layout:
'hcl'
type:
'notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'unknown'
remap:
'yes'
brand: |
TUXEDO
model: |
TUXEDO Aura 15 Gen1
bios: |
1.07.08TTR3
cpu: |
AMD Ryzen 7 4700U with Radeon Graphics
cpu-short: |
FIXME
chipset: |
Advanced Micro Devices, Inc. [AMD] Renoir Root Complex [1022:1630]
chipset-short: |
FIXME
gpu: |
Advanced Micro Devices, Inc. [AMD/ATI] Renoir [1002:1636] (rev c2) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Intel Corporation Wi-Fi 6 AX200 (rev 1a)
memory: |
64893
scsi: |
Samsung SSD 860 Rev: 4B6Q
usb: |
2
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.1
xen: |
4.14.5
kernel: |
5.15.52-1
remark: |
1. Update BIOS to version 1.07.08TTR3 instead 1.07.08TTR1
2. Enable advanced BIOS settings
3. In one of the AMD elements go to NBIO and activate IOMMU
4. Set performance profile to 3 (Quiet)
5. Set Core Performance Boost to Off
6. TPM might be possible to activate in BIOS
NOTE: System crashes were imminent if the performance profile is not set to 3
and CPB is not turned off - possibly due to overheating.
credit: |
S.N.
link: |
FIXLINK
Remarks
Can’t upload files yet, but the Tuxedo Aura Gen1 does work with Qubes if you are willing to do a few things. First I’m pretty sure I had to update the BIOS which allowed for some advanced settings. In one of the AMD tabs, there is the “NBIO” setting which can be used to enable IOMMU.
I had some stability issues due to the Auras horrendous fan control. Workaround: Disable CPM and set performance mode to “Quiet” in the BIOS.
This allows my device to idle around 55 degrees Celsius. More testing required.
Update: After updating to kernel-latest the stability issues seem to have subsided. There are still some issues with the fan control - it can be done in BIOS (i.e. setting medium to 75C and fan to 80 or such) but it’s not very good.
I don’t want to install an electron app using npm in dom0 however.
