We have updated Qubes Security Bulletin 090: Zenbleed (CVE-2023-20593, XSA-433). The text of this updated QSB (including a changelog) and its accompanying cryptographic signatures are reproduced below. For an explanation of this announcement and instructions for authenticating this QSB, please see the end of this announcement.
---===[ Qubes Security Bulletin 090 ]===---
2023-07-24
Changelog
2023-07-24: Original QSB published
2023-08-01: Updated Xen packages with upstream bug fix (XSA-433 v3 [3])
User action required
Users must install the following specific packages in order to address
the issues discussed in this bulletin:
For Qubes 4.1, in dom0:
- linux-firmware 20230625-146
- Xen packages 4.14.5-22
For Qubes 4.2, in dom0:
- linux-firmware 20230625-147
- Xen packages 4.17.1-4
by the community. [1] Once available, the packages are to be installed
via the Qubes Update tool or its command-line equivalents. [2]
effect.
passphrase to new PCR values, as PCR18+19 will change due to the new
Xen and initramfs binaries.
Summary
On 2023-07-24, the Xen Project published XSA-433, "x86/AMD: Zenbleed"
[3]:
| Researchers at Google have discovered Zenbleed, a hardware bug causing
| corruption of the vector registers.
| When a VZEROUPPER instruction is discarded as part of a bad transient
| execution path, its effect on internal tracking are not unwound
| correctly. This manifests as the wrong micro-architectural state
| becoming architectural, and corrupting the vector registers.
| Note: While this malfunction is related to speculative execution, this
| is not a speculative sidechannel vulnerability.
| The corruption is not random. It happens to be stale values from the
| physical vector register file, a structure competitively shared between
| sibling threads. Therefore, an attacker can directly access data from
| the sibling thread, or from a more privileged context.
| For more details, see:
| https://www.amd.com/en/resources/product-security/bulletin/amd-sb-7008.html
| https://github.com/google/security-research/security/advisories/GHSA-v6wh-rxpg-cmm8
Impact
As explained in XSA-433, this vulnerability is specific to the AMD Zen 2
microarchitecture, and AMD does not believe that other
microarchitectures are affected. Exploiting this vulnerability would
allow an attacker to read data from different contexts on the same core.
Examples of such data include key material, ciphertext and plaintext
from AES-NI operations, and the contents of REP-MOVS instructions, which
are commonly used to implement `memcpy()`.
In order to exploit this vulnerability, an attacker must be capable of
executing code at any privilege level in any qube, e.g., JavaScript in a
web browser. Moreover, the code to reliably exploit this vulnerability
is publicly available. Accordingly, there is a high risk of this
vulnerability being exploited in practice.
Credits
Tavis Ormandy of Google Project Zero.
References
[1] https://www.qubes-os.org/doc/testing/
[2] https://www.qubes-os.org/doc/how-to-update/
[3] https://xenbits.xen.org/xsa/advisory-433.html
The Qubes Security Team
Source: https://github.com/QubesOS/qubes-secpack/blob/main/QSBs/qsb-090-2023.txt
Marek Marczykowski-Górecki’s PGP signature
-----BEGIN PGP SIGNATURE-----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=gT88
-----END PGP SIGNATURE-----
Source: https://github.com/QubesOS/qubes-secpack/blob/main/QSBs/qsb-090-2023.txt.sig.marmarek
Simon Gaiser (aka HW42)’s PGP signature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=omf2
Source: https://github.com/QubesOS/qubes-secpack/blob/main/QSBs/qsb-090-2023.txt.sig.simon
What is the purpose of this announcement?
The purpose of this announcement is to inform the Qubes community that a new Qubes security bulletin (QSB) has been published.
What is a Qubes security bulletin (QSB)?
A Qubes security bulletin (QSB) is a security announcement issued by the Qubes security team. A QSB typically provides a summary and impact analysis of one or more recently-discovered software vulnerabilities, including details about patching to address them. A list of all QSBs is available here.
Why should I care about QSBs?
QSBs tell you what actions you must take in order to protect yourself from recently-discovered security vulnerabilities. In most cases, security vulnerabilities are addressed by updating normally. However, in some cases, special user action is required. In all cases, the required actions are detailed in QSBs.
What are the PGP signatures that accompany QSBs?
A PGP signature is a cryptographic digital signature made in accordance with the OpenPGP standard. PGP signatures can be cryptographically verified with programs like GNU Privacy Guard (GPG). The Qubes security team cryptographically signs all QSBs so that Qubes users have a reliable way to check whether QSBs are genuine. The only way to be certain that a QSB is authentic is by verifying its PGP signatures.
Why should I care whether a QSB is authentic?
A forged QSB could deceive you into taking actions that adversely affect the security of your Qubes OS system, such as installing malware or making configuration changes that render your system vulnerable to attack. Falsified QSBs could sow fear, uncertainty, and doubt about the security of Qubes OS or the status of the Qubes OS Project.
How do I verify the PGP signatures on a QSB?
The following command-line instructions assume a Linux system with git and gpg installed. (See here for Windows and Mac options.)
Obtain the Qubes Master Signing Key (QMSK), e.g.:
$ gpg --fetch-keys https://keys.qubes-os.org/keys/qubes-master-signing-key.asc gpg: directory '/home/user/.gnupg' created gpg: keybox '/home/user/.gnupg/pubring.kbx' created gpg: requesting key from 'https://keys.qubes-os.org/keys/qubes-master-signing-key.asc' gpg: /home/user/.gnupg/trustdb.gpg: trustdb created gpg: key DDFA1A3E36879494: public key "Qubes Master Signing Key" imported gpg: Total number processed: 1 gpg: imported: 1(See here for more ways to obtain the QMSK.)
View the fingerprint of the PGP key you just imported. (Note:
gpg>indicates a prompt inside of the GnuPG program. Type what appears after it when prompted.)$ gpg --edit-key 0x427F11FD0FAA4B080123F01CDDFA1A3E36879494 gpg (GnuPG) 2.2.27; Copyright (C) 2021 Free Software Foundation, Inc. This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. pub rsa4096/DDFA1A3E36879494 created: 2010-04-01 expires: never usage: SC trust: unknown validity: unknown [ unknown] (1). Qubes Master Signing Key gpg> fpr pub rsa4096/DDFA1A3E36879494 2010-04-01 Qubes Master Signing Key Primary key fingerprint: 427F 11FD 0FAA 4B08 0123 F01C DDFA 1A3E 3687 9494 -
Important: At this point, you still don’t know whether the key you just imported is the genuine QMSK or a forgery. In order for this entire procedure to provide meaningful security benefits, you must authenticate the QMSK out-of-band. Do not skip this step! The standard method is to obtain the QMSK fingerprint from multiple independent sources in several different ways and check to see whether they match the key you just imported. See here for more details and ideas for how to do that.
Tip: Record the genuine QMSK fingerprint in a safe place (or several) so that you don’t have to repeat this step in the future.
Once you are satisfied that you have the genuine QMSK, set its trust level to 5 (“ultimate”), then quit GnuPG with
q.gpg> trust pub rsa4096/DDFA1A3E36879494 created: 2010-04-01 expires: never usage: SC trust: unknown validity: unknown [ unknown] (1). Qubes Master Signing Key Please decide how far you trust this user to correctly verify other users' keys (by looking at passports, checking fingerprints from different sources, etc.) 1 = I don't know or won't say 2 = I do NOT trust 3 = I trust marginally 4 = I trust fully 5 = I trust ultimately m = back to the main menu Your decision? 5 Do you really want to set this key to ultimate trust? (y/N) y pub rsa4096/DDFA1A3E36879494 created: 2010-04-01 expires: never usage: SC trust: ultimate validity: unknown [ unknown] (1). Qubes Master Signing Key Please note that the shown key validity is not necessarily correct unless you restart the program. gpg> q -
Use Git to clone the qubes-secpack repo.
$ git clone https://github.com/QubesOS/qubes-secpack.git Cloning into 'qubes-secpack'... remote: Enumerating objects: 4065, done. remote: Counting objects: 100% (1474/1474), done. remote: Compressing objects: 100% (742/742), done. remote: Total 4065 (delta 743), reused 1413 (delta 731), pack-reused 2591 Receiving objects: 100% (4065/4065), 1.64 MiB | 2.53 MiB/s, done. Resolving deltas: 100% (1910/1910), done. -
Import the included PGP keys. (See our PGP key policies for important information about these keys.)
$ gpg --import qubes-secpack/keys/*/* gpg: key 063938BA42CFA724: public key "Marek Marczykowski-GĂłrecki (Qubes OS signing key)" imported gpg: qubes-secpack/keys/core-devs/retired: read error: Is a directory gpg: no valid OpenPGP data found. gpg: key 8C05216CE09C093C: 1 signature not checked due to a missing key gpg: key 8C05216CE09C093C: public key "HW42 (Qubes Signing Key)" imported gpg: key DA0434BC706E1FCF: public key "Simon Gaiser (Qubes OS signing key)" imported gpg: key 8CE137352A019A17: 2 signatures not checked due to missing keys gpg: key 8CE137352A019A17: public key "Andrew David Wong (Qubes Documentation Signing Key)" imported gpg: key AAA743B42FBC07A9: public key "Brennan Novak (Qubes Website & Documentation Signing)" imported gpg: key B6A0BB95CA74A5C3: public key "Joanna Rutkowska (Qubes Documentation Signing Key)" imported gpg: key F32894BE9684938A: public key "Marek Marczykowski-GĂłrecki (Qubes Documentation Signing Key)" imported gpg: key 6E7A27B909DAFB92: public key "Hakisho Nukama (Qubes Documentation Signing Key)" imported gpg: key 485C7504F27D0A72: 1 signature not checked due to a missing key gpg: key 485C7504F27D0A72: public key "Sven Semmler (Qubes Documentation Signing Key)" imported gpg: key BB52274595B71262: public key "unman (Qubes Documentation Signing Key)" imported gpg: key DC2F3678D272F2A8: 1 signature not checked due to a missing key gpg: key DC2F3678D272F2A8: public key "Wojtek Porczyk (Qubes OS documentation signing key)" imported gpg: key FD64F4F9E9720C4D: 1 signature not checked due to a missing key gpg: key FD64F4F9E9720C4D: public key "Zrubi (Qubes Documentation Signing Key)" imported gpg: key DDFA1A3E36879494: "Qubes Master Signing Key" not changed gpg: key 1848792F9E2795E9: public key "Qubes OS Release 4 Signing Key" imported gpg: qubes-secpack/keys/release-keys/retired: read error: Is a directory gpg: no valid OpenPGP data found. gpg: key D655A4F21830E06A: public key "Marek Marczykowski-GĂłrecki (Qubes security pack)" imported gpg: key ACC2602F3F48CB21: public key "Qubes OS Security Team" imported gpg: qubes-secpack/keys/security-team/retired: read error: Is a directory gpg: no valid OpenPGP data found. gpg: key 4AC18DE1112E1490: public key "Simon Gaiser (Qubes Security Pack signing key)" imported gpg: Total number processed: 17 gpg: imported: 16 gpg: unchanged: 1 gpg: marginals needed: 3 completes needed: 1 trust model: pgp gpg: depth: 0 valid: 1 signed: 6 trust: 0-, 0q, 0n, 0m, 0f, 1u gpg: depth: 1 valid: 6 signed: 0 trust: 6-, 0q, 0n, 0m, 0f, 0u -
Verify signed Git tags.
$ cd qubes-secpack/ $ git tag -v `git describe` object 266e14a6fae57c9a91362c9ac784d3a891f4d351 type commit tag marmarek_sec_266e14a6 tagger Marek Marczykowski-GĂłrecki 1677757924 +0100 Tag for commit 266e14a6fae57c9a91362c9ac784d3a891f4d351 gpg: Signature made Thu 02 Mar 2023 03:52:04 AM PST gpg: using RSA key 2D1771FE4D767EDC76B089FAD655A4F21830E06A gpg: Good signature from "Marek Marczykowski-GĂłrecki (Qubes security pack)" [full]The exact output will differ, but the final line should always start with
gpg: Good signature from...followed by an appropriate key. The[full]indicates full trust, which this key inherits in virtue of being validly signed by the QMSK. -
Verify PGP signatures, e.g.:
$ cd QSBs/ $ gpg --verify qsb-087-2022.txt.sig.marmarek qsb-087-2022.txt gpg: Signature made Wed 23 Nov 2022 04:05:51 AM PST gpg: using RSA key 2D1771FE4D767EDC76B089FAD655A4F21830E06A gpg: Good signature from "Marek Marczykowski-GĂłrecki (Qubes security pack)" [full] $ gpg --verify qsb-087-2022.txt.sig.simon qsb-087-2022.txt gpg: Signature made Wed 23 Nov 2022 03:50:42 AM PST gpg: using RSA key EA18E7F040C41DDAEFE9AA0F4AC18DE1112E1490 gpg: Good signature from "Simon Gaiser (Qubes Security Pack signing key)" [full] $ cd ../canaries/ $ gpg --verify canary-034-2023.txt.sig.marmarek canary-034-2023.txt gpg: Signature made Thu 02 Mar 2023 03:51:48 AM PST gpg: using RSA key 2D1771FE4D767EDC76B089FAD655A4F21830E06A gpg: Good signature from "Marek Marczykowski-GĂłrecki (Qubes security pack)" [full] $ gpg --verify canary-034-2023.txt.sig.simon canary-034-2023.txt gpg: Signature made Thu 02 Mar 2023 01:47:52 AM PST gpg: using RSA key EA18E7F040C41DDAEFE9AA0F4AC18DE1112E1490 gpg: Good signature from "Simon Gaiser (Qubes Security Pack signing key)" [full]Again, the exact output will differ, but the final line of output from each
gpg --verifycommand should always start withgpg: Good signature from...followed by an appropriate key.
For this announcement (QSB-090), the commands are:
$ gpg --verify qsb-090-2023.txt.sig.marmarek qsb-090-2023.txt
$ gpg --verify qsb-090-2023.txt.sig.simon qsb-090-2023.txt
You can also verify the signatures directly from this announcement in addition to or instead of verifying the files from the qubes-secpack. Simply copy and paste the QSB-090 text into a plain text file and do the same for both signature files. Then, perform the same authentication steps as listed above, substituting the filenames above with the names of the files you just created.
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2023/08/02/qsb-090-update/
