Hello community
I am having an issue with my usb-sys that I had several month ago and was quite easy to fix. Unfortunately, I didn’t write down the solution on a piece of paper as a reference. Today the power to our house was shut down. I had forgotton about it so Qubes OS suddenly went without power and the shutdown was not clean therefore.
Now, as the power was back up I stated my computer entered the passphrase and like a few month ago I was not able to use the keyboard to enter to logon password.
I remembered a few steps and got it working to some extent but the qubes won’t start automatically anymore.
Here is what I have done:
I added
qubes.skip_autostart
in the kernel parameters. This allowed me to log in into Qubes OS 4.3.0.
I then asked ChatGPT for help and entered these commands:
Remove old/broken sys-usb (if still present)
qvm-shutdown sys-usb
qvm-remove sys-usb --force
Create new sys-usb (StandaloneVM, label optional)
qvm-create sys-usb --class StandaloneVM --label red
Set autostart
qvm-prefs sys-usb autostart true
Reboot so USB devices attach automatically
reboot
I then rebooted and after logging in I discovered that none of the system qubes such as sys-net, sys-usb, sys-firewall have started.
When I right-click on the freshly created sys-usb qubes I get an error that does not make sense at all because I have been using Qubes OS on this hardware for 8+ years without problems at all:
“Failed to start an HVM qube with PCI devices assigned. hardware does not support IOMMU/VT-d/AMD-Vi”
Could it have to do with the --force command in qvm-remove sys-usb --force? ChatGT wrote that this qould remove all config files as well. Or did I forget a step?
Thank you in advance.
