mjanna
August 29, 2025, 6:23pm
1
I need help!
I was in the middle of my working and my OS just got stuck while I was switching windows with alt + tab!
I unplugged my external monitor and plugged it in and everything is black now!!!
The bluetooth mouth is responsive.
I have unsaved work!
Can I do something?!!
Try to switch to another tty e.g. using Ctrl+Alt+F2 (default tty is Ctrl+Alt+F1).
mjanna
August 29, 2025, 6:44pm
3
OK!
ctrl + f1 got me into terminal? What do I do here???
mjanna
August 29, 2025, 6:56pm
4
I think I should be able to type in that TTY? Because I canβt!
mjanna
August 29, 2025, 6:59pm
5
OK! I switched to third TTY and logged in!
What do I do now?
mjanna
August 29, 2025, 7:03pm
6
I GOT IT! Prolem solved!!!
ChrisA
August 29, 2025, 7:06pm
7
Hi mjanna
Nice that your problem is solved!
To help people in the future, can you write a bit about what you noticed, where you looked and how you solved the problem?
With a summary of the steps you took, you should mark that message as the solution to the problem.
