Attempted to perform an in-place upgrade to 4.1 from 4.0 and I simply can’t. It first says it can’t detect the release version, then it says version 4.0.6-1 fc25 noarch is already installed. The process takes a few minutes. What can I do?
Thanks.
are you folowing:
Yes.
I did have to try several times. Please describe your steps and error messages you get, so someone can help you.
