Remarks
- Ethernet did not work out of the box, there was PCI issues. This was solved by following the guide here: PCI troubleshooting | Qubes OS
- Microphone works, have not tested out webcam yet
- Did not have to modify any bios settings, except disable secure boot
Discrete GPU Issues
Discrete GPU works out of the box, with latest kernels installed.
However it is not stable by any means. I crash 1-2 times a day with following error message.
GPU lockup - switching to software fbcon
Sometimes the screen goes black and I get back into the login screen after a few seconds. Other times the screen freezes completely and I have to do a hard reboot.
I think this can be fixed by installing Nvidia proprietary drivers. But I read in a recent post that Nvidia drivers are no longer supported. The community guide itself is 2 years old. If someone could give me more insight into this, that would be great.
layout:
'hcl'
type:
'notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'unknown'
remap:
'yes'
brand: |
LENOVO
model: |
20QVCTO1WW
bios: |
N2OET55W (1.42 )
cpu: |
Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
cpu-short: |
FIXME
chipset: |
Intel Corporation Device [8086:3e20] (rev 0d)
chipset-short: |
FIXME
gpu: |
Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630] [8086:3e9b] (rev 02) (prog-if 00 [VGA controller])
NVIDIA Corporation TU117M [GeForce GTX 1650 Mobile / Max-Q] [10de:1f91] (rev a1) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Ethernet Connection (7) I219-LM (rev 10)
Intel Corporation Wi-Fi 6 AX200 (rev 1a)
memory: |
65144
scsi: |
usb: |
2
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.1
xen: |
4.14.4
kernel: |
5.16.13-2
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
