TongFang GX5 WiFi issues
Hello, I have a TongFang GX5. Ryzen AI 9 HX 370, 96GB, AMD Radeon 890M. The WiFi uses an MEDIATEK MT7922 adapter . I read that there was an issue with the 6.12 kernel with this and the only way to use it was to roll back to the 6.11 kernel. Unfortunately, I can’t install Qubes if I use 6.11 and then 6.12, the WiFi doesn’t work. I was checking to see if there was any progress being made on the kernel side to address this series of adapters.
Do you have tried to install the mediatek firmware (mt7xxx-firmware)?
The newest is actually installed by default. I looked for a newer one but didn’t see one. Thank you for your suggestion.
In the end, I swapped it out for an Intel card.
