Hello, I have a problem.
I use for one template for one program, but, I have a problem with whonix minimalization, I don’t need all of the programs that are preinstalled in the whonix template, as I use them separately in the minimal templates. I only need the tor browser
When I try to remove all the programs I don’t need from the whonix template, I encounter a bunch of errors.
Can you tell me what I can do to create a minimal template for my tor browser
Maybe I can modify debian template to whonix and then make settings of tor browser like whonix?
