Every now and then a new major version of the distro used as a base for our (hopefully) carefully-crafted templates is out. The “dist-upgrade my templates” approach (which we would use on a bare-metal GNU/Linux install) is cumbersome when it has to be applied to many templates, possibly may not provide all goodies of newer templates (upstream or Qubes), and globally does not seem favored around here. We seem to prefer switching a new version of the template, which also helps to minimize AppVM downtime.
But how do we make sure a newer version of a template is ready to switch an AppVM to the new version? How do we track the modifications done over the original template ? Unless you specifically take note, or back up your dpkg/rpm logs for later datamining, basically we don’t.
As I start to consider migrating my debian-10 templates to debian-11, I find myself wondering, “is the debian-10 template pristine, or did I install specific packages for a specific AppVM, and which?”.
As I look into setting up split-ssh (just an example of course, although really the one that finally triggered this post), I note that additional packages I’d need in vault are not present in the base image, and the same holds for the new qrexec definitions … and if I just install them I’m just adding to the bad trend that will make the template upgrade more painful.
How could we improve on that ?
I distinguish 3 kinds of templates (do I miss others?):
- those installed from repository, untouched
- those installed from repository, with modifications
- those cloned from one installed from repository, with later modifications
The value in such templates (what would be enough to backup, aside from their qubes.xml configuration) is precisely in those (rootfs) modifications… which we don’t track.
Tracking modifications to the rootfs as they are made is hard, identifying them after the fact is costly and may not necessarily yield usable information.
But we could explore another approach: adding a new kind of templates whose rootfs cannot be modified manually (eg. they would not be possible to start the standard ways). Those would only be modifiable under control of qubes-core-admin, ie. by applying Salt repices: if the rootfs state can be reproduced programmatically, we can much more easily produce a new template using a more recent version of the base distro, and (as a bonus) we only have to backup the scripts that generate them, instead of their full contents.
As qubesctl becomes the entrypoint for all modifications to such templates, it can record the full history. Today not everyone is familiar enough with Salt to manage templates this way. As early adopters write more recipes for common tasks, and those recipes are made available as standard admin tools, it will become progressively easier to onboard new users.
Eagerly waiting for your reactions
