Whenever I update dom0 I get an error about not being able to remove kernel 6.6.48 since sys-usb uses kernel 6.6.48. I thought I would manually switch sys-usb to the latest kernel in the GUI but I see that another Qubes system of mine also has sys-usb on 6.6.48. Should I switch both of those to the latest?
Can anyone confirm whether their Fedora sys-usb qube is on a kernel greater than 6.6.48? If so I’ll switch it manually.
My (debian) sys-usb just uses the default kernel.
mine is
6.12.54-1.qubes.fc37.x86_64
