When I open thunar the icon is perfectly fine, but when I start to navigate to any place like folders or my computer the icon is changing to whatever place I’m at. Like for a folder, it will actually display a folder icon instead of thunar’s one, or when I navigate to computer:/// it actually displays computer’s icon or when I’m at trash:/// it show’s the trash’s icon
I want it to show just my thunar’s icon like it normally would
What AppVM is this occuring in, and what TemplateVM is it based on?
This is a setting in thunar preferences. Go and change it, kemosabe.
Unless the issue is that it shows folder icon (instead of the hammer thing), not that it changes the icon based on current resource. Then I don’t know. You should search xfce-oriented resources for an answer.
p.s. Considering like it normally would, you probably have example of it working correctly. Maybe comparing configurations / thunar version will do it?
