I made a post before, sadly, the spam filter removed the post.
I am using the instructions here:
wget doesn’t seem to work I recall from 4.2 / Whonix 17, so I copied this from my previous Qubes install:
curl -sx 127.0.0.1:8082 https://updates.signal.org/desktop/apt/keys.asc | gpg --dearmor | sudo tee -a /usr/share/keyrings/signal-desktop-keyring.gpg > /dev/null
WARNING: Tor proxy doesn't seem to be functional. Stream isolation will be disabled.
Before I write more errors and the filter removes my post, this seems to be the crux of the problem.
Tor proxy doesn’t seem to be functional, stream isolation will be disabled.
Trying the step #1 on the signal instructions results in this:
If you are using Whonix 18, you don’t need to do anything special to use the sysmaint user.
Simply open qterminal in the whonix-workstation-18 template, and it will open by default as the sysmaint user. Sudo commands will work unless you have made changes yourself to the Boot mode settings.
