layout:
'hcl'
type:
'notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'unknown'
remap:
'yes'
brand: |
TUXEDO
model: |
N7x0WU
bios: |
5.12
cpu: |
Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
cpu-short: |
FIXME
chipset: |
Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers [8086:5914] (rev 08)
chipset-short: |
FIXME
gpu: |
Intel Corporation UHD Graphics 620 [8086:5917] (rev 07) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 12)
Intel Corporation Wireless 8265 / 8275 (rev 78)
memory: |
32646
scsi: |
ST2000LM015-2E81 Rev: SDM1
Samsung SSD 860 Rev: 1B6Q
usb: |
2
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.1
xen: |
4.14.5
kernel: |
5.15.52-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
Remarks
After Installation the Network-VMs doesn’n start. problem is an unassigned Realtek Express Card Reader. The problem is described on this Website: libvirt.libvirtError: internal error: Unable to reset PCI device 0000:05:00.2: internal error: Active 0000:05:00.0 devices on bus with 0000:05:00.2, not doing bus reset · Issue #1393 · QubesOS/qubes-issues · GitHub . After this fix is installed - all looks fine.
I’ve tested some Tools like vlc, kdenlive, calibre, anki, mpv, mplayer and all work fine. For anki i have created a debian-template with japanese symbols. Both Network-Adapter, LAN and WLAN, works fine.
I have also tested many displaylink-driver for my docking station. Some of them works but the System ist very slow and hangs a lot of time. So i didn’t use it anymore.
- Qubes-HCL-TUXEDO-N7x0WU-20220827-131300.yml (993 Bytes)
