the dnf history command doesn’t show much. Here is the output of 2025 updates:
ID | Command line | Date and time | Action(s) | Altered
43 | --exclude=qubes-template- | 2025-03-04 05:17 | Upgrade | 4
42 | --exclude=qubes-template- | 2025-02-22 01:17 | Upgrade | 6 EE
41 | --exclude=qubes-template- | 2025-02-19 23:27 | C, E, I, U | 25 EE
40 | --exclude=qubes-template- | 2025-02-13 07:02 | C, E, I | 9 EE
39 | --exclude=qubes-template- | 2025-02-10 14:59 | Upgrade | 2
38 | --exclude=qubes-template- | 2025-01-17 10:57 | C, E, I, U | 21 EE
37 | --exclude=qubes-template- | 2025-01-07 04:01 | Upgrade | 2
36 | --exclude=qubes-template- | 2025-01-01 10:28 | C, E, I, U | 69 EE
I checked /var/log/dnf.log and here is the output for March 2025:
2025-03-04T05:17:38+0430 INFO --- logging initialized ---
2025-03-04T05:17:38+0430 DDEBUG timer: config: 5 ms
2025-03-04T05:17:38+0430 DEBUG Loaded plugins: builddep, changelog, config-manager, copr, debug, debuginfo-install, download, generate_completion_cache, groups-manager, needs-restarting, playground, repoclosure, repodiff, repograph, repomanage, reposync, system-upgrade
2025-03-04T05:17:38+0430 DEBUG DNF version: 4.18.0
2025-03-04T05:17:38+0430 DDEBUG Command: dnf check-update
2025-03-04T05:17:38+0430 DDEBUG Installroot: /
2025-03-04T05:17:38+0430 DDEBUG Releasever: 4.2
2025-03-04T05:17:38+0430 DEBUG cachedir: /var/cache/dnf
2025-03-04T05:17:38+0430 DDEBUG Base command: check-update
2025-03-04T05:17:38+0430 DDEBUG Extra commands: ['check-update']
2025-03-04T05:17:38+0430 DEBUG User-Agent: constructed: 'libdnf (Qubes OS 4.2; generic; Linux.x86_64)'
2025-03-04T05:17:38+0430 DEBUG reviving: failed for 'qubes-dom0-cached', mismatched repomd.
2025-03-04T05:17:38+0430 DEBUG repo: downloading from remote: qubes-dom0-cached
2025-03-04T05:17:38+0430 DEBUG qubes-dom0-cached: using metadata from Tue 04 Mar 2025 05:17:37 AM +0430.
2025-03-04T05:17:38+0430 DDEBUG timer: sack setup: 196 ms
2025-03-04T05:17:38+0430 DEBUG Completion plugin: Generating completion cache...
2025-03-04T05:17:38+0430 DDEBUG Cleaning up.
2025-03-04T05:17:38+0430 DDEBUG Plugins were unloaded.
2025-03-04T05:17:38+0430 DDEBUG timer: config: 2 ms
2025-03-04T05:17:38+0430 DDEBUG Command: dnf --exclude=qubes-template-* -y upgrade
2025-03-04T05:17:38+0430 DDEBUG Base command: upgrade
2025-03-04T05:17:38+0430 DDEBUG Extra commands: ['--exclude=qubes-template-*', '-y', 'upgrade']
2025-03-04T05:17:38+0430 DEBUG repo: using cache for: qubes-dom0-cached
2025-03-04T05:17:38+0430 DDEBUG timer: sack setup: 148 ms
2025-03-04T05:17:38+0430 DEBUG Excludes in dnf.conf: qubes-template-*
2025-03-04T05:17:38+0430 DEBUG --> Starting dependency resolution
2025-03-04T05:17:38+0430 DEBUG ---> Package qubes-core-dom0.noarch 4.2.36-1.fc37 will be upgraded
2025-03-04T05:17:38+0430 DEBUG ---> Package qubes-core-dom0.noarch 4.2.37-1.fc37 will be an upgrade
2025-03-04T05:17:38+0430 DEBUG ---> Package qubes-core-qrexec.x86_64 4.2.21-1.fc37 will be upgraded
2025-03-04T05:17:38+0430 DEBUG ---> Package qubes-core-qrexec.x86_64 4.2.23-1.fc37 will be an upgrade
2025-03-04T05:17:38+0430 DEBUG ---> Package qubes-core-qrexec-dom0.x86_64 4.2.21-1.fc37 will be upgraded
2025-03-04T05:17:38+0430 DEBUG ---> Package qubes-core-qrexec-dom0.x86_64 4.2.23-1.fc37 will be an upgrade
2025-03-04T05:17:38+0430 DEBUG ---> Package qubes-core-qrexec-libs.x86_64 4.2.21-1.fc37 will be upgraded
2025-03-04T05:17:38+0430 DEBUG ---> Package qubes-core-qrexec-libs.x86_64 4.2.23-1.fc37 will be an upgrade
2025-03-04T05:17:38+0430 DEBUG --> Finished dependency resolution
2025-03-04T05:17:38+0430 DDEBUG timer: depsolve: 26 ms
2025-03-04T05:17:38+0430 INFO Dependencies resolved.
2025-03-04T05:17:38+0430 INFO ================================================================================
Package Arch Version Repository Size
Upgrading:
qubes-core-dom0 noarch 4.2.37-1.fc37 qubes-dom0-cached 1.0 M
qubes-core-qrexec x86_64 4.2.23-1.fc37 qubes-dom0-cached 276 k
qubes-core-qrexec-dom0 x86_64 4.2.23-1.fc37 qubes-dom0-cached 43 k
qubes-core-qrexec-libs x86_64 4.2.23-1.fc37 qubes-dom0-cached 31 k
Transaction Summary
Upgrade 4 Packages
2025-03-04T05:17:38+0430 INFO Total size: 1.4 M
2025-03-04T05:17:38+0430 INFO Downloading Packages:
2025-03-04T05:17:38+0430 DEBUG Using rpmkeys executable at /usr/bin/rpmkeys to verify signatures
2025-03-04T05:17:38+0430 INFO Running transaction check
2025-03-04T05:17:39+0430 INFO Transaction check succeeded.
2025-03-04T05:17:39+0430 INFO Running transaction test
2025-03-04T05:17:39+0430 INFO Transaction test succeeded.
2025-03-04T05:17:39+0430 DDEBUG timer: transaction test: 332 ms
2025-03-04T05:17:39+0430 DDEBUG RPM transaction start.
2025-03-04T05:17:42+0430 DDEBUG RPM transaction over.
2025-03-04T05:17:42+0430 DDEBUG timer: verify transaction: 182 ms
2025-03-04T05:17:42+0430 DDEBUG timer: transaction: 3167 ms
2025-03-04T05:17:42+0430 DEBUG Completion plugin: Generating completion cache...
2025-03-04T05:17:42+0430 DEBUG Upgraded: qubes-core-dom0-4.2.37-1.fc37.noarch
2025-03-04T05:17:42+0430 DEBUG Upgraded: qubes-core-qrexec-4.2.23-1.fc37.x86_64
2025-03-04T05:17:42+0430 DEBUG Upgraded: qubes-core-qrexec-dom0-4.2.23-1.fc37.x86_64
2025-03-04T05:17:42+0430 DEBUG Upgraded: qubes-core-qrexec-libs-4.2.23-1.fc37.x86_64
2025-03-04T05:17:42+0430 INFO Complete!
2025-03-04T05:17:42+0430 DDEBUG Cleaning up.
2025-03-04T05:17:42+0430 DDEBUG Plugins were unloaded.
2025-03-04T05:17:42+0430 INFO --- logging initialized ---
2025-03-04T05:17:42+0430 DDEBUG timer: config: 2 ms
2025-03-04T05:17:42+0430 DEBUG Loaded plugins: builddep, changelog, config-manager, copr, debug, debuginfo-install, download, generate_completion_cache, groups-manager, needs-restarting, playground, repoclosure, repodiff, repograph, repomanage, reposync, system-upgrade
2025-03-04T05:17:42+0430 DEBUG DNF version: 4.18.0
2025-03-04T05:17:42+0430 DDEBUG Command: dnf -q check-update
2025-03-04T05:17:42+0430 DDEBUG Installroot: /
2025-03-04T05:17:42+0430 DDEBUG Releasever: 4.2
2025-03-04T05:17:42+0430 DEBUG cachedir: /var/cache/dnf
2025-03-04T05:17:42+0430 DDEBUG Base command: check-update
2025-03-04T05:17:42+0430 DDEBUG Extra commands: ['-q', 'check-update']
2025-03-04T05:17:42+0430 DEBUG User-Agent: constructed: 'libdnf (Qubes OS 4.2; generic; Linux.x86_64)'
2025-03-04T05:17:43+0430 DEBUG reviving: 'qubes-dom0-cached' can be revived - repomd matches.
2025-03-04T05:17:43+0430 DEBUG qubes-dom0-cached: using metadata from Tue 04 Mar 2025 05:17:37 AM +0430.
2025-03-04T05:17:43+0430 DDEBUG timer: sack setup: 156 ms
2025-03-04T05:17:43+0430 DDEBUG Cleaning up.
2025-03-04T05:17:43+0430 DDEBUG Plugins were unloaded.
Nope:
sudo dnf repolist
repo id repo name
qubes-dom0-cached Qubes OS Repository for Dom0
Output of /etc/yum.repos.d/qubes-dom0.repo
cat /etc/yum.repos.d/qubes-dom0.repo
[qubes-dom0-current]
name = Qubes Host Repository (updates)
#baseurl = https://yum.qubes-os.org/r$releasever/current/host/fc37
#baseurl = http://yum.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r$releasever/current/host/fc37
metalink = https://yum.qubes-os.org/r$releasever/current/host/fc37/repodata/repomd.xml.metalink
skip_if_unavailable=False
enabled = 1
metadata_expire = 6h
gpgcheck = 1
gpgkey = file:///etc/pki/rpm-gpg/RPM-GPG-KEY-qubes-$releasever-primary
[qubes-dom0-current-testing]
name = Qubes Host Repository (updates-testing)
#baseurl = https://yum.qubes-os.org/r$releasever/current-testing/host/fc37
#baseurl = http://yum.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r$releasever/current-testing/host/fc37
metalink = https://yum.qubes-os.org/r$releasever/current-testing/host/fc37/repodata/repomd.xml.metalink
enabled = 0
gpgcheck = 1
[qubes-dom0-security-testing]
name = Qubes Host Repository (security-testing)
#baseurl = https://yum.qubes-os.org/r$releasever/security-testing/host/fc37
#baseurl = http://yum.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r$releasever/security-testing/host/fc37
metalink = https://yum.qubes-os.org/r$releasever/security-testing/host/fc37/repodata/repomd.xml.metalink
enabled = 0
gpgcheck = 1
[qubes-dom0-unstable]
name = Qubes Host Repository (unstable)
#baseurl = https://yum.qubes-os.org/r$releasever/unstable/host/fc37
#baseurl = http://yum.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r$releasever/unstable/host/fc37
metalink = https://yum.qubes-os.org/r$releasever/unstable/host/fc37/repodata/repomd.xml.metalink
enabled = 0
gpgcheck = 1
gpgkey = file:///etc/pki/rpm-gpg/RPM-GPG-KEY-qubes-$releasever-unstable
Additionally here is the HCL report of the system:
layout:
'hcl'
type:
'Notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'unknown'
remap:
'yes'
brand: |
Dell Inc.
model: |
Latitude 5400
bios: |
1.18.0
cpu: |
Intel(R) Core(TM) i5-8365U CPU @ 1.60GHz
cpu-short: |
FIXME
chipset: |
Intel Corporation Coffee Lake HOST and DRAM Controller [8086:3e34] (rev 0c)
chipset-short: |
FIXME
gpu: |
Intel Corporation WhiskeyLake-U GT2 [UHD Graphics 620] [8086:3ea0] (rev 02) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Cannon Point-LP CNVi [Wireless-AC] [8086:9df0] (rev 30)
Intel Corporation Ethernet Connection (6) I219-LM [8086:15bd] (rev 30)
memory: |
32582
scsi: |
usb: |
1
certified:
'no'
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.2.4
xen: |
4.17.5
kernel: |
6.6.77-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
