Trivalent Browser
I have been trying to get this to work on a Fedora 42 template but I have been unsuccessful so far. I have managed to install it, but I cannot get it to run. I cannot get appVM to show it in the application list. A friend of mine set it up on a normal Fedora system and it just works normally. Can anyone offer some suggestions?
In a fedora template, run this:
sudo -i
curl -x http://localhost:8082 -o /etc/yum.repos.d/secureblue.repo https://repo.secureblue.dev/secureblue.repo
yum update
Then accept the GPG key, and run
yum install trivalent
After you stop the template, Trivalent should show up in the template applications list, and all AppVMs using this template.
Thanks for your help!
I tried that. The first command printed nothing, appeared to do nothing actually. Is that normal?
The second command printed this
Updating and loading repositories:
Repositories loaded.
Failed to resolve the transaction:
No match for argument: trivalent
You can try to add to command line:
–skip-unavailable to skip unavailable packages
I’m afraid to say that I don’t know enough to be able to successfully resolve the situation myself.
EIDT: changed the name to
trivalent-chromium-clean-source
and that worked. Well that’s already installed as I mentioned in the initial comment.
Package “trivalent-chromium-clean-source-140.0.7339.127-878737.x86_64” is already installed.
It doesnt show up in the appVM still
the first command downloads a file and store it in /etc/yum.repos.d/secureblue.repo, it does not print anything.
What is the output of this?
dnf update
dnf search trivalent
bash-5.2# dnf search trivalent
Matched fields: name, summary
trivalent-subresource-filter.src Subresource filter for trivalent
trivalent-subresource-filter.noarch Subresource filter for trivalent
trivalent-chromium-clean-source.src Chromium’s source tarball.
trivalent-chromium-clean-source.x86_64 Chromium’s source tarball.
what about the output of dnf update?
That was a massive output, whilst it did its things. It worked and updated and verified all the packages. Do you want me to paste the whole output of that here?
I need to see the output if you want me to understand why you can’t install trivalent.
bash-5.2# dnf update
Package                                              Arch   Version                 Reposit      Size
Upgrading:
 btrfs-progs                                         x86_64 6.16.1-1.fc42           updates   6.3 MiB
   replacing btrfs-progs                             x86_64 6.16-1.fc42             updates   6.3 MiB
 cups-filesystem                                     noarch 1:2.4.14-1.fc42         updates   0.0   B
   replacing cups-filesystem                         noarch 1:2.4.12-3.fc42         updates   0.0   B
 cups-libs                                           x86_64 1:2.4.14-1.fc42         updates 618.7 KiB
   replacing cups-libs                               x86_64 1:2.4.12-3.fc42         updates 618.7 KiB
 pipewire                                            x86_64 1.4.8-1.fc42            updates 429.6 KiB
   replacing pipewire                                x86_64 1.4.7-1.fc42            updates 428.0 KiB
 pipewire-alsa                                       x86_64 1.4.8-1.fc42            updates 158.0 KiB
   replacing pipewire-alsa                           x86_64 1.4.7-1.fc42            updates 158.0 KiB
 pipewire-jack-audio-connection-kit                  x86_64 1.4.8-1.fc42            updates  30.0   B
   replacing pipewire-jack-audio-connection-kit      x86_64 1.4.7-1.fc42            updates  30.0   B
 pipewire-jack-audio-connection-kit-libs             x86_64 1.4.8-1.fc42            updates 496.6 KiB
   replacing pipewire-jack-audio-connection-kit-libs x86_64 1.4.7-1.fc42            updates 496.6 KiB
 pipewire-libs                                       x86_64 1.4.8-1.fc42            updates   8.6 MiB
   replacing pipewire-libs                           x86_64 1.4.7-1.fc42            updates   8.6 MiB
 pipewire-plugin-libcamera                           x86_64 1.4.8-1.fc42            updates 146.5 KiB
   replacing pipewire-plugin-libcamera               x86_64 1.4.7-1.fc42            updates 146.5 KiB
 pipewire-pulseaudio                                 x86_64 1.4.8-1.fc42            updates 436.1 KiB
   replacing pipewire-pulseaudio                     x86_64 1.4.7-1.fc42            updates 436.1 KiB
 qt5ct                                               x86_64 1.9-6.fc42              updates 952.8 KiB
   replacing qt5ct                                   x86_64 1.1-31.fc42             updates   1.2 MiB
Installing dependencies:
 LibRaw                                              x86_64 0.21.4-1.fc42           updates   2.3 MiB
 breeze-icon-theme                                   noarch 6.17.0-1.fc42           updates  27.0 MiB
 ghostscript-tools-fontutils                         noarch 10.05.1-4.fc42          updates   2.5 KiB
 ghostscript-tools-printing                          noarch 10.05.1-4.fc42          updates   3.5 KiB
 imath                                               x86_64 3.1.12-2.fc42           fedora  383.7 KiB
 jxrlib                                              x86_64 1.1-30.fc42             fedora  775.9 KiB
 kde-filesystem                                      x86_64 5-5.fc42                fedora  774.0   B
 kde-settings                                        noarch 42.0-3.fc42             fedora   69.4 KiB
 kf5-filesystem                                      x86_64 5.116.0-4.fc42          fedora    1.4 KiB
 kf5-karchive                                        x86_64 5.116.0-3.fc42          fedora  589.5 KiB
 kf5-kauth                                           x86_64 5.116.0-3.fc42          fedora  432.3 KiB
 kf5-kcodecs                                         x86_64 5.116.0-3.fc42          fedora  720.4 KiB
 kf5-kconfig-core                                    x86_64 5.116.0-3.fc42          fedora    1.2 MiB
 kf5-kconfig-gui                                     x86_64 5.116.0-3.fc42          fedora  145.5 KiB
 kf5-kconfigwidgets                                  x86_64 5.116.0-3.fc42          fedora    1.5 MiB
 kf5-kcoreaddons                                     x86_64 5.116.0-3.fc42          fedora    1.8 MiB
 kf5-kguiaddons                                      x86_64 5.116.0-3.fc42          fedora  377.6 KiB
 kf5-ki18n                                           x86_64 5.116.0-3.fc42          fedora   17.0 MiB
 kf5-kiconthemes                                     x86_64 5.116.0-3.fc42          fedora  560.1 KiB
 kf5-kwidgetsaddons                                  x86_64 5.116.0-3.fc42          fedora    6.6 MiB
 kf6-filesystem                                      x86_64 6.17.0-1.fc42           updates   1.5 KiB
 kf6-karchive                                        x86_64 6.17.0-1.fc42           updates 753.9 KiB
 kf6-kimageformats                                   x86_64 6.17.0-1.fc42           updates   2.5 MiB
 openexr-libs                                        x86_64 3.2.4-3.fc41            fedora    6.5 MiB
 plasma-breeze-common                                noarch 6.4.4-1.fc42            updates  38.4 MiB
 polkit-qt5-1                                        x86_64 0.200.0-3.fc42          fedora  256.7 KiB
 qt6-filesystem                                      x86_64 6.9.1-1.fc42            updates   0.0   B
 qt6-qtbase                                          x86_64 6.9.1-1.fc42            updates  12.9 MiB
 qt6-qtbase-common                                   noarch 6.9.1-1.fc42            updates  74.0   B
 qt6-qtbase-gui                                      x86_64 6.9.1-1.fc42            updates  23.7 MiB
 qt6-qtdeclarative                                   x86_64 6.9.1-3.fc42            updates  49.0 MiB
 qt6-qtsvg                                           x86_64 6.9.1-2.fc42            updates 873.1 KiB
 qt6-qtwayland                                       x86_64 6.9.1-3.fc42            updates   5.0 MiB
 tslib                                               x86_64 1.23-1.fc42             fedora  416.1 KiB
 xcb-util-cursor                                     x86_64 0.1.5-3.fc42            fedora   23.2 KiB
Installing weak dependencies:
 ghostscript                                         x86_64 10.05.1-4.fc42          updates  30.8 KiB
 gstreamer1-plugins-good-qt6                         x86_64 1.26.5-1.fc42           updates 216.0 KiB
 kf6-kguiaddons                                      x86_64 6.17.0-1.fc42           updates 579.7 KiB
 qt6-qttranslations                                  noarch 6.9.1-1.fc42            updates  14.0 MiB
Transaction Summary:
 Installing:        39 packages
 Upgrading:         11 packages
 Replacing:         11 packages
Total size of inbound packages is 91 MiB. Need to download 91 MiB.
After this operation, 216 MiB extra will be used (install 235 MiB, remove 18 MiB).
Is this ok [y/N]: y
[ 1/50] kf5-kconfigwidgets-0:5.116.0-3. 100% | 744.9 KiB/s | 472.3 KiB |  00m01s
[ 2/50] kf5-kiconthemes-0:5.116.0-3.fc4 100% | 263.6 KiB/s | 191.4 KiB |  00m01s
[ 3/50] kf5-kconfig-core-0:5.116.0-3.fc 100% | 433.2 KiB/s | 354.8 KiB |  00m01s
[ 4/50] kde-settings-0:42.0-3.fc42.noar 100% | 101.6 KiB/s |  41.6 KiB |  00m00s
[ 5/50] kf5-kcodecs-0:5.116.0-3.fc42.x8 100% | 501.7 KiB/s | 202.2 KiB |  00m00s
[ 6/50] kf5-kauth-0:5.116.0-3.fc42.x86_ 100% | 288.2 KiB/s | 151.9 KiB |  00m01s
[ 7/50] kf5-kconfig-gui-0:5.116.0-3.fc4 100% | 152.3 KiB/s |  56.5 KiB |  00m00s
[ 8/50] kf5-kguiaddons-0:5.116.0-3.fc42 100% | 270.1 KiB/s | 116.1 KiB |  00m00s
[ 9/50] kf5-kcoreaddons-0:5.116.0-3.fc4 100% | 959.7 KiB/s | 501.0 KiB |  00m01s
[10/50] kf5-ki18n-0:5.116.0-3.fc42.x86_ 100% |   1.8 MiB/s |   1.7 MiB |  00m01s
[11/50] kf5-karchive-0:5.116.0-3.fc42.x 100% | 240.6 KiB/s | 167.2 KiB |  00m01s
[12/50] kf5-kwidgetsaddons-0:5.116.0-3. 100% |   1.3 MiB/s |   1.6 MiB |  00m01s
[13/50] kde-filesystem-0:5-5.fc42.x86_6 100% |  54.1 KiB/s |  38.0 KiB |  00m01s
[14/50] polkit-qt5-1-0:0.200.0-3.fc42.x 100% |  99.9 KiB/s |  83.9 KiB |  00m01s
[15/50] kf5-filesystem-0:5.116.0-4.fc42 100% |  19.3 KiB/s |  11.1 KiB |  00m01s
[16/50] kf6-kguiaddons-0:6.17.0-1.fc42. 100% | 138.6 KiB/s | 177.3 KiB |  00m01s
[17/50] qt6-qtbase-0:6.9.1-1.fc42.x86_6 100% | 665.1 KiB/s |   4.1 MiB |  00m06s
[18/50] breeze-icon-theme-0:6.17.0-1.fc 100% |   1.2 MiB/s |  10.4 MiB |  00m08s
[19/50] qt6-qtbase-common-0:6.9.1-1.fc4 100% |  16.1 KiB/s |  12.5 KiB |  00m01s
[20/50] qt6-qtwayland-0:6.9.1-3.fc42.x8 100% |  92.6 KiB/s |   1.2 MiB |  00m13s
[21/50] qt6-qtbase-gui-0:6.9.1-1.fc42.x 100% | 165.5 KiB/s |   7.7 MiB |  00m48s
[22/50] qt6-qtsvg-0:6.9.1-2.fc42.x86_64 100% | 143.9 KiB/s | 293.4 KiB |  00m02s
[23/50] tslib-0:1.23-1.fc42.x86_64      100% |  62.4 KiB/s | 153.9 KiB |  00m02s
[24/50] xcb-util-cursor-0:0.1.5-3.fc42. 100% |  19.7 KiB/s |  18.3 KiB |  00m01s
[25/50] kf6-kimageformats-0:6.17.0-1.fc 100% | 337.8 KiB/s | 663.5 KiB |  00m02s
[26/50] imath-0:3.1.12-2.fc42.x86_64    100% |  10.6 KiB/s | 101.8 KiB |  00m10s
[27/50] jxrlib-0:1.1-30.fc42.x86_64     100% | 555.5 KiB/s | 457.2 KiB |  00m01s
[28/50] openexr-libs-0:3.2.4-3.fc41.x86 100% | 444.2 KiB/s |   1.1 MiB |  00m03s
[29/50] qt6-filesystem-0:6.9.1-1.fc42.x 100% |  14.8 KiB/s |  10.8 KiB |  00m01s
[30/50] LibRaw-0:0.21.4-1.fc42.x86_64   100% | 282.8 KiB/s | 412.7 KiB |  00m01s
[31/50] kf6-filesystem-0:6.17.0-1.fc42. 100% |  21.1 KiB/s |  12.5 KiB |  00m01s
[32/50] kf6-karchive-0:6.17.0-1.fc42.x8 100% | 231.3 KiB/s | 204.7 KiB |  00m01s
[33/50] gstreamer1-plugins-good-qt6-0:1 100% | 165.3 KiB/s |  84.8 KiB |  00m01s
[34/50] qt6-qttranslations-0:6.9.1-1.fc 100% | 151.4 KiB/s |   1.9 MiB |  00m13s
[35/50] ghostscript-0:10.05.1-4.fc42.x8 100% |  25.8 KiB/s |  36.4 KiB |  00m01s
[36/50] ghostscript-tools-fontutils-0:1 100% |   9.6 KiB/s |  12.2 KiB |  00m01s
[37/50] qt6-qtdeclarative-0:6.9.1-3.fc4 100% | 128.9 KiB/s |  12.8 MiB |  01m41s
[38/50] ghostscript-tools-printing-0:10 100% |  14.8 KiB/s |  12.8 KiB |  00m01s
[39/50] cups-filesystem-1:2.4.14-1.fc42 100% |  13.4 KiB/s |  12.7 KiB |  00m01s
[40/50] btrfs-progs-0:6.16.1-1.fc42.x86 100% | 737.0 KiB/s |   1.3 MiB |  00m02s
[41/50] cups-libs-1:2.4.14-1.fc42.x86_6 100% | 244.6 KiB/s | 261.3 KiB |  00m01s
[42/50] pipewire-0:1.4.8-1.fc42.x86_64  100% | 190.4 KiB/s | 134.4 KiB |  00m01s
[43/50] pipewire-pulseaudio-0:1.4.8-1.f 100% | 156.7 KiB/s | 210.2 KiB |  00m01s
[44/50] plasma-breeze-common-0:6.4.4-1. 100% | 342.4 KiB/s |  38.4 MiB |  01m55s
[45/50] pipewire-plugin-libcamera-0:1.4 100% |  10.4 KiB/s |  75.8 KiB |  00m07s
[46/50] pipewire-jack-audio-connection- 100% |  20.4 KiB/s | 144.9 KiB |  00m07s
[47/50] pipewire-alsa-0:1.4.8-1.fc42.x8 100% |  53.9 KiB/s |  60.4 KiB |  00m01s
[48/50] pipewire-jack-audio-connection- 100% |  11.5 KiB/s |  12.3 KiB |  00m01s
[49/50] qt5ct-0:1.9-6.fc42.x86_64       100% | 247.0 KiB/s | 267.3 KiB |  00m01s
[50/50] pipewire-libs-0:1.4.8-1.fc42.x8 100% | 207.9 KiB/s |   2.4 MiB |  00m12s
[50/50] Total                           100% | 724.4 KiB/s |  90.6 MiB |  02m08s
Running transaction
[ 1/63] Verify package files            100% |  33.0   B/s |  50.0   B |  00m01s
[ 2/63] Prepare transaction             100% |  96.0   B/s |  61.0   B |  00m01s
[ 3/63] Upgrading pipewire-libs-0:1.4.8 100% |  28.0 MiB/s |   8.7 MiB |  00m00s
[ 4/63] Installing kde-filesystem-0:5-5 100% | 623.2 KiB/s |  54.2 KiB |  00m00s
[ 5/63] Installing kf5-filesystem-0:5.1 100% | 254.2 KiB/s |   3.3 KiB |  00m00s
[ 6/63] Installing kf5-kcoreaddons-0:5. 100% |  12.7 MiB/s |   1.8 MiB |  00m00s
[ 7/63] Installing kf6-filesystem-0:6.1 100% | 193.7 KiB/s |   3.7 KiB |  00m00s
[ 8/63] Installing kf5-ki18n-0:5.116.0- 100% |  62.5 MiB/s |  17.0 MiB |  00m00s
[ 9/63] Installing kf5-kwidgetsaddons-0 100% |  19.8 MiB/s |   6.6 MiB |  00m00s
[10/63] Installing ghostscript-tools-fo 100% |  33.2 KiB/s |   3.4 KiB |  00m00s
[11/63] Installing ghostscript-tools-pr 100% |  51.1 KiB/s |   5.1 KiB |  00m00s
[12/63] Installing ghostscript-0:10.05. 100% | 326.6 KiB/s |  35.3 KiB |  00m00s
[13/63] Installing imath-0:3.1.12-2.fc4 100% |   7.5 MiB/s | 385.9 KiB |  00m00s
[14/63] Installing openexr-libs-0:3.2.4 100% |  48.7 MiB/s |   6.5 MiB |  00m00s
[15/63] Installing kf5-kcodecs-0:5.116. 100% |   6.2 MiB/s | 739.2 KiB |  00m00s
[16/63] Installing kf5-kguiaddons-0:5.1 100% |   7.6 MiB/s | 380.7 KiB |  00m00s
[17/63] Installing kf5-karchive-0:5.116 100% |   5.6 MiB/s | 596.7 KiB |  00m00s
[18/63] Upgrading pipewire-jack-audio-c 100% |   7.6 KiB/s | 312.0   B |  00m00s
[19/63] Upgrading pipewire-jack-audio-c 100% |   6.2 MiB/s | 499.1 KiB |  00m00s
[20/63] Upgrading cups-filesystem-1:2.4 100% |  37.9 KiB/s |   1.8 KiB |  00m00s
[21/63] Upgrading cups-libs-1:2.4.14-1. 100% |  10.1 MiB/s | 620.3 KiB |  00m00s
[22/63] Installing LibRaw-0:0.21.4-1.fc 100% |  35.4 MiB/s |   2.3 MiB |  00m00s
[23/63] Installing qt6-filesystem-0:6.9 100% |  85.1 KiB/s |   3.5 KiB |  00m00s
[24/63] Installing qt6-qtbase-common-0: 100% |  13.8 KiB/s | 352.0   B |  00m00s
[25/63] Installing qt6-qtbase-0:6.9.1-1 100% |  35.0 MiB/s |  12.9 MiB |  00m00s
[26/63] Installing kf6-karchive-0:6.17. 100% |   6.6 MiB/s | 762.6 KiB |  00m00s
[27/63] Installing jxrlib-0:1.1-30.fc42 100% |   6.0 MiB/s | 778.6 KiB |  00m00s
[28/63] Installing xcb-util-cursor-0:0. 100% | 170.9 KiB/s |  24.6 KiB |  00m00s
[29/63] Installing tslib-0:1.23-1.fc42. 100% |   1.3 MiB/s | 432.4 KiB |  00m00s
[30/63] Installing qt6-qtbase-gui-0:6.9 100% |  60.9 MiB/s |  23.7 MiB |  00m00s
[31/63] Installing qt6-qtsvg-0:6.9.1-2. 100% |   9.5 MiB/s | 876.2 KiB |  00m00s
[32/63] Installing qt6-qtdeclarative-0: 100% |  37.5 MiB/s |  49.3 MiB |  00m01s
[33/63] Installing qt6-qtwayland-0:6.9. 100% |  15.9 MiB/s |   5.1 MiB |  00m00s
[34/63] Installing breeze-icon-theme-0: 100% |   5.1 MiB/s |  33.8 MiB |  00m07s
[35/63] Installing kde-settings-0:42.0- 100% |   2.7 MiB/s |  79.3 KiB |  00m00s
[36/63] Installing kf5-kconfig-core-0:5 100% |  17.7 MiB/s |   1.2 MiB |  00m00s
[37/63] Installing kf5-kconfig-gui-0:5. 100% |  20.4 MiB/s | 146.3 KiB |  00m00s
[38/63] Installing plasma-breeze-common 100% | 198.0 MiB/s |  38.4 MiB |  00m00s
[39/63] Installing polkit-qt5-1-0:0.200 100% |  14.1 MiB/s | 259.8 KiB |  00m00s
[40/63] Installing kf5-kauth-0:5.116.0- 100% |   6.5 MiB/s | 453.5 KiB |  00m00s
[41/63] Installing kf5-kconfigwidgets-0 100% |  19.0 MiB/s |   1.5 MiB |  00m00s
[42/63] Installing kf5-kiconthemes-0:5. 100% |   9.2 MiB/s | 577.8 KiB |  00m00s
[43/63] Upgrading qt5ct-0:1.9-6.fc42.x8 100% |  14.3 MiB/s | 963.1 KiB |  00m00s
[44/63] Installing kf6-kguiaddons-0:6.1 100% |  11.2 MiB/s | 584.9 KiB |  00m00s
[45/63] Installing gstreamer1-plugins-g 100% |  16.3 MiB/s | 216.5 KiB |  00m00s
[46/63] Installing kf6-kimageformats-0: 100% |  24.4 MiB/s |   2.5 MiB |  00m00s
[47/63] Upgrading pipewire-0:1.4.8-1.fc 100% |   5.3 MiB/s | 436.2 KiB |  00m00s
[48/63] Upgrading pipewire-pulseaudio-0 100% |   6.0 MiB/s | 444.2 KiB |  00m00s
[49/63] Upgrading pipewire-plugin-libca 100% |  12.0 MiB/s | 147.2 KiB |  00m00s
[50/63] Upgrading pipewire-alsa-0:1.4.8 100% |   6.0 MiB/s | 159.8 KiB |  00m00s
[51/63] Upgrading btrfs-progs-0:6.16.1- 100% |  11.2 MiB/s |   6.3 MiB |  00m01s
[52/63] Installing qt6-qttranslations-0 100% |  18.9 MiB/s |  14.1 MiB |  00m01s
[53/63] Removing pipewire-jack-audio-co 100% | 151.0   B/s |  15.0   B |  00m00s
[54/63] Removing pipewire-alsa-0:1.4.7- 100% | 173.0   B/s |   9.0   B |  00m00s
[55/63] Removing pipewire-pulseaudio-0: 100% | 356.0   B/s |  47.0   B |  00m00s
[56/63] Removing pipewire-0:1.4.7-1.fc4 100% | 565.0   B/s |  43.0   B |  00m00s
[57/63] Removing pipewire-plugin-libcam 100% | 227.0   B/s |   5.0   B |  00m00s
[58/63] Removing cups-libs-1:2.4.12-3.f 100% | 428.0   B/s |   9.0   B |  00m00s
[59/63] Removing cups-filesystem-1:2.4. 100% | 684.0   B/s |  13.0   B |  00m00s
[60/63] Removing pipewire-jack-audio-co 100% |  55.0   B/s |   1.0   B |  00m00s
[61/63] Removing pipewire-libs-0:1.4.7- 100% |   2.2 KiB/s | 391.0   B |  00m00s
[62/63] Removing qt5ct-0:1.1-31.fc42.x8 100% | 598.0   B/s |  67.0   B |  00m00s
[63/63] Removing btrfs-progs-0:6.16-1.f 100% |   0.0   B/s |  58.0   B |  01m04s
Complete!
Ok, nothing weird here. Did it ever asked you to accept the GPG key of secureblue?
What is the output of dnf repolist ?
Looks like this for me:
repo id                                                        repo name
fedora                                                         Fedora 42 - x86_64
fedora-cisco-openh264                                          Fedora 42 openh264 (From Cisco) - x86_64
qubes-vm-r4.2-current                                          Qubes OS Repository for VM (updates)
secureblue                                                     secureblue
updates                                                        Fedora 42 - x86_64 - Updates
And on my system, I can search trivalent in the list and get some result:
Mise à jour et chargement des dépôts :
Dépôts chargés.
Champs avec correspondance : name (correspondance exacte)
 trivalent.x86_64	A security-focused browser built upon Google's Chromium web browser
 trivalent.aarch64	A security-focused browser built upon Google's Chromium web browser
Champs avec correspondance : name, summary
 trivalent-qt6-ui.x86_64	Qt6 UI built from Trivalent
 trivalent-qt6-ui.aarch64	Qt6 UI built from Trivalent
I believe it asked me accept the GPG yes, but not today with your input here, it was the other day when I first started trying.
Repolist output:
bash-5.2# dnf repolist
repo id repo name
copr:copr.fedorainfracloud.org:secureblue:trivalent Copr repo for trivalent owned by secureb
updates
I don’t understand if the browser is installed… with your initial post, I was thinking about something related to the app menu shortcuts:
Yes, someone else mentioned .desktop may be missing elsewhere on the internet. I don’t fully understand how to resolve that situation either. Qubes is so stable and easy to use for me once its set up. But when I have to start messing I soon get lost.
The previous link mentions a few ideas for troubleshooting this issue. Are you able to launch the browser from a qube using the template? You can open a terminal and run the program, or use xfce4-appfinder.
No I can’t seem to launch it at all from anywhere. I’m sorry but I do not know what xfce-appfinder is. I’m afraid to say that I’m not very good at all this.
Don’t worry. xfce4-appfinder is a graphical program that you can launch from terminal. But if you can’t launch the browser from terminal it might be useless…
Are you working on a test template? If so, could you try to create a new one and follow @solene instructions?
Yes, OK. I’ll create a new template do that tomorrow. That’s a good idea.
It seams to me that you didn’t installed repository so only thing that you installed is source code not binary.
Install repository first.
I have done that, and I am still getting nowhere.
sudo -i
yum update
bash-5.2# yum install trivalent
 Qubes OS Repository for VM (updates)   100% |   3.1 KiB/s |   2.8 KiB |  00m01s
 Fedora 42 - x86_64 - Updates           100% |   3.5 KiB/s |   5.0 KiB |  00m01s
  --skip-unavailable to skip unavailable packages
I just redid your instructions on a fresh template, and no. It did not ask me.
I did definitely have something installed/downloaded that resembles the browser but isn’t, so that makes sense. However, I was under the impression I had installed the repository.
This should looks like this
yum update
 secureblue                             100% |   3.0 KiB/s |   1.7 KiB |  00m01s
>>> repomd.xml GPG signature verification error: Signing key not found
 https://repo.secureblue.dev/secureblue 100% |   1.5 KiB/s | 417.0   B |  00m00s
Importation de la clé OpenPGP 0xF47B3E41 :
 UserID     : "secureblueadmin <secureblueadmin@proton.me>"
 Empreinte  : 26B4463ED8F313BC7E3FBDF9D9223AF0F47B3E41
 De         : https://repo.secureblue.dev/secureblue.gpg
Is this ok [y/N]:
Could you share the content of /etc/yum.repos.d/secureblue.repo on your template?
And the output of dnf repolist too?
