Trying to do a in-place upgrade to 4.3.rc2 issue
Hello, while trying to upgrade from 4.2.4 to 4.3 I keep getting this error while tying to install the qubes-dist-upgrade . I have read the 4.3 upgrade documentation with no results getting this to work… Any help is appreciated.
$ sudo qubes-dom0-update -y qubes-dist-upgrade  --releasever=4.3 --enablerepo=qubes-dom0-current-testing
Using sys-whonix as UpdateVM for Dom0
Downloading packages. This may take a while...
Fedora 41 - x86_64                               14 kB/s |  27 kB     00:01
Fedora 41 - x86_64 - Updates                    3.9 kB/s | 7.2 kB     00:01
Qubes Host Repository (updates)                 1.6 kB/s | 2.7 kB     00:01
Qubes Host Repository (updates-testing)         1.4 kB/s | 2.8 kB     00:01
No match for argument: qubes-dist-upgrade
Error: Unable to find a match: qubes-dist-upgrade
It seems that you’ve already updated your dom0 repositories to Qubes OS 4.3.
Did you run qubes-dist-upgrade before to update Qubes OS 4.2 to Qubes OS 4.3 and removed qubes-dist-upgrade after this?
Or did you change repositories manually?
No, I did not run qubes-dist-upgrade I enabled all testing updates in the global config. It downloaded a few updates that was about it.
Then run this command instead:
sudo qubes-dom0-update -y qubes-dist-upgrade  --releasever=4.2 --enablerepo=qubes-dom0-current-testing
That worked… :sunglasses: What was the issue?
Thank you for your help.
Package             Arch    Version          Repository                   Size
Installing:
 qubes-dist-upgrade  noarch  4.2.1-1.fc37     qubes-dom0-current-testing   21 k
Installing dependencies:
 xinput              x86_64  1.6.4-3.fc41     fedora                       37 k
Since you’re still on Qubes OS 4.2, then don’t use --releasever=4.3 as stated in the guide:
