Sys-whonix changes during computer iddle
computer: HP EliteBook 840 G6
cubes os: latest available, updated through TOR
problem: unattended changes in sys-whonix
Dear all,
i believe I do have modifications on the BIOS/NVRAM level on above mentioned laptop ultimately causing unauthorized access and system modification. I would appreciate if somebody could check attached log of sys-whonix telling if there isnt some straightforward indication of compromise. This would help a lot to actually and over the problem to my technological partner with capabilities and manpower to diagnose the problem properly and find the intrusion attack vector.
Many thanks and stay safe
Regards
Frantisek
Logfile Opened [ 0.000000] Linux version 6.6.54-1.qubes.fc37.x86_64 (mockbuild@88464547b772444f82c444d96f0906c1) (gcc (GCC) 12.3.1 20230508 (Red Hat 12.3.1-1), GNU ld version 2.38-27.fc37) #1 SMP PREEMPT_DYNAMIC Mon Oct 7 20:17:52 GMT 2024 [2024-12-01 17:05:55] [ 0.000000] Command line: root=/dev/mapper/dmroot ro nomodeset console=hvc0 rd_NO_PLYMOUTH rd.plymouth.enable=0 plymouth.enable=0 clocksource=tsc xen_scrub_pages=0 swiotlb=2048 apparmor=1 security=apparmor [2024-12-01 17:05:55] [ 0.000000] BIOS-provided physical RAM map: [2024-12-01 17:05:55] [ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable [2024-12-01 17:05:55] [ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved [2024-12-01 17:05:55] [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001f3fffff] usable [2024-12-01 17:05:55] [ 0.000000] BIOS-e820: [mem 0x00000000fc000000-0x00000000fc00803f] ACPI data [2024-12-01 17:05:55] [ 0.000000] BIOS-e820: [mem 0x00000000feff8000-0x00000000feffffff] reserved [2024-12-01 17:05:55] [ 0.000000] NX (Execute Disable) protection: active [2024-12-01 17:05:55] [ 0.000000] APIC: Static calls initialized [2024-12-01 17:05:55] [ 0.000000] DMI not present or invalid. [2024-12-01 17:05:55] [ 0.000000] Hypervisor detected: Xen HVM [2024-12-01 17:05:55] [ 0.000000] Xen version 4.17. [2024-12-01 17:05:55] [ 0.083655] tsc: Fast TSC calibration failed [2024-12-01 17:05:55] [ 0.083659] tsc: Detected 1991.999 MHz processor [2024-12-01 17:05:55] [ 0.083680] last_pfn = 0x1f400 max_arch_pfn = 0x400000000 [2024-12-01 17:05:55] [ 0.083705] MTRR map: 0 entries (0 fixed + 0 variable; max 16), built from 8 variable MTRRs [2024-12-01 17:05:55] [ 0.083707] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT [2024-12-01 17:05:55] [ 0.089659] Using GB pages for direct mapping [2024-12-01 17:05:55] [ 0.089775] RAMDISK: [mem 0x03801000-0x04a02fff] [2024-12-01 17:05:55] [ 0.089860] ACPI: Early table checksum verification disabled [2024-12-01 17:05:55] [ 0.089862] ACPI: RSDP 0x00000000FC008000 000024 (v02 Xen ) [2024-12-01 17:05:55] [ 0.089866] ACPI: XSDT 0x00000000FC007F60 000034 (v01 Xen HVM 00000000 HVML 00000000) [2024-12-01 17:05:55] [ 0.089870] ACPI: FACP 0x00000000FC007D60 00010C (v05 Xen HVM 00000000 HVML 00000000) [2024-12-01 17:05:55] [ 0.089874] ACPI: DSDT 0x00000000FC001040 006C9B (v05 Xen HVM 00000000 INTL 20220331) [2024-12-01 17:05:55] [ 0.089876] ACPI: FACS 0x00000000FC001000 000040 [2024-12-01 17:05:55] [ 0.089878] ACPI: FACS 0x00000000FC001000 000040 [2024-12-01 17:05:55] [ 0.089880] ACPI: APIC 0x00000000FC007E70 00003C (v02 Xen HVM 00000000 HVML 00000000) [2024-12-01 17:05:55] [ 0.089881] ACPI: Reserving FACP table memory at [mem 0xfc007d60-0xfc007e6b] [2024-12-01 17:05:55] [ 0.089883] ACPI: Reserving DSDT table memory at [mem 0xfc001040-0xfc007cda] [2024-12-01 17:05:55] [ 0.089883] ACPI: Reserving FACS table memory at [mem 0xfc001000-0xfc00103f] [2024-12-01 17:05:55] [ 0.089884] ACPI: Reserving FACS table memory at [mem 0xfc001000-0xfc00103f] [2024-12-01 17:05:55] [ 0.089885] ACPI: Reserving APIC table memory at [mem 0xfc007e70-0xfc007eab] [2024-12-01 17:05:55] [ 0.089984] No NUMA configuration found [2024-12-01 17:05:55] [ 0.089985] Faking a node at [mem 0x0000000000000000-0x000000001f3fffff] [2024-12-01 17:05:55] [ 0.089993] NODE_DATA(0) allocated [mem 0x1f3d5000-0x1f3fffff] [2024-12-01 17:05:55] [ 0.090217] Zone ranges: [2024-12-01 17:05:55] [ 0.090218] DMA [mem 0x0000000000001000-0x0000000000ffffff] [2024-12-01 17:05:55] [ 0.090219] DMA32 [mem 0x0000000001000000-0x000000001f3fffff] [2024-12-01 17:05:55] [ 0.090221] Normal empty [2024-12-01 17:05:55] [ 0.090221] Device empty [2024-12-01 17:05:55] [ 0.090222] Movable zone start for each node [2024-12-01 17:05:55] [ 0.090224] Early memory node ranges [2024-12-01 17:05:55] [ 0.090224] node 0: [mem 0x0000000000001000-0x000000000009ffff] [2024-12-01 17:05:55] [ 0.090226] node 0: [mem 0x0000000000100000-0x000000001f3fffff] [2024-12-01 17:05:55] [ 0.090227] Initmem setup node 0 [mem 0x0000000000001000-0x000000001f3fffff] [2024-12-01 17:05:55] [ 0.090231] On node 0, zone DMA: 1 pages in unavailable ranges [2024-12-01 17:05:55] [ 0.090254] On node 0, zone DMA: 96 pages in unavailable ranges [2024-12-01 17:05:55] [ 0.091113] On node 0, zone DMA32: 3072 pages in unavailable ranges [2024-12-01 17:05:55] [ 0.091176] ACPI: No IOAPIC entries present [2024-12-01 17:05:55] [ 0.091177] ACPI: Using ACPI for processor (LAPIC) configuration information [2024-12-01 17:05:55] [ 0.091178] TSC deadline timer available [2024-12-01 17:05:55] [ 0.091179] smpboot: Allowing 2 CPUs, 0 hotplug CPUs [2024-12-01 17:05:55] [ 0.091184] [mem 0x1f400000-0xfbffffff] available for PCI devices [2024-12-01 17:05:55] [ 0.091189] Booting kernel on Xen PVH [2024-12-01 17:05:55] [ 0.091190] Xen version: 4.17.5 [2024-12-01 17:05:55] [ 0.091192] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns [2024-12-01 17:05:55] [ 0.096032] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:2 nr_cpu_ids:2 nr_node_ids:1 [2024-12-01 17:05:55] [ 0.096305] percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u1048576 [2024-12-01 17:05:55] [ 0.096328] PV qspinlock hash table entries: 256 (order: 0, 4096 bytes, linear) [2024-12-01 17:05:55] [ 0.096330] Kernel command line: root=/dev/mapper/dmroot ro nomodeset console=hvc0 rd_NO_PLYMOUTH rd.plymouth.enable=0 plymouth.enable=0 clocksource=tsc xen_scrub_pages=0 swiotlb=2048 apparmor=1 security=apparmor [2024-12-01 17:05:55] [ 0.096359] Booted with the nomodeset parameter. Only the system framebuffer will be available [2024-12-01 17:05:55] [ 0.096455] Unknown kernel command line parameters “rd_NO_PLYMOUTH”, will be passed to user space. [2024-12-01 17:05:55] [ 0.096479] random: crng init done [2024-12-01 17:05:55] [ 0.096519] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [2024-12-01 17:05:55] [ 0.096545] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) [2024-12-01 17:05:55] [ 0.096573] Fallback order for Node 0: 0 [2024-12-01 17:05:55] [ 0.096576] Built 1 zonelists, mobility grouping on. Total pages: 122160 [2024-12-01 17:05:55] [ 0.096577] Policy zone: DMA32 [2024-12-01 17:05:55] [ 0.096838] mem auto-init: stack:all(zero), heap alloc:on, heap free:on [2024-12-01 17:05:55] [ 0.096839] mem auto-init: clearing system memory may take some time… [2024-12-01 17:05:55] [ 0.129548] Memory: 431012K/511612K available (18432K kernel code, 3245K rwdata, 8832K rodata, 5148K init, 6140K bss, 80344K reserved, 0K cma-reserved) [2024-12-01 17:05:55] [ 0.129704] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [2024-12-01 17:05:55] [ 0.129720] ftrace: allocating 56365 entries in 221 pages [2024-12-01 17:05:55] [ 0.137750] ftrace: allocated 221 pages with 6 groups [2024-12-01 17:05:55] [ 0.137796] Dynamic Preempt: full [2024-12-01 17:05:55] [ 0.137813] rcu: Preemptible hierarchical RCU implementation. [2024-12-01 17:05:55] [ 0.137814] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=2. [2024-12-01 17:05:55] [ 0.137815] Trampoline variant of Tasks RCU enabled. [2024-12-01 17:05:55] [ 0.137815] Rude variant of Tasks RCU enabled. [2024-12-01 17:05:55] [ 0.137815] Tracing variant of Tasks RCU enabled. [2024-12-01 17:05:55] [ 0.137816] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies. [2024-12-01 17:05:55] [ 0.137816] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [2024-12-01 17:05:55] [ 0.140420] NR_IRQS: 524544, nr_irqs: 48, preallocated irqs: 16 [2024-12-01 17:05:55] [ 0.140451] xen:events: Using FIFO-based ABI [2024-12-01 17:05:55] [ 0.140460] xen:events: Xen HVM callback vector for event delivery is enabled [2024-12-01 17:05:55] [ 0.140608] rcu: srcu_init: Setting srcu_struct sizes based on contention. [2024-12-01 17:05:55] [ 0.140692] kfence: initialized - using 2097152 bytes for 255 objects at 0x(ptrval)-0x(ptrval) [2024-12-01 17:05:55] [ 0.140715] Console: colour dummy device 80x25 [2024-12-01 17:05:55] [ 0.140727] printk: console [hvc0] enabled [2024-12-01 17:05:55] [ 0.141743] ACPI: Core revision 20230628 [2024-12-01 17:05:55] [ 0.141816] ACPI: setting ELCR to 0200 (from ffff) [2024-12-01 17:05:55] [ 0.141844] APIC: Switch to symmetric I/O mode setup [2024-12-01 17:05:55] [ 0.141863] x2apic enabled [2024-12-01 17:05:55] [ 0.141914] APIC: Switched APIC routing to: physical x2apic [2024-12-01 17:05:55] [ 0.141981] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x396d4ffc055, max_idle_ns: 881590662783 ns [2024-12-01 17:05:55] [ 0.141998] Calibrating delay loop (skipped), value calculated using timer frequency… 3983.99 BogoMIPS (lpj=1991999) [2024-12-01 17:05:55] [ 0.142113] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8 [2024-12-01 17:05:55] [ 0.142123] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4 [2024-12-01 17:05:55] [ 0.142135] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization [2024-12-01 17:05:55] [ 0.142150] Spectre V2 : Spectre BHI mitigation: SW BHB clearing on vm exit [2024-12-01 17:05:55] [ 0.142159] Spectre V2 : Spectre BHI mitigation: SW BHB clearing on syscall [2024-12-01 17:05:55] [ 0.142167] Spectre V2 : Mitigation: Enhanced / Automatic IBRS [2024-12-01 17:05:55] [ 0.142175] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch [2024-12-01 17:05:55] [ 0.142186] Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT [2024-12-01 17:05:55] [ 0.142196] RETBleed: Mitigation: Enhanced IBRS [2024-12-01 17:05:55] [ 0.142204] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier [2024-12-01 17:05:55] [ 0.142256] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl [2024-12-01 17:05:55] [ 0.142273] MMIO Stale Data: Mitigation: Clear CPU buffers [2024-12-01 17:05:55] [ 0.142280] SRBDS: Unknown: Dependent on hypervisor status [2024-12-01 17:05:55] [ 0.142298] x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’ [2024-12-01 17:05:55] [ 0.142309] x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’ [2024-12-01 17:05:55] [ 0.142317] x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’ [2024-12-01 17:05:55] [ 0.142326] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256 [2024-12-01 17:05:55] [ 0.142337] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using ‘compacted’ format. [2024-12-01 17:05:55] [ 0.142996] Freeing SMP alternatives memory: 48K [2024-12-01 17:05:55] [ 0.142996] pid_max: default: 32768 minimum: 301 [2024-12-01 17:05:55] [ 0.142996] LSM: initializing lsm=lockdown,capability,yama,apparmor,integrity [2024-12-01 17:05:55] [ 0.142996] Yama: becoming mindful. [2024-12-01 17:05:55] [ 0.142996] AppArmor: AppArmor initialized [2024-12-01 17:05:55] [ 0.142996] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear) [2024-12-01 17:05:55] [ 0.142996] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear) [2024-12-01 17:05:55] [ 0.142996] clocksource: xen: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns [2024-12-01 17:05:55] [ 0.142996] installing Xen timer for CPU 0 [2024-12-01 17:05:55] [ 0.142996] smpboot: CPU0: Intel(R) Core™ i7-8565U CPU @ 1.80GHz (family: 0x6, model: 0x8e, stepping: 0xc) [2024-12-01 17:05:55] [ 0.142996] cpu 0 spinlock event irq 20 [2024-12-01 17:05:55] [ 0.142996] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1. [2024-12-01 17:05:55] [ 0.142996] RCU Tasks Rude: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1. [2024-12-01 17:05:55] [ 0.142996] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1. [2024-12-01 17:05:55] [ 0.142996] Performance Events: unsupported p6 CPU model 142 no PMU driver, software events only. [2024-12-01 17:05:55] [ 0.142996] signal: max sigframe size: 1776 [2024-12-01 17:05:55] [ 0.142996] rcu: Hierarchical SRCU implementation. [2024-12-01 17:05:55] [ 0.142996] rcu: Max phase no-delay instances is 400. [2024-12-01 17:05:55] [ 0.142996] NMI watchdog: Perf NMI watchdog permanently disabled [2024-12-01 17:05:55] [ 0.142996] smp: Bringing up secondary CPUs … [2024-12-01 17:05:55] [ 0.142996] installing Xen timer for CPU 1 [2024-12-01 17:05:55] [ 0.142996] smpboot: x86: Booting SMP configuration: [2024-12-01 17:05:55] [ 0.142996] … node #0, CPUs: #1 [2024-12-01 17:05:55] [ 0.143026] cpu 1 spinlock event irq 25 [2024-12-01 17:05:55] [ 0.143064] smp: Brought up 1 node, 2 CPUs [2024-12-01 17:05:55] [ 0.143072] smpboot: Max logical packages: 1 [2024-12-01 17:05:55] [ 0.143080] smpboot: Total of 2 processors activated (7967.99 BogoMIPS) [2024-12-01 17:05:55] [ 0.143236] devtmpfs: initialized [2024-12-01 17:05:55] [ 0.143236] x86/mm: Memory block size: 128MB [2024-12-01 17:05:55] [ 0.144413] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns [2024-12-01 17:05:55] [ 0.144429] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [2024-12-01 17:05:55] [ 0.144474] pinctrl core: initialized pinctrl subsystem [2024-12-01 17:05:55] [ 0.144897] NET: Registered PF_NETLINK/PF_ROUTE protocol family [2024-12-01 17:05:55] [ 0.144923] xen:grant_table: Grant tables using version 1 layout [2024-12-01 17:05:55] [ 0.144946] Grant table initialized [2024-12-01 17:05:55] [ 0.145043] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations [2024-12-01 17:05:55] [ 0.145057] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [2024-12-01 17:05:55] [ 0.145074] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [2024-12-01 17:05:55] [ 0.145092] audit: initializing netlink subsys (disabled) [2024-12-01 17:05:55] [ 0.145212] thermal_sys: Registered thermal governor ‘fair_share’ [2024-12-01 17:05:55] [ 0.145213] thermal_sys: Registered thermal governor ‘bang_bang’ [2024-12-01 17:05:55] [ 0.145223] thermal_sys: Registered thermal governor ‘step_wise’ [2024-12-01 17:05:55] [ 0.145231] thermal_sys: Registered thermal governor ‘user_space’ [2024-12-01 17:05:55] [ 0.145245] audit: type=2000 audit(1733069155.791:1): state=initialized audit_enabled=0 res=1 [2024-12-01 17:05:55] [ 0.145269] cpuidle: using governor menu [2024-12-01 17:05:55] [ 0.145361] PCI: Fatal: No config space access function found [2024-12-01 17:05:55] [ 0.145500] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible. [2024-12-01 17:05:55] [ 0.176851] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [2024-12-01 17:05:55] [ 0.176851] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page [2024-12-01 17:05:55] [ 0.177032] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [2024-12-01 17:05:55] [ 0.177042] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page [2024-12-01 17:05:55] [ 0.177142] cryptd: max_cpu_qlen set to 1000 [2024-12-01 17:05:55] [ 0.177142] raid6: skipped pq benchmark and selected avx2x4 [2024-12-01 17:05:55] [ 0.177142] raid6: using avx2x2 recovery algorithm [2024-12-01 17:05:55] [ 0.177142] ACPI: Added _OSI(Module Device) [2024-12-01 17:05:55] [ 0.177142] ACPI: Added _OSI(Processor Device) [2024-12-01 17:05:55] [ 0.177142] ACPI: Added _OSI(3.0 _SCP Extensions) [2024-12-01 17:05:55] [ 0.177142] ACPI: Added _OSI(Processor Aggregator Device) [2024-12-01 17:05:55] [ 0.180187] ACPI: 1 ACPI AML tables successfully acquired and loaded [2024-12-01 17:05:55] [ 0.180324] ACPI: OSL: SCI (ACPI GSI 9) not registered [2024-12-01 17:05:55] [ 0.180485] ACPI: _OSC evaluation for CPUs failed, trying _PDC [2024-12-01 17:05:55] [ 0.181400] ACPI: Interpreter enabled [2024-12-01 17:05:55] [ 0.181409] ACPI: PM: (supports S0) [2024-12-01 17:05:55] [ 0.181416] ACPI: Using platform specific model for interrupt routing [2024-12-01 17:05:55] [ 0.181619] PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug [2024-12-01 17:05:55] [ 0.181633] PCI: Using E820 reservations for host bridge windows [2024-12-01 17:05:55] [ 0.181733] ACPI: Enabled 1 GPEs in block 00 to 0F [2024-12-01 17:05:55] [ 0.181748] ACPI Error: No handler or method for GPE 00, disabling event (20230628/evgpe-839) [2024-12-01 17:05:55] [ 0.181766] ACPI Error: No handler or method for GPE 01, disabling event (20230628/evgpe-839) [2024-12-01 17:05:55] [ 0.181788] ACPI Error: No handler or method for GPE 03, disabling event (20230628/evgpe-839) [2024-12-01 17:05:55] [ 0.181807] ACPI Error: No handler or method for GPE 04, disabling event (20230628/evgpe-839) [2024-12-01 17:05:55] [ 0.181824] ACPI Error: No handler or method for GPE 05, disabling event (20230628/evgpe-839) [2024-12-01 17:05:55] [ 0.181841] ACPI Error: No handler or method for GPE 06, disabling event (20230628/evgpe-839) [2024-12-01 17:05:55] [ 0.181858] ACPI Error: No handler or method for GPE 07, disabling event (20230628/evgpe-839) [2024-12-01 17:05:55] [ 0.184495] xen:balloon: Initialising balloon driver [2024-12-01 17:05:55] [ 0.185810] acpi LNXCPU:02: Still not present [2024-12-01 17:05:55] [ 0.185826] acpi LNXCPU:03: Still not present [2024-12-01 17:05:55] [ 0.185844] acpi LNXCPU:04: Still not present [2024-12-01 17:05:55] [ 0.185857] acpi LNXCPU:05: Still not present [2024-12-01 17:05:55] [ 0.185869] acpi LNXCPU:06: Still not present
[2024-12-01 17:05:56] [ 0.187893] acpi LNXCPU:7e: Still not present [2024-12-01 17:05:56] [ 0.187906] acpi LNXCPU:7f: Still not present [2024-12-01 17:05:56] [ 0.188010] iommu: Default domain type: Translated [2024-12-01 17:05:56] [ 0.188020] iommu: DMA domain TLB invalidation policy: lazy mode [2024-12-01 17:05:56] [ 0.188116] SCSI subsystem initialized [2024-12-01 17:05:56] [ 0.188144] ACPI: bus type USB registered [2024-12-01 17:05:56] [ 0.188144] usbcore: registered new interface driver usbfs [2024-12-01 17:05:56] [ 0.188144] usbcore: registered new interface driver hub [2024-12-01 17:05:56] [ 0.188144] usbcore: registered new device driver usb [2024-12-01 17:05:56] [ 0.188144] pps_core: LinuxPPS API ver. 1 registered [2024-12-01 17:05:56] [ 0.188144] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it [2024-12-01 17:05:56] [ 0.188144] PTP clock support registered [2024-12-01 17:05:56] [ 0.188144] EDAC MC: Ver: 3.0.0 [2024-12-01 17:05:56] [ 0.188171] NetLabel: Initializing [2024-12-01 17:05:56] [ 0.188178] NetLabel: domain hash size = 128 [2024-12-01 17:05:56] [ 0.188186] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [2024-12-01 17:05:56] [ 0.188205] NetLabel: unlabeled traffic allowed by default [2024-12-01 17:05:56] [ 0.188215] mctp: management component transport protocol core [2024-12-01 17:05:56] [ 0.188225] NET: Registered PF_MCTP protocol family [2024-12-01 17:05:56] [ 0.188234] PCI: Using ACPI for IRQ routing [2024-12-01 17:05:56] [ 0.188240] PCI: System does not support PCI [2024-12-01 17:05:56] [ 0.188258] vgaarb: loaded [2024-12-01 17:05:56] [ 0.188258] clocksource: Switched to clocksource tsc-early [2024-12-01 17:05:56] [ 0.188258] VFS: Disk quotas dquot_6.6.0 [2024-12-01 17:05:56] [ 0.188258] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [2024-12-01 17:05:56] [ 0.188258] AppArmor: AppArmor Filesystem Enabled [2024-12-01 17:05:56] [ 0.188258] pnp: PnP ACPI init [2024-12-01 17:05:56] [ 0.188262] pnp: PnP ACPI: found 0 devices [2024-12-01 17:05:56] [ 0.191038] NET: Registered PF_INET protocol family [2024-12-01 17:05:56] [ 0.191064] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear) [2024-12-01 17:05:56] [ 0.191199] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear) [2024-12-01 17:05:56] [ 0.191214] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [2024-12-01 17:05:56] [ 0.191228] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear) [2024-12-01 17:05:56] [ 0.191246] TCP bind hash table entries: 4096 (order: 5, 131072 bytes, linear) [2024-12-01 17:05:56] [ 0.191270] TCP: Hash tables configured (established 4096 bind 4096) [2024-12-01 17:05:56] [ 0.191308] MPTCP token hash table entries: 512 (order: 1, 12288 bytes, linear) [2024-12-01 17:05:56] [ 0.191325] UDP hash table entries: 256 (order: 1, 8192 bytes, linear) [2024-12-01 17:05:56] [ 0.191336] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear) [2024-12-01 17:05:56] [ 0.191361] NET: Registered PF_UNIX/PF_LOCAL protocol family [2024-12-01 17:05:56] [ 0.191376] NET: Registered PF_XDP protocol family [2024-12-01 17:05:56] [ 0.191385] PCI: CLS 0 bytes, default 64 [2024-12-01 17:05:56] [ 0.191452] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x396d4ffc055, max_idle_ns: 881590662783 ns [2024-12-01 17:05:56] [ 0.191517] Trying to unpack rootfs image as initramfs… [2024-12-01 17:05:56] [ 0.198132] Freeing initrd memory: 18440K [2024-12-01 17:05:56] [ 0.198173] clocksource: Switched to clocksource tsc [2024-12-01 17:05:56] [ 0.198719] Initialise system trusted keyrings [2024-12-01 17:05:56] [ 0.198737] Key type blacklist registered [2024-12-01 17:05:56] [ 0.198781] workingset: timestamp_bits=36 max_order=17 bucket_order=0 [2024-12-01 17:05:56] [ 0.198800] zbud: loaded [2024-12-01 17:05:56] [ 0.199075] integrity: Platform Keyring initialized [2024-12-01 17:05:56] [ 0.199084] integrity: Machine keyring initialized [2024-12-01 17:05:56] [ 0.204091] NET: Registered PF_ALG protocol family [2024-12-01 17:05:56] [ 0.204101] xor: automatically using best checksumming function avx [2024-12-01 17:05:56] [ 0.204112] Key type asymmetric registered [2024-12-01 17:05:56] [ 0.204118] Asymmetric key parser ‘x509’ registered [2024-12-01 17:05:56] [ 0.205369] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [2024-12-01 17:05:56] [ 0.205430] io scheduler mq-deadline registered [2024-12-01 17:05:56] [ 0.205440] io scheduler kyber registered [2024-12-01 17:05:56] [ 0.205450] io scheduler bfq registered [2024-12-01 17:05:56] [ 0.206599] atomic64_test: passed for x86-64 platform with CX8 and with SSE [2024-12-01 17:05:56] [ 0.208730] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled [2024-12-01 17:05:56] [ 0.209877] Non-volatile memory driver v1.3 [2024-12-01 17:05:56] [ 0.209888] Linux agpgart interface v0.103 [2024-12-01 17:05:56] [ 0.209927] ACPI: bus type drm_connector registered [2024-12-01 17:05:56] [ 0.210245] usbcore: registered new interface driver usbserial_generic [2024-12-01 17:05:56] [ 0.210259] usbserial: USB Serial support registered for generic [2024-12-01 17:05:56] [ 0.210283] i8042: PNP: No PS/2 controller found. [2024-12-01 17:05:56] [ 0.210306] mousedev: PS/2 mouse device common for all mice [2024-12-01 17:05:56] [ 0.210344] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log. [2024-12-01 17:05:56] [ 0.210362] device-mapper: uevent: version 1.0.3 [2024-12-01 17:05:56] [ 0.210398] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com [2024-12-01 17:05:56] [ 0.210457] intel_pstate: CPU model not supported [2024-12-01 17:05:56] [ 0.210486] hid: raw HID events driver (C) Jiri Kosina [2024-12-01 17:05:56] [ 0.210507] usbcore: registered new interface driver usbhid [2024-12-01 17:05:56] [ 0.210515] usbhid: USB HID core driver [2024-12-01 17:05:56] [ 0.210562] drop_monitor: Initializing network drop monitor service [2024-12-01 17:05:56] [ 0.210623] Initializing XFRM netlink socket [2024-12-01 17:05:56] [ 0.210640] NET: Registered PF_INET6 protocol family [2024-12-01 17:05:56] [ 0.211744] Segment Routing with IPv6 [2024-12-01 17:05:56] [ 0.211752] RPL Segment Routing with IPv6 [2024-12-01 17:05:56] [ 0.211762] In-situ OAM (IOAM) with IPv6 [2024-12-01 17:05:56] [ 0.211782] mip6: Mobile IPv6 [2024-12-01 17:05:56] [ 0.211790] NET: Registered PF_PACKET protocol family [2024-12-01 17:05:56] [ 0.386017] IPI shorthand broadcast: enabled [2024-12-01 17:05:56] [ 0.386032] AVX2 version of gcm_enc/dec engaged. [2024-12-01 17:05:56] [ 0.386125] AES CTR mode by8 optimization enabled [2024-12-01 17:05:56] [ 0.387478] sched_clock: Marking stable (386005679, 1386412)->(733373160, -345981069) [2024-12-01 17:05:56] [ 0.387617] registered taskstats version 1 [2024-12-01 17:05:56] [ 0.387702] Loading compiled-in X.509 certificates [2024-12-01 17:05:56] [ 0.394358] Loaded X.509 cert ‘Build time autogenerated kernel key: d7d0025f4e6fd8eabf6fa87248491b10f9d8f127’ [2024-12-01 17:05:56] [ 0.395831] page_owner is disabled [2024-12-01 17:05:56] [ 0.396088] Key type .fscrypt registered [2024-12-01 17:05:56] [ 0.396096] Key type fscrypt-provisioning registered [2024-12-01 17:05:56] [ 0.396366] Btrfs loaded, zoned=yes, fsverity=yes [2024-12-01 17:05:56] [ 0.396398] Key type big_key registered [2024-12-01 17:05:56] [ 0.397360] Key type encrypted registered [2024-12-01 17:05:56] [ 0.397370] AppArmor: AppArmor sha1 policy hashing enabled [2024-12-01 17:05:56] [ 0.397382] ima: No TPM chip found, activating TPM-bypass! [2024-12-01 17:05:56] [ 0.397403] Loading compiled-in module X.509 certificates [2024-12-01 17:05:56] [ 0.397766] Loaded X.509 cert ‘Build time autogenerated kernel key: d7d0025f4e6fd8eabf6fa87248491b10f9d8f127’ [2024-12-01 17:05:56] [ 0.397783] ima: Allocated hash algorithm: sha256 [2024-12-01 17:05:56] [ 0.397797] ima: No architecture policies found [2024-12-01 17:05:56] [ 0.397812] evm: Initialising EVM extended attributes: [2024-12-01 17:05:56] [ 0.397819] evm: security.selinux [2024-12-01 17:05:56] [ 0.397825] evm: security.SMACK64 (disabled) [2024-12-01 17:05:56] [ 0.397833] evm: security.SMACK64EXEC (disabled) [2024-12-01 17:05:56] [ 0.397839] evm: security.SMACK64TRANSMUTE (disabled) [2024-12-01 17:05:56] [ 0.397847] evm: security.SMACK64MMAP (disabled) [2024-12-01 17:05:56] [ 0.397854] evm: security.apparmor [2024-12-01 17:05:56] [ 0.397859] evm: security.ima [2024-12-01 17:05:56] [ 0.397864] evm: security.capability [2024-12-01 17:05:56] [ 0.397870] evm: HMAC attrs: 0x1 [2024-12-01 17:05:56] [ 0.419540] alg: No test for 842 (842-scomp) [2024-12-01 17:05:56] [ 0.419605] alg: No test for 842 (842-generic) [2024-12-01 17:05:56] [ 0.501021] xenbus_probe_frontend: Device with no driver: device/vbd/51712 [2024-12-01 17:05:56] [ 0.501037] xenbus_probe_frontend: Device with no driver: device/vbd/51728 [2024-12-01 17:05:56] [ 0.501046] xenbus_probe_frontend: Device with no driver: device/vbd/51744 [2024-12-01 17:05:56] [ 0.501055] xenbus_probe_frontend: Device with no driver: device/vbd/51760 [2024-12-01 17:05:56] [ 0.501064] xenbus_probe_frontend: Device with no driver: device/vif/0 [2024-12-01 17:05:56] [ 0.501277] hid_bpf: error while preloading HID BPF dispatcher: -22 [2024-12-01 17:05:56] [ 0.501283] RAS: Correctable Errors collector initialized. [2024-12-01 17:05:56] [ 0.501329] clk: Disabling unused clocks [2024-12-01 17:05:56] [ 0.502183] Freeing unused decrypted memory: 2028K [2024-12-01 17:05:56] [ 0.502787] Freeing unused kernel image (initmem) memory: 5148K [2024-12-01 17:05:56] [ 0.502805] Write protecting the kernel read-only data: 28672k [2024-12-01 17:05:56] [ 0.503182] Freeing unused kernel image (rodata/data gap) memory: 1408K [2024-12-01 17:05:56] [ 0.503197] Run /init as init process [2024-12-01 17:05:56] Qubes initramfs script here: [2024-12-01 17:05:56] [ 0.505797] Invalid max_queues (4), will use default max: 2. [2024-12-01 17:05:56] [ 0.524072] blkfront: xvda: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled [2024-12-01 17:05:56] [ 0.534167] xvda: xvda1 xvda2 xvda3 [2024-12-01 17:05:56] [ 0.537958] blkfront: xvdb: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled [2024-12-01 17:05:56] [ 0.541114] blkfront: xvdc: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled [2024-12-01 17:05:56] [ 0.543060] blkfront: xvdd: barrier or flush: disabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled [2024-12-01 17:05:56] Waiting for /dev/xvda* devices… [2024-12-01 17:05:56] Qubes: Doing R/W setup for TemplateVM… [2024-12-01 17:05:56] [ 0.891038] xvdc: xvdc1 xvdc3 [2024-12-01 17:05:56] Setting up swapspace version 1, size = 1073737728 bytes [2024-12-01 17:05:56] UUID=d8b19aae-a918-4da2-9357-39e1969dc391 [2024-12-01 17:05:56] Qubes: done. [2024-12-01 17:05:56] [ 1.014159] EXT4-fs (xvda3): mounted filesystem da476444-20eb-45a8-8ee7-292a7bc6193e r/w with ordered data mode. Quota mode: none. [2024-12-01 17:05:56] Waiting for /dev/xvdd device… [2024-12-01 17:05:56] [ 1.019366] EXT4-fs (xvdd): mounting ext3 file system using the ext4 subsystem [2024-12-01 17:05:56] [ 1.021331] EXT4-fs (xvdd): mounted filesystem 7c253527-0a42-4096-affc-44c88d74bcde ro with ordered data mode. Quota mode: none. [2024-12-01 17:05:57] mount: can’t read ‘/proc/mounts’: No such file or directory [2024-12-01 17:05:57] [ 1.158255] systemd[1]: systemd 252.31-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [2024-12-01 17:05:57] [ 1.158328] systemd[1]: Detected virtualization xen. [2024-12-01 17:05:57] [ 1.158347] systemd[1]: Detected architecture x86-64. [2024-12-01 17:05:57] [2024-12-01 17:05:57] Welcome to .[1mDebian GNU/Linux 12 (bookworm).[0m! [2024-12-01 17:05:57] [2024-12-01 17:05:57] [ 1.163555] systemd[1]: Hostname set to . [2024-12-01 17:05:57] [ 1.256597] systemd[1]: /lib/systemd/system/qubes-gui-agent.service:15: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [2024-12-01 17:05:57] [ 1.342303] systemd[1]: Queued start job for default target multi-user.target. [2024-12-01 17:05:57] [ 1.359937] systemd[1]: Created slice system-getty.slice - Slice /system/getty. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Created slice .[0;1;39msystem-getty.slice.[0m - Slice /system/getty. [2024-12-01 17:05:57] [ 1.360233] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Created slice .[0;1;39msystem-modprlice.[0m - Slice /system/modprobe. [2024-12-01 17:05:57] [ 1.360483] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Created slice .[0;1;39msystem-seria.[0m - Slice /system/serial-getty. [2024-12-01 17:05:57] [ 1.360705] systemd[1]: Created slice system-tor.slice - Slice /system/tor. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Created slice .[0;1;39msystem-tor.slice.[0m - Slice /system/tor. [2024-12-01 17:05:57] [ 1.360883] systemd[1]: Created slice user.slice - User and Session Slice. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Created slice .[0;1;39muser.slice.[0m - User and Session Slice. [2024-12-01 17:05:57] [ 1.360966] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Started .[0;1;39msystemd-ask-passwoquests to Console Directory Watch. [2024-12-01 17:05:57] [ 1.361040] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Started .[0;1;39msystemd-ask-passwo Requests to Wall Directory Watch. [2024-12-01 17:05:57] [ 1.361187] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Set up automount .[0;1;39mproc-sys-rmats File System Automount Point. [2024-12-01 17:05:57] [ 1.361249] systemd[1]: Expecting device dev-hvc0.device - /dev/hvc0… [2024-12-01 17:05:57] Expecting device .[0;1;39mdev-hvc0.device.[0m - /dev/hvc0… [2024-12-01 17:05:57] [ 1.361291] systemd[1]: Expecting device dev-xvdc1.device - /dev/xvdc1… [2024-12-01 17:05:57] Expecting device .[0;1;39mdev-xvdc1.device.[0m - /dev/xvdc1… [2024-12-01 17:05:57] [ 1.361337] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Reached target .[0;1;39mcryptsetup.get.[0m - Local Encrypted Volumes. [2024-12-01 17:05:57] [ 1.361415] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Reached target .[0;1;39mintegrityseLocal Integrity Protected Volumes. [2024-12-01 17:05:57] [ 1.361490] systemd[1]: Reached target paths.target - Path Units. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Reached target .[0;1;39mpaths.target.[0m - Path Units. [2024-12-01 17:05:57] [ 1.361543] systemd[1]: Reached target remote-fs.target - Remote File Systems. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Reached target .[0;1;39mremote-fs.target.[0m - Remote File Systems. [2024-12-01 17:05:57] [ 1.361595] systemd[1]: Reached target slices.target - Slice Units. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Reached target .[0;1;39mslices.target.[0m - Slice Units. [2024-12-01 17:05:57] [ 1.361661] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Reached target .[0;1;39mveritysetup - Local Verity Protected Volumes. [2024-12-01 17:05:57] [ 1.361786] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-fsckdsck to fsckd communication Socket. [2024-12-01 17:05:57] [ 1.361875] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-initc initctl Compatibility Named Pipe. [2024-12-01 17:05:57] [ 1.362432] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-journsocket.[0m - Journal Audit Socket. [2024-12-01 17:05:57] [ 1.362566] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log). [2024-12-01 17:05:57] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-journt.[0m - Journal Socket (/dev/log). [2024-12-01 17:05:57] [ 1.362694] systemd[1]: Listening on systemd-journald.socket - Journal Socket. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-journald.socket.[0m - Journal Socket. [2024-12-01 17:05:57] [ 1.362841] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-udevd.socket.[0m - udev Control Socket. [2024-12-01 17:05:57] [ 1.362942] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-udevdl.socket.[0m - udev Kernel Socket. [2024-12-01 17:05:57] [ 1.560655] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System… [2024-12-01 17:05:57] Mounting .[0;1;39mdev-hugepages.mount.[0m - Huge Pages File System… [2024-12-01 17:05:57] [ 1.561551] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System… [2024-12-01 17:05:57] Mounting .[0;1;39mdev-mqueue.mount.POSIX Message Queue File System… [2024-12-01 17:05:57] [ 1.564272] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System… [2024-12-01 17:05:57] Mounting .[0;1;39msys-kernel-debug…[0m - Kernel Debug File System… [2024-12-01 17:05:57] [ 1.565050] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System… [2024-12-01 17:05:57] Mounting .[0;1;39msys-kernel-tracin.[0m - Kernel Trace File System… [2024-12-01 17:05:57] [ 1.565841] systemd[1]: Starting dev-xvdc1-swap.service - Enable swap on /dev/xvdc1 early… [2024-12-01 17:05:57] Starting .[0;1;39mdev-xvdc1-swap.seEnable swap on /dev/xvdc1 early… [2024-12-01 17:05:57] [ 1.567110] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes… [2024-12-01 17:05:57] Starting .[0;1;39mkmod-static-nodesate List of Static Device Nodes… [2024-12-01 17:05:57] [ 1.568176] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs… [2024-12-01 17:05:57] Starting .[0;1;39mmodprobe@configfsm - Load Kernel Module configfs… [2024-12-01 17:05:57] [ 1.570134] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod… [2024-12-01 17:05:57] Starting .[0;1;39mmodprobe@dm_mod.s[0m - Load Kernel Module dm_mod… [2024-12-01 17:05:57] [ 1.571148] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm… [2024-12-01 17:05:57] Starting .[0;1;39mmodprobe@drm.service.[0m - Load Kernel Module drm… [2024-12-01 17:05:57] [ 1.573746] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore… [2024-12-01 17:05:57] Starting .[0;1;39mmodprobe@efi_psto- Load Kernel Module efi_pstore… [2024-12-01 17:05:57] [ 1.574800] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse… [2024-12-01 17:05:57] Starting .[0;1;39mmodprobe@fuse.sere.[0m - Load Kernel Module fuse… [2024-12-01 17:05:57] [ 1.575650] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop… [2024-12-01 17:05:57] Starting .[0;1;39mmodprobe@loop.sere.[0m - Load Kernel Module loop… [2024-12-01 17:05:57] [ 1.579062] systemd[1]: Starting systemd-journald.service - Journal Service… [2024-12-01 17:05:57] Starting .[0;1;39msystemd-journald.service.[0m - Journal Service… [2024-12-01 17:05:57] [ 1.579580] Adding 1048572k swap on /dev/xvdc1. Priority:-2 extents:1 across:1048572k SS [2024-12-01 17:05:57] [ 1.581418] loop: module loaded [2024-12-01 17:05:57] [ 1.582905] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules… [2024-12-01 17:05:57] Starting .[0;1;39msystemd-modules-lrvice.[0m - Load Kernel Modules… [2024-12-01 17:05:57] [ 1.585665] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices… [2024-12-01 17:05:57] Starting .[0;1;39msystemd-udev-trig[0m - Coldplug All udev Devices… [2024-12-01 17:05:57] [ 1.586461] systemd[1]: Condition check resulted in dev-xvdc1.swap - /dev/xvdc1 being skipped. [2024-12-01 17:05:57] [ 1.586504] systemd[1]: Unnecessary job was removed for dev-xvdc1.device - /dev/xvdc1. [2024-12-01 17:05:57] [ 1.587191] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Mounted .[0;1;39mdev-hugepages.mount.[0m - Huge Pages File System. [2024-12-01 17:05:57] [ 1.587239] fuse: init (API version 7.39) [2024-12-01 17:05:57] [ 1.589567] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Mounted .[0;1;39mdev-mqueue.mount.[- POSIX Message Queue File System. [2024-12-01 17:05:57] [ 1.589784] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Mounted .[0;1;39msys-kernel-debug.mnt.[0m - Kernel Debug File System. [2024-12-01 17:05:57] [ 1.589895] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Mounted .[0;1;39msys-kernel-tracingnt.[0m - Kernel Trace File System. [2024-12-01 17:05:57] [ 1.590100] systemd[1]: dev-xvdc1-swap.service: Deactivated successfully. [2024-12-01 17:05:57] [ 1.760946] systemd[1]: Finished dev-xvdc1-swap.service - Enable swap on /dev/xvdc1 early. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Finished .[0;1;39mdev-xvdc1-swap.se- Enable swap on /dev/xvdc1 early. [2024-12-01 17:05:57] [ 1.761375] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Finished .[0;1;39mkmod-static-nodesreate List of Static Device Nodes. [2024-12-01 17:05:57] [ 1.762696] systemd[1]: modprobe@configfs.service: Deactivated successfully. [2024-12-01 17:05:57] [ 1.762812] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@configfs[0m - Load Kernel Module configfs. [2024-12-01 17:05:57] [ 1.763251] systemd[1]: modprobe@dm_mod.service: Deactivated successfully. [2024-12-01 17:05:57] [ 1.764922] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@dm_mod.se.[0m - Load Kernel Module dm_mod. [2024-12-01 17:05:57] [ 1.765221] systemd[1]: modprobe@drm.service: Deactivated successfully. [2024-12-01 17:05:57] [ 1.765331] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@drm.service.[0m - Load Kernel Module drm. [2024-12-01 17:05:57] [ 1.765617] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [2024-12-01 17:05:57] [ 1.765939] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@efi_pstom - Load Kernel Module efi_pstore. [2024-12-01 17:05:57] [ 1.766302] systemd[1]: modprobe@fuse.service: Deactivated successfully. [2024-12-01 17:05:57] [ 1.766461] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@fuse.service.[0m - Load Kernel Module fuse. [2024-12-01 17:05:57] [ 1.766696] systemd[1]: modprobe@loop.service: Deactivated successfully. [2024-12-01 17:05:57] [ 1.766794] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@loop.service.[0m - Load Kernel Module loop. [2024-12-01 17:05:57] [ 1.767030] systemd[1]: Reached target swap.target - Swaps. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Reached target .[0;1;39mswap.target.[0m - Swaps. [2024-12-01 17:05:57] [ 1.770178] xen:xen_evtchn: Event-channel device installed [2024-12-01 17:05:57] [ 1.770605] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System… [2024-12-01 17:05:57] Mounting .[0;1;39msys-fs-fuse-conne.[0m - FUSE Control File System… [2024-12-01 17:05:57] [ 1.771937] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System… [2024-12-01 17:05:57] Mounting .[0;1;39msys-kernel-configernel Configuration File System… [2024-12-01 17:05:57] [ 1.772046] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/). [2024-12-01 17:05:57] [ 1.772887] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems… [2024-12-01 17:05:57] Starting .[0;1;39msystemd-remount-fnt Root and Kernel File Systems… [2024-12-01 17:05:57] [ 1.773007] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met. [2024-12-01 17:05:57] [ 1.774674] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Mounted .[0;1;39msys-fs-fuse-connecnt.[0m - FUSE Control File System. [2024-12-01 17:05:57] [ 1.776710] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Mounted .[0;1;39msys-kernel-config. Kernel Configuration File System. [2024-12-01 17:05:57] [ 1.789826] systemd[1]: Started systemd-journald.service - Journal Service. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Started .[0;1;39msystemd-journald.service.[0m - Journal Service. [2024-12-01 17:05:57] [ 1.794652] EXT4-fs (xvda3): re-mounted da476444-20eb-45a8-8ee7-292a7bc6193e r/w. Quota mode: none. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-remount-fount Root and Kernel File Systems. [2024-12-01 17:05:57] Starting .[0;1;39msystemd-journal-fh Journal to Persistent Storage… [2024-12-01 17:05:57] Starting .[0;1;39msystemd-sysusers.rvice.[0m - Create System Users… [2024-12-01 17:05:57] [ 1.977635] systemd-journald[254]: Received client request to flush runtime journal. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-modules-lservice.[0m - Load Kernel Modules. [2024-12-01 17:05:57] Starting .[0;1;39mqubes-db.service.[0m - Qubes DB agent… [2024-12-01 17:05:57] Starting .[0;1;39msystemd-sysctl.sece.[0m - Apply Kernel Variables… [2024-12-01 17:05:57] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-udev-trige.[0m - Coldplug All udev Devices. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-sysusers.service.[0m - Create System Users. [2024-12-01 17:05:57] Starting .[0;1;39msystemd-tmpfiles-ate Static Device Nodes in /dev… [2024-12-01 17:05:57] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-sysctl.service.[0m - Apply Kernel Variables. [2024-12-01 17:05:57] [.[0;32m OK .[0m] Started .[0;1;39mqubes-db.service.[0m - Qubes DB agent. [2024-12-01 17:05:57] Starting .[0;1;39mqubes-sysinit.ser - Init Qubes Services settings… [2024-12-01 17:05:57] Starting .[0;1;39msystemd-random-seice.[0m - Load/Save Random Seed… [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-tmpfiles-reate Static Device Nodes in /dev. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Reached target .[0;1;39mlocal-fs-prreparation for Local File Systems. [2024-12-01 17:05:58] Starting .[0;1;39msystemd-udevd.serger for Device Events and Files… [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-sysinit.ser0m - Init Qubes Services settings. [2024-12-01 17:05:58] Starting .[0;1;39mqubes-mount-dirs.tialize and mount /rw and /home… [2024-12-01 17:05:58] Starting .[0;1;39mqubes-rootfs-resim - Adjust root filesystem size… [2024-12-01 17:05:58] Starting .[0;1;39mqubes-whonix-sysies+Whonix services and settings… [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-journal-fush Journal to Persistent Storage. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-random-service.[0m - Load/Save Random Seed. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-whonix-sysiubes+Whonix services and settings. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Started .[0;1;39msystemd-udevd.servnager for Device Events and Files. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Found device .[0;1;39mdev-hvc0.device.[0m - /dev/hvc0. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-rootfs-resi[0m - Adjust root filesystem size. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-mount-dirs.nitialize and mount /rw and /home. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Reached target .[0;1;39mlocal-fs.target.[0m - Local File Systems. [2024-12-01 17:05:58] Starting .[0;1;39mlive-mode-apparmo0m - Fix AppArmor for live mode… [2024-12-01 17:05:58] Starting .[0;1;39mqubes-early-vm-coe.[0m - Early Qubes VM settings… [2024-12-01 17:05:58] Starting .[0;1;39mremove-system-map - Removes the System.map files… [2024-12-01 17:05:58] Starting .[0;1;39msystemd-binfmt.seet Up Additional Binary Formats… [2024-12-01 17:05:58] Starting .[0;1;39msystemd-tmpfiles-te System Files and Directories… [2024-12-01 17:05:58] Starting .[0;1;39mwhonix-firewall.sce.[0m - Whonix firewall loader… [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39mlive-mode-apparmo.[0m - Fix AppArmor for live mode. [2024-12-01 17:05:58] Starting .[0;1;39mapparmor.service.[0m - Load AppArmor profiles… [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-early-vm-coice.[0m - Early Qubes VM settings. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39mremove-system-map0m - Removes the System.map files. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-tmpfiles-eate System Files and Directories. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Started .[0;1;39mjitterentropy.servm - Jitterentropy Gatherer Daemon. [2024-12-01 17:05:58] Starting .[0;1;39msystemd-update-utrd System Boot/Shutdown in UTMP… [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-update-utcord System Boot/Shutdown in UTMP. [2024-12-01 17:05:58] Starting .[0;1;39mdev-xvdc1-swap.seEnable swap on /dev/xvdc1 early… [2024-12-01 17:05:58] Starting .[0;1;39mlive-mode-apparmo0m - Fix AppArmor for live mode… [2024-12-01 17:05:58] Starting .[0;1;39mmodprobe@dm_mod.s[0m - Load Kernel Module dm_mod… [2024-12-01 17:05:58] Starting .[0;1;39mmodprobe@efi_psto- Load Kernel Module efi_pstore… [2024-12-01 17:05:58] Starting .[0;1;39mmodprobe@loop.sere.[0m - Load Kernel Module loop… [2024-12-01 17:05:58] [.[0;32m OK .[0m] Created slice .[0;1;39msystem-qubeslice /system/qubes-network-uplink. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39mdev-xvdc1-swap.se- Enable swap on /dev/xvdc1 early. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39mlive-mode-apparmo.[0m - Fix AppArmor for live mode. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@dm_mod.se.[0m - Load Kernel Module dm_mod. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@efi_pstom - Load Kernel Module efi_pstore. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@loop.service.[0m - Load Kernel Module loop. [2024-12-01 17:05:58] Mounting .[0;1;39mproc-sys-fs-binfmutable File Formats File System… [2024-12-01 17:05:58] [.[0;32m OK .[0m] Mounted .[0;1;39mproc-sys-fs-binfmtecutable File Formats File System. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-binfmt.se Set Up Additional Binary Formats. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39mapparmor.service.[0m - Load AppArmor profiles. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Started .[0;1;39mhaveged.service.[0mon based on the HAVEGE algorithm. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Reached target .[0;1;39msysinit.target.[0m - System Initialization. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Started .[0;1;39mdpkg-db-backup.tim Daily dpkg database backup timer. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Started .[0;1;39me2scrub_all.timer.etadata Check for All Filesystems. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Started .[0;1;39mfstrim.timer.[0m - Discard unused blocks once a week. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Started .[0;1;39mlogrotate.timer.[0m - Daily rotation of log files. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Started .[0;1;39mman-db.timer.[0m - Daily man-db regeneration. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Started .[0;1;39mqubes-sync-time.ti.[0m - Update system time each 6h. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Started .[0;1;39mqubes-update-check - Periodically check for updates. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Started .[0;1;39msystemd-tmpfiles-c Cleanup of Temporary Directories. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Reached target .[0;1;39msysinit-pos sys-init.target by security-misc. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Reached target .[0;1;39mtimers.target.[0m - Timer Units. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Listening on .[0;1;39mdbus.socket.[- D-Bus System Message Bus Socket. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Reached target .[0;1;39msockets.target.[0m - Socket Units. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Reached target .[0;1;39mbasic.target.[0m - Basic System. [2024-12-01 17:05:58] Starting .[0;1;39mdbus.service.[0m - D-Bus System Message Bus… [2024-12-01 17:05:58] Starting .[0;1;39mdist-skel-first-bopulation at First Boot Service… [2024-12-01 17:05:58] Starting .[0;1;39me2scrub_reap.serve ext4 Metadata Check Snapshots… [2024-12-01 17:05:58] Starting .[0;1;39mmsgcollector.service.[0m - msgcollector… [2024-12-01 17:05:58] Starting .[0;1;39mqubes-antispoof.ses anti-spoofing firewall rules… [2024-12-01 17:05:58] Starting .[0;1;39mqubes-meminfo-wribes memory information reporter… [2024-12-01 17:05:58] Starting .[0;1;39mqubes-network-upl[0m - Qubes network uplink wait… [2024-12-01 17:05:58] Starting .[0;1;39mqubes-whonix-postce.[0m - Qubes-Whonix post init… [2024-12-01 17:05:58] Starting .[0;1;39mqubes-whonix-qubeally enable qubes-updates-proxy… [2024-12-01 17:05:58] Starting .[0;1;39msdwdate-pre.servicure Distributed Web Date - Pre… [2024-12-01 17:05:58] Starting .[0;1;39msysfsutils.servic variables from /etc/sysfs.conf… [2024-12-01 17:05:58] Starting .[0;1;39msystemd-logind.seice.[0m - User Login Management… [2024-12-01 17:05:58] Starting .[0;1;39mtimesanitycheck.service.[0m - Time Sanity Check… [2024-12-01 17:05:58] Starting .[0;1;39mxen.service.[0m - LSB: Xen daemons… [2024-12-01 17:05:58] Starting .[0;1;39mxendriverdomain.sXen driver domain device daemon… [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39mdist-skel-first-b Population at First Boot Service. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39mmsgcollector.service.[0m - msgcollector. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Started .[0;1;39mqubes-meminfo-writQubes memory information reporter. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-whonix-qubeonally enable qubes-updates-proxy. [2024-12-01 17:05:58] Starting .[0;1;39mlogrotate.service.[0m - Rotate log files… [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39mtimesanitycheck.service.[0m - Time Sanity Check. [2024-12-01 17:05:58] [.[0;32m OK .[0m] Finished .[0;1;39me2scrub_reap.servine ext4 Metadata Check Snapshots. [2024-12-01 17:05:59] [.[0;32m OK .[0m] Started .[0;1;39mdbus.service.[0m - D-Bus System Message Bus. [2024-12-01 17:05:59] [.[0;32m OK .[0m] Started .[0;1;39mxendriverdomain.se- Xen driver domain device daemon. [2024-12-01 17:05:59] [.[0;32m OK .[0m] Started .[0;1;39msysfsutils.servicefs variables from /etc/sysfs.conf. [2024-12-01 17:05:59] Starting .[0;1;39mbootclockrandomiz.[0m - Boot Clock Randomization… [2024-12-01 17:05:59] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-antispoof.subes anti-spoofing firewall rules. [2024-12-01 17:05:59] [.[0;32m OK .[0m] Started .[0;1;39msystemd-logind.service.[0m - User Login Management. [2024-12-01 17:05:59] [.[0;32m OK .[0m] Finished .[0;1;39mbootclockrandomizce.[0m - Boot Clock Randomization. [2024-12-01 17:05:59] [.[0;32m OK .[0m] Started .[0;1;39mxen.service.[0m - LSB: Xen daemons. [2024-12-01 17:05:59] [.[0;32m OK .[0m] Finished .[0;1;39mlogrotate.service.[0m - Rotate log files. [.[0;32m OK .[0m] Started .[0;1;39mqubes-whonix-postivice.[0m - Qubes-Whonix post init. [2024-12-01 17:06:00] Starting .[0;1;39mlegacy-dist.servitribution Legacy Versions Fixes… [2024-12-01 17:06:00] [.[0;32m OK .[0m] Finished .[0;1;39mlegacy-dist.serviistribution Legacy Versions Fixes. [2024-12-01 17:06:00] Starting .[0;1;39manon-gw-anonymizem - Make Sure Torrc Files Exist… [2024-12-01 17:06:00] [.[0;32m OK .[0m] Finished .[0;1;39manon-gw-anonymize[0m - Make Sure Torrc Files Exist. [2024-12-01 17:06:00] Starting .[0;1;39mtor.service.[0m -for TCP (multi-instance-master)… [2024-12-01 17:06:00] [.[0;32m OK .[0m] Finished .[0;1;39mtor.service.[0m -k for TCP (multi-instance-master). [2024-12-01 17:06:00] [.[0;32m OK .[0m] Finished .[0;1;39mwhonix-firewall.svice.[0m - Whonix firewall loader. [2024-12-01 17:06:00] [.[0;32m OK .[0m] Reached target .[0;1;39mnetwork-preget.[0m - Preparation for Network. [2024-12-01 17:06:00] Starting .[0;1;39mqubes-network-uplbes network uplink (eth0) setup… [2024-12-01 17:06:00] Starting .[0;1;39mqubes-whonix-netw and internal network interface… [2024-12-01 17:06:00] [.[0;32m OK .[0m] Started .[0;1;39mwhonix-firewall-reice.[0m - Whonix firewall watcher. [2024-12-01 17:06:00] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-network-uplQubes network uplink (eth0) setup. [2024-12-01 17:06:00] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-network-uple.[0m - Qubes network uplink wait. [2024-12-01 17:06:00] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-whonix-netwal and internal network interface. [2024-12-01 17:06:00] [.[0;32m OK .[0m] Reached target .[0;1;39mnetwork.target.[0m - Network. [2024-12-01 17:06:00] [.[0;32m OK .[0m] Reached target .[0;1;39mnetwork-online.target.[0m - Network is Online. [2024-12-01 17:06:00] Starting .[0;1;39monion-grater.serv- Tor control port filter proxy… [2024-12-01 17:06:00] Starting .[0;1;39mopenvpn.service.[0m - OpenVPN service… [2024-12-01 17:06:00] Starting .[0;1;39mqubes-misc-post.s - Qubes misc post-boot actions… [2024-12-01 17:06:00] Starting .[0;1;39mqubes-whonix-toriix Torified Updates Proxy Check… [2024-12-01 17:06:00] Starting .[0;1;39msystemd-user-sessvice.[0m - Permit User Sessions… [2024-12-01 17:06:00] Starting .[0;1;39mtor@default.serviymizing overlay network for TCP… [2024-12-01 17:06:00] Starting .[0;1;39mxendomains.servictart/stop secondary xen domains… [2024-12-01 17:06:00] [.[0;32m OK .[0m] Finished .[0;1;39mopenvpn.service.[0m - OpenVPN service. [2024-12-01 17:06:00] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-whonix-torionix Torified Updates Proxy Check. [2024-12-01 17:06:00] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-user-sesservice.[0m - Permit User Sessions. [2024-12-01 17:06:00] [.[0;32m OK .[0m] Started .[0;1;39mgetty@tty1.service.[0m - Getty on tty1. [2024-12-01 17:06:00] Starting .[0;1;39mqubes-gui-agent.service.[0m - Qubes GUI Agent… [2024-12-01 17:06:00] Starting .[0;1;39mqubes-qrexec-agene.[0m - Qubes remote exec agent… [2024-12-01 17:06:00] Starting .[0;1;39mqubes-updates-proQubes updates proxy (tinyproxy)… [2024-12-01 17:06:00] [.[0;32m OK .[0m] Started .[0;1;39mserial-getty@hvc0.service.[0m - Serial Getty on hvc0. [2024-12-01 17:06:00] [.[0;32m OK .[0m] Reached target .[0;1;39mgetty.target.[0m - Login Prompts. [2024-12-01 17:06:00] [.[0;32m OK .[0m] Started .[0;1;39mqubes-gui-agent.service.[0m - Qubes GUI Agent. [2024-12-01 17:06:00] [.[0;32m OK .[0m] Started .[0;1;39mqubes-qrexec-agentice.[0m - Qubes remote exec agent. [2024-12-01 17:06:00] [.[0;32m OK .[0m] Finished .[0;1;39msdwdate-gui-shutdte-gui on gateway about shutdown… [2024-12-01 17:06:00] [.[0;32m OK .[0m] Started .[0;1;39mqubes-updates-prox- Qubes updates proxy (tinyproxy). [2024-12-01 17:06:00] [.[0;32m OK .[0m] Started .[0;1;39mxendomains.service Start/stop secondary xen domains. [2024-12-01 17:06:01] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-misc-post.s0m - Qubes misc post-boot actions. [2024-12-01 17:06:01] [.[0;32m OK .[0m] Started .[0;1;39monion-grater.servim - Tor control port filter proxy. [2024-12-01 17:06:01] [.[0;32m OK .[0m] Started .[0;1;39msdwdate-pre.servicSecure Distributed Web Date - Pre. [2024-12-01 17:06:03] [.[0;32m OK .[0m] Created slice .[0;1;39muser-1000.slice.[0m - User Slice of UID 1000. [2024-12-01 17:06:03] Starting .[0;1;39muser-runtime-dir@untime Directory /run/user/1000… [2024-12-01 17:06:03] [.[0;32m OK .[0m] Finished .[0;1;39muser-runtime-dir@ Runtime Directory /run/user/1000. [2024-12-01 17:06:03] Starting .[0;1;39muser@1000.service.[0m - User Manager for UID 1000… [2024-12-01 17:06:03] [.[0;32m OK .[0m] Started .[0;1;39mtor@default.serviconymizing overlay network for TCP. [2024-12-01 17:06:03] Starting .[0;1;39mcanary.service.[0m - canary… [2024-12-01 17:06:03] [.[0;32m OK .[0m] Started .[0;1;39msdwdate-start-anon Tor Restart Request File Watcher. [2024-12-01 17:06:03] Starting .[0;1;39msdwdate.service.[0m - Secure Distributed Web Date… [2024-12-01 17:06:03] [.[0;32m OK .[0m] Started .[0;1;39mcanary.service.[0m - canary. [2024-12-01 17:06:03] [.[0;32m OK .[0m] Started .[0;1;39muser@1000.service.[0m - User Manager for UID 1000. [2024-12-01 17:06:03] [.[0;32m OK .[0m] Started .[0;1;39msession-c1.scope.[0m - Session c1 of User user. [2024-12-01 17:06:03] [.[0;32m OK .[0m] Started .[0;1;39msession-c2.scope.[0m - Session c2 of User user. [2024-12-01 17:06:03] [.[0;32m OK .[0m] Started .[0;1;39msession-c3.scope.[0m - Session c3 of User user. [2024-12-01 17:06:04] [.[0;32m OK .[0m] Started .[0;1;39msdwdate.service.[0m - Secure Distributed Web Date. [2024-12-01 17:06:04] [.[0;32m OK .[0m] Reached target .[0;1;39mmulti-user.target.[0m - Multi-User System. [2024-12-01 17:06:04] Starting .[0;1;39mpanic-on-oops.ser’ late during the boot process… [2024-12-01 17:06:04] Starting .[0;1;39msystemd-update-ut Record Runlevel Change in UTMP… [2024-12-01 17:06:04] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-update-ut - Record Runlevel Change in UTMP. [2024-12-01 17:06:04] [.[0;32m OK .[0m] Finished .[0;1;39mpanic-on-oops.ser=1’ late during the boot process… [2024-12-01 17:06:05] [2024-12-01 17:06:05] Welcome to Whonix-Gateway (R)!
