installer and QubesOS itself couldnât see my disk drives. I ran off a thumb drive long enough to know I wanted this enough to justify buying a new machine to put it on.)
Does the attack surface increase using KDE?
Thanks for replying
as long as itâs on dom0 that shouldnât change anything with regards to security
