Hello,
I can’t add the French language ?
On the previous version we used system-config-language but with the 36 it doesn’t work.
And I can’t add the free and non-free repositories either.
[user@fed36-bureau ~]$ sudo dnf install https://download1.rpmfusion.org/free/fedora/rpmfusion-free-release-$(rpm -E %fedora).noarch.rpm
Last metadata expiration check: 3:25:15 ago on Thu Sep 15 06:17:06 2022.
rpmfusion-free-release-36.noarch.rpm 2.1 kB/s | 11 kB 00:05
Package rpmfusion-free-release-36-1.noarch is already installed.
Dependencies resolved.
Nothing to do.
Complete!
[user@fed36-bureau ~]$ sudo dnf install https://download1.rpmfusion.org/nonfree/fedora/rpmfusion-nonfree-release-$(rpm -E %fedora).noarch.rpm
Last metadata expiration check: 3:25:52 ago on Thu Sep 15 06:17:06 2022.
rpmfusion-nonfree-release-36.noarch.rpm 3.9 kB/s | 11 kB 00:02
Package rpmfusion-nonfree-release-36-1.noarch is already installed.
Nothing to do.
Complete!
[user@fed36-bureau ~]$ dnf repolist
repo id repo name
fedora Fedora 36 - x86_64
fedora-cisco-openh264 Fedora 36 openh264 (From Cisco) - x86_64
qubes-vm-r4.1-current Qubes OS Repository for VM (updates)
updates Fedora 36 - x86_64 - Updates
[user@fed36-bureau ~]$ sudo dnf install vlc
Last metadata expiration check: 3:32:19 ago on Thu Sep 15 06:17:06 2022.
No match for argument: vlc
Error: Unable to find a match: vlc
