I did as you asked, and completed the first step of processing the topic.
Everyone can use this post as a starting point in the topic, after reading the first post.
I hope this makes further research and discussion simpler for everyone.
The Two Distinct Concepts
Concept A: Qubes Event Buffering (The Intended Feature)
What it is: A specific mechanism implemented to obfuscate input timing.
The Claim: Forum users (specifically plankretriever) argue that while this feature works for keyboard timing, it is broken/ineffective for mouse movements. They claim it fails to inject sufficient noise into mouse data to defeat fingerprinting algorithms.
The Criticism: The user argues that because it doesn’t work for mice, Qubes OS users are vulnerable, unlike Whonix users who use Kloak.
Concept B: The Qubes Architecture / Unman’s Defense (The Incidental Effect)
What it is: The inherent nature of running a browser in a separate VM (AppVM) communicating with a GUI VM (dom0) via Xen.
The Claim: unman (Qubes Team) argues that the architecture itself provides the obfuscation. The process of routing input through the hypervisor (Xen) and between VMs introduces unintended, non-removable delays and jitter.
The Defense: unman states these natural delays are sufficient to degrade mouse fingerprinting to the point of being “almost useless,” effectively solving the problem without needing Kloak or a specific “buffering” feature. He suggests testing this by comparing timing data between two different Qubes VMs, which he claims will show no significant correlation.
Unman’s argument is that you don’t need the specific “Event Buffering” feature to be perfect; the underlying Xen/VM latency (which acts as a natural buffer) is already doing the heavy lifting. He implies that users looking for a specific “Kloak-like” module are missing the point that the OS architecture already breaks the timing correlation required for fingerprinting.
Technical Consensus from the Thread
The Conflict:
Side A (plankretriever): The specific mouse obfuscation logic in Qubes is missing. We need Kloak (which injects specific noise) because the current state could potentially at unpredictable times, leaves mouse tremors exposed.
Side B (unman/Qubes Team): You are over-engineering the problem. The natural latency of the VM architecture creates enough noise to break the fingerprint. Running tests in separate VMs already proves the correlation is broken.
The Unresolved Technical Question:
Does the incidental latency of Xen VM communication provide enough entropy to defeat modern, high-frequency mouse fingerprinting algorithms, or is active noise injection (like Kloak) mathematically required to reach the threshold of anonymity?
Why this is hard to answer: It requires running specific, high-fidelity fingerprinting scripts against a Qubes VM and measuring the “identification success rate” against a baseline of non-Qubes systems. There is no open-source “production ready” tool for this mentioned in the thread, making empirical verification difficult for the average user.
It also said this:
Avoiding JavaScript
Concept: Disable JS (e.g., via NoScript/NOJS) to prevent script-based data extraction.
Limitation: Modern web participation (forums, auth, dynamic content) almost universally requires JS. Disabling JS reduces utility to near-zero for **interactive** anonymity.
Text-Based Browsers (Lynx, w3m, etc.)
Concept: Use browsers that do not render a graphical cursor, eliminating mouse movement data entirely.
Limitation:
High Outlier Risk: **Very few anonymity seekers use text browsers, making the user a unique fingerprint based on the absence of mouse data.**
Bot Flagging: Many sites block or challenge text-based user agents.
Feature Parity: Cannot access modern web services requiring JS or complex UI.
VNC Proxying
Concept: Proxy browsing through a VNC session.
Mechanism: VNC decouples the physical input device from the browser session, altering the input source and significantly reducing sampling rate/fidelity.
Limitation:
Algorithms can filter out VNC-induced noise (e.g., 50ms spikes).
Still requires a GUI environment, potentially reintroducing some fingerprint vectors.
Adds complexity and latency.
Keyboard-Only Navigation
Concept: Use browsers with Vim-like navigation (e.g., qutebrowser) or screen readers to avoid mouse usage.
Limitation:
Outlier Status: **Like text browsers, 100% keyboard usage is rare, creating a unique behavioral fingerprint.**
"Assistive Tech" Argument: While ~5-20% of users have disabilities affecting input, **the specific combination of "keyboard-only + Tor + Qubes" remains statistically rare.**
UNANSWERED QUESTION: What is the statistical baseline of "keyboard-only" users in the Tor network, and is it low enough to be considered a unique fingerprint?
Why it's a valuable question: Validates or refutes the "outlier" argument against keyboard-only navigation.
Why it's difficult to answer: Requires telemetry data from the Tor network that is generally not aggregated for specific input methods due to privacy constraints. Estimating this requires surveying a non-representative sample or analyzing public exit node traffic patterns, which is noisy.
